Author Topic: D.I.Y. active crossover network :)  (Read 8259 times)
Offline mc_king
  • Pogi/Ganda Points: 4
Re: D.I.Y. active crossover network :)
« Reply #60 on: July 07, 2011, 02:19:33 PM »
mga sis penge naman po ako ng info about sa circuit na to. gusto ko rin po syang gawin. ;D ;D
eto po ang email ko spoco_notnot@yahoo.com..
pag naumpisahan ko na i post ko po dito.
thanks in advance! ;D ;D
sir paki open this link
http://diy.haikusolutions.com/files/Active3-WayCrossoverSC.zip
Offline spoco
  • Pogi/Ganda Points: 13
« Reply #61 on: July 07, 2011, 03:08:12 PM »
sis mc_king thanks sa email..
eto pampa pogi mo sis +1  :)
Offline mc_king
« Reply #62 on: July 07, 2011, 03:55:57 PM »
thanks sis.
my first point. memoravilla.
Offline jbmobile
  • Pogi/Ganda Points: 8
  • if you think u can do it...DIY
« Reply #63 on: July 12, 2011, 03:52:22 PM »
makisawsaw nga...ano bang mga cross over points ginamit nyo?.. lo-mid x over at mid-hi x over freqs..maganda ito L-R 24dB 3way x over network...  ;D
  • Pogi/Ganda Points: 136
« Reply #64 on: July 12, 2011, 04:55:27 PM »
240Hz yata sa low-mid at 2.4Khz sa mid-hi.
Offline Skyjham
  • Pogi/Ganda Points: 138
« Reply #65 on: September 01, 2011, 06:27:37 PM »
ito po sakin pasensya na po kung medyo di maayos pagkagawa ko.
Learning is un-ending process
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #66 on: September 01, 2011, 06:42:27 PM »
WootsPC2 Videos  Woots Page
Offline Woots29
  • asan si mojacko?
    • Woots Page
« Reply #67 on: September 01, 2011, 06:44:14 PM »
nice +1  ;D
Offline Skyjham
« Reply #68 on: September 01, 2011, 06:58:47 PM »
thanks bro Woots29
Offline viel_dk
« Reply #69 on: September 01, 2011, 06:59:39 PM »
mga sir pwede po pa send sa email ko yung mga partslist para mapagaralan ko ng konti at makagawa na rin.. ;D
gusto ko kasi gumawa ng 2.1 multimedia system eh..
zaldy712@yahoo.com
salamat po...
no past, no future......
Offline lovehack
  • Error 105 (net::ERR_NAME_NOT_RESOLVED): Unable to
« Reply #70 on: September 03, 2011, 10:50:02 PM »
nice project.... balance out ba yan?
The server at yahoo.com can't be found, because the DNS lookup failed. DNS is the web service that translates a website's name to its Internet address. This error is most often caused by having no connection to the Internet or a misconfigured network.
Offline OsonerOmolap
« Reply #71 on: October 07, 2011, 01:44:17 PM »
Mga bosing pa hingi naman nag parts list........... Eto ung email add ko. osoneromolap@gmail.com thanks in advance............ God Bless..........
« Reply #72 on: October 08, 2011, 12:31:53 PM »
Pwede lang din ba gumamit ng ceramic sa crossover ckt?
Offline Skyjham
« Reply #73 on: October 08, 2011, 04:39:54 PM »
Parts List 3-Way Active Crossover
1 1RU rack-mounting case, Altronics H-5011 or equivalent
1 PC board, code 01101031, 219 x 99mm
1 IEC power socket
1 chassis-mount safety fuseholder (3AG or M205 type)
1 0.5A fuse (3AG or M205 type to suit fuseholder)
1 DPST rocker switch with inbuilt neon (S1)
1 20VA toroidal transformer with 2 15V secondaries
1 3-way insulated terminal block
4 dual gold-plated RCA PC-mounting sockets, Altronics P-0212 or equivalent
6 multi-turn 100kΩ trimpots (VR1-VR6), Altronics R-2382A or equivalent
Semiconductors
6 TL074 quad FET-input op amps (IC-IC6)
1 7815 positive 3-terminal regulator
1 7915 negative 3-terminal regulator
4 1N4004 silicon diodes (D1-D4)
Capacitors
2 1000μF 25V PC electrolytic
2 100μF 25V PC electrolytic
2 1μF 50V bipolar electrolytic
14 100nF (0.1μ) multi-layer ceramic (code 100n or 104)
20 47nF (.047μ) metallised polyester (code 47n or 473)
20 2.2nF (.0022μF) metallised polyester (code 2n2 or 222)
2 220pF ceramic
Resistors (1% metal film)
2 47kΩW (yellow violet orange brown or yellow violet black red brown)
8 20kΩ (red black orange brown or red black black red brown)
38 10kΩ (brown black orange brown or brown black black red brown)
4 100Ω (brown black brown brown or brown black black black brown)
Offline sh@rp
« Reply #74 on: October 28, 2011, 11:31:40 AM »
ako rin sir! engrenn@gmail.com! more power!
Never Try to be Successful, Pursue Excellence
Offline Mhavskie
  • Pogi/Ganda Points: 77
  • NeverShoutNever!
« Reply #75 on: October 28, 2011, 11:49:45 AM »
teka baka may schem kayo ng 2-way active cross over jan, low - (mid-hi)
« Reply #76 on: October 28, 2011, 12:39:27 PM »
Pag fixed lang ang frequency sis mganda na yung 24dB/ocatve ni Rod Elliot. Baka may magbigay ng variable dyan hintay na lang muna at ako ay di rin mahilig sa variable.
Pero sana may schema si sir skyjham.
Offline labgruppen
  • Pogi/Ganda Points: 87
« Reply #77 on: October 28, 2011, 07:42:12 PM »
Try this.
Variable freq. 24 db/octave crossover. You will need a quad-potentiometer though.
Uploaded with ImageShack.us
Inputs and outputs are fully balanced. Single channel is shown.
Offline Mhavskie
  • NeverShoutNever!
« Reply #78 on: October 28, 2011, 08:04:33 PM »
ayos +1 sis,, save ko muna :)
Offline DJFEL
« Reply #79 on: October 28, 2011, 08:46:39 PM »
pa sub...nice 1..
dj fel on the mix
