luckily, nakita ko na rin ung mga pics at video sa experiment ko...
(di nga lang sobrang linaw dahil kuha lang sa cellfone ko)
CAUTION: ALWAYS WEAR PROPER SAFETY PROTECTIVE CLOTHING (SAFETY GOGGLES, GLOVES, ETC).PICTURE SECTIONbattery 1sa kaliwang plastic container ung aluminum pipe (outside), blue plastic separator, at copper pipe (inside-hidden),
sa kanang plastic container ung copper pipe (inside), cpvc separator, at used aluminum soda can (outside),
sa likod ung different pipe sizes after testing...
battery 2ung clorox medyo umiitim dahil kinakain ung aluminum soda can,
at ung copper pipe nagkakaroon ng green residue dahil sa reaction ng copper sa chlorine gas (?)...
battery 3ung copper pipe sa loob (hidden), ung aluminum pipe (outside - medyo makapal),
then plastic sheet separator ung blue...
battery 4with the above set-up, nakakuha ako ng 2.021VDC @ 24.17mA...
VIDEO SECTIONbattery test 1 (click on the image to play video clip)
battery test 2 (click on the image to play video clip)
battery test 3 (click on the image to play video clip)
battery test 4 (click on the image to play video clip)
battery test 5 (click on the image to play video clip)
