Author Topic: Subsitutions of TB1238AN jungle ic  (Read 808 times)
Offline envader
  • Pogi/Ganda Points: 18
  • simplicity is beauty
« on: September 08, 2010, 02:53:52 PM »
Mga master, baka may alam ky0ng sub ng nsabing ic kc wlng mbilhan dito sa amin. Tia.
GUSTO MO BA NG EXTRA INCOME? BUMISITA KA DITO AT MAGRIGISTER: http://viralpaidads.com/?=3666
Offline bobbie
  • Pogi/Ganda Points: 63
Re: Subsitutions of TB1238AN jungle ic
« Reply #1 on: September 08, 2010, 05:04:17 PM »
confirm ba na yan ang sira?
Offline gie62
  • Pogi/Ganda Points: 56
« Reply #2 on: September 08, 2010, 06:52:46 PM »
http://www.newportelec.com/ic_t.html
dyan meron, pwede mong padeliver sa inyo..
Offline envader
« Reply #3 on: September 08, 2010, 10:17:12 PM »
yes sir, confirm kc sinubok k0 s good 1 ok xa, pro wl dito kht junk man lng. Salamat sir.
Offline envader
« Reply #4 on: September 08, 2010, 10:23:40 PM »
yes sir, gusto ko po subukan k0ng wla nang ibang paraan, 300+ lng d0n. Xa nga pala sir, hnd po ba tyo maloko niyan? Nsubukan ko rin bumili ng online sa alexan at ok nman wlng prblm, pro s area ko ngaun ay wlng s0urce sa pgbayad s knila. Salamat sir.
Offline envader
« Reply #5 on: September 08, 2010, 10:32:20 PM »
Salamat s inyo, mga poge 4u.
Offline gie62
« Reply #6 on: September 09, 2010, 07:09:06 AM »
madaming beses nakong kumuha dyan. may tindahan sila sa evangelista st. quiapo. sa bank, smartmoney, gcash ang bayaran dyan. saan ka ba?
Offline envader
« Reply #7 on: September 10, 2010, 07:31:29 PM »
sir, nasa cotabato p ako n0ng kumukuha ako s alexan, d0n may s0urce p ako s pgbayad ng mbilis pro ngaun nasa jolo sulu n ako, money order lng ang s0urce di2. Sir sinubukan ko na mag inquery s newp0rt. Thanks.
Offline envader
« Reply #8 on: September 10, 2010, 08:06:12 PM »
Xa nga po mga sir, pkibigay nmn po ng pinout ng ta1268n kc my hhagilapin lng po ako, di kc kya i dload ng cp ko s net kc masyado mlaki ang files, salamat po.
Offline gie62
« Reply #9 on: September 10, 2010, 08:52:53 PM »
ta1268n
pin #                         pin #
1 n.c.                            29 x-ray
2 sound out                    30 fbp in
3 rf agc                          31 sync. out
4 sif tank                        32 h. out
5 agc filter                      33 h. afc
6 pif ground                     34 32fH vco
7 pif in                            35 d. ground
8 pif in                            36 abl
9 pif vcc                         37 tv in
10 loop filter                    38 acl
11 apc filter                     39 ext. video
12 vcxo                           40 black det
13 gnd                            41 av / sw out
14 f-blk                           42 dc rest
15 analog r-in                   43 y in
16 analog g-in                  44 aft
17 analog b-in                  45 chroma in
18 d. vcc (3.3v)               46 vcc
19 r-out                          47 tv det. out
20 g-out                         48 sif vcc
21 b-out                         49 pif tank
22 v. out                        50 pif tank
23 nfb                            51 sif gnd
24 v. ramp                      52 limiter in
25 v sepa filter                53 audio tv in
26 h. vcc (9v)                 54 de-emphasis
27 scl                            55 ext. audio
28 sda                           56 n.c.
Offline envader
« Reply #10 on: September 10, 2010, 09:12:18 PM »
sir gie62, salamat po s pinout, poge po kyo.
Offline song
  • Pogi/Ganda Points: 34
  • tyaga + elab, makukuha mo din yan!!!
« Reply #11 on: October 11, 2010, 02:14:43 PM »
sis ghie mukha di yata correct part number naibigay mo ke sis storm TB po need nya, TA po naibigay nyo. napansin lang po. hehehe
"It takes a month to find a customer, seconds to loose one."
Song's TV Shop
Offline song
« Reply #12 on: October 11, 2010, 02:17:39 PM »
ay sori po naduling ako. hehehe correct po kau.
Song's TV Shop
