Author Topic: Elliott Sound Products (DIY)  (Read 1589 times)
Offline neutron
  • Pogi/Ganda Points: 13
    • wheelee
« on: September 14, 2010, 03:18:24 PM »
ello, may naka try na ba mag build ng mga sa site nya lalo na itong 1.5KW amp  :o
PSU
http://sound.westhost.com/p-list.htm
Offline lhong2x
  • if something makes u weak, make it as ur strength
Re: Elliott Sound Products (DIY)
« Reply #1 on: October 15, 2010, 12:36:46 PM »
meron po ba kayong pcb layout nito bossing???
yayay! :)
Offline neutron
    • wheelee
« Reply #2 on: October 15, 2010, 02:21:34 PM »
sa palagay nyo ba magkano ang aabutin nito kung mga 500W/ channel lang?
Offline Dandy
  • Pogi/Ganda Points: 31
« Reply #3 on: March 30, 2012, 07:26:08 PM »
jeeez!...  gawan mo ng pcb, gawan ko ng BOM price.  Can test with lower voltage I guess.
  • Pogi/Ganda Points: 315
« Reply #4 on: March 30, 2012, 07:39:50 PM »
p117 ahahay ;D
Offline efren
  • Pogi/Ganda Points: 210
  • old school audio fanatic
« Reply #5 on: March 30, 2012, 08:10:23 PM »
kahit si Rod Elliot sinabi nya hindi nya ia-attempt gawin yan, totally insane daw  ;D
Just a word of unsolicited advice, take it or ignore it: start with lower power amps before attempting to build this one, unless you are a well seasoned builder who knows the theoretical & technical aspect like a whistle, otherwise you're heading for a disaster for sure ;)
"just keep 'em glowing"
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« Reply #6 on: March 30, 2012, 09:12:36 PM »
Kailangan mo ng 70-0-70vac na power supply para sa 500w/channel into 8 ohms.
Pero kung 500watts into 4 ohms, kailangan mo lang ng 55-0-55vac.
Dito kailangan mo at least 1.5kw na trafo para sa stereo.
For 250watts/channel pwede na yung P68 ni Elliot.
Tig 165 pesos ang MJ15025 sa newportelec.com.
Sabi nila may problema daw ang circuit na yan pero palagay ko pwedeng i-try muna sa lower voltage at pag maayos na pwedeng i-try sa rated voltage.
Offline Dandy
« Reply #7 on: March 30, 2012, 10:30:46 PM »
wow..!   ganun!
@ neutron, interesting itong  post mo.  I wonder if there is really interested in building this AMP scaling the voltage to fit to normal +/-50Vdc,  and reducing the power transistor to 2 or 3 for test (but include all the power transistor pad on the PCB design)  ---- do it for fun or disaster.
pa OT, or proven circuit hanap,  doon sa Laguisma Electronics series 1,2,  proven na proven  and built by several thousand students and audio hobbyist.
  • Make it simple
« Reply #8 on: March 31, 2012, 07:23:18 AM »
He's referring to the amount of power, but not to the design.
He said if you could pay him the amount of money involved, he is willing to do it and it will work.
Offline neutron
    • wheelee
« Reply #9 on: April 16, 2012, 05:57:51 PM »
actually halos standard design naman yung input/ pre/ bias stage nya ang nakakamahal dito is yung output Transistors & PSU.
I remember repairing an amp, forgot the model, with almost 12 output transistors, tinest muna namin sa 2 then 4 ok naman na sya, nung nilagay na namin  laht ng trans *pok* tigot "nanaman" silang lahat - aguy!!!
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #10 on: April 17, 2012, 01:50:10 AM »
baka something wrong sis? baka may shorted na ouput transistor? either bad batch/fake possible damay yung ibang ouput tran.?
kasi diba mas safe pa nga yung more output trannies VS lower count of output transistor lalo na if lower impedance yung load!
