Author Topic: Pano po nagana ang CCTV?  (Read 939 times)
Offline Boks
« on: September 14, 2010, 07:29:49 PM »
pano yung transmission? wired? wireless?
If you fail to plan,
You plan to fail...
              -signboard.. =)
Re: Pano po nagana ang CCTV?
« Reply #1 on: September 14, 2010, 09:28:00 PM »
As the acronym suggest, Closed Circuit TV which means it is wired ...at least it was originally wired but nowadays due to the popularity of home/business security monitoring, cctv is a term more associated to security camera systems both wired or wireless.
Offline Mr. D
  • Pogi/Ganda Points: 369
  • "Agta Maloko"
« Reply #2 on: September 14, 2010, 10:40:50 PM »
may wired at may wireless. may mga camera na built-in na yung transmitter at meron namang separate ang transmitter (ikanakabit ito kung meron ng existing na camera). dati sa VHS tape pa yung recording pero ngayon meron ng DVR (hard disk na ang ginagamit).
Good Guys Never Hide
Offline angehlo_1027
« Reply #3 on: November 19, 2010, 04:28:37 PM »
there are three components of cctv system. una ung cctv camera/s. then next is the dvr. then next is monitor.
Offline lordemtech
  • Pogi/Ganda Points: 17
  • "Life is how you make it"
« Reply #4 on: January 20, 2011, 04:12:17 PM »
ano kaya mas maganda na cable ng cctv cam, cat5 o yung auxilliary wire?
"I am a slow walker, but i never walk back"
Offline x13r_kit_0
  • Pogi/Ganda Points: 149
  • --__x13r_kit_0__--
« Reply #5 on: February 25, 2011, 11:41:51 AM »
sa pinangalingan kong company hindi pareho.,gumagamit ng coaxial cable at ung isa nmn cat-5 cable na may signal balloon sa magkabilang dulo,papuntang camera at s DVR.
   =How about the other side?=
« Reply #6 on: February 25, 2011, 11:52:17 AM »
The typical setup for Large or Wide Area Analog Wired CCTV, is something like this=)
Cameras----[Coaxial Cable]----Video Amplifier ----[CAT5e] ---------------------------------------------------Video Amplfier ---------[Coaxial Cable] ---- DVR
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #7 on: February 25, 2011, 12:15:31 PM »
simple other setup like this
camera------------coaxial cable-----------dvr----------cpu/monitor
camera------------coaxial cable-----------standalone dvr/HDD---------monitor
wireless camera- reciver-cpu/monitor
Offline x13r_kit_0
« Reply #8 on: February 25, 2011, 01:09:51 PM »
power supply ng camera baka makalimutan,d makakakita yan..hehehe :) :) :)iether centralized or adapter type.
Offline Vaounsi
« Reply #9 on: February 25, 2011, 01:11:37 PM »
toinks.nyahahaha ;D ;D ;D ;D
« Reply #10 on: February 25, 2011, 01:20:25 PM »
sama naten NVR :D
IP Cameras --- Network Switch -- NVR
:D
pede rin..
IP Camera -- NVR :D
pede ring standalone IP camera, just see kung support nito ang flash storage like SD Card :D
Offline Vaounsi
« Reply #11 on: February 25, 2011, 01:26:27 PM »
 :D :D ;D
pati to
wireless palm monitor kit.. dapat suported din ng flash storage  ;) ;D
