Author Topic: Pahelp po on buying smd parts sa project ko...  (Read 308 times)
  • Pogi/Ganda Points: 53
« on: September 18, 2010, 04:12:35 PM »
Mmm... Patulong po sana ako kung sino man magmamagandang loob na tumulong,,, need ko lang po sana ng pyesa to finish my project... heto po parts:
4 x 2N3904
4 x 27 pF Capacitor
2 x 0.01uF Capacitor
2 x 20 MHz Xtal Oscillator
2 x Push button switch (yung maliit lang na may apat na legs)
2 x Common Cathode 7-segment display (2 yung digits)
ALL PARTS ARE SURFACE MOUNT EXCEPT FOR THE push buttons and 7-SEGMENT...
Sorry po sa abala wala kasi me makuhang pyesa dito sa location ko(bicol-legaspi city).
Di ko rin alam prices niyan. Willing po ako magdagdag ng money if kalabisan man yung hinihingi ko... PM NIYO PO AKO.
Salamat po! GOD BLESS
Re: Pahelp po on buying smd parts sa project ko...
« Reply #1 on: September 18, 2010, 08:38:11 PM »
Up! up! up!
« Reply #2 on: September 18, 2010, 09:20:56 PM »
Up ko lang po...
« Reply #3 on: September 19, 2010, 07:37:29 AM »
Wala ata gusto tumulong :D
Ask ko na lang po if pwede mg-order sa alexan or deeco ng mga IC or electronic components?
« Reply #4 on: September 19, 2010, 08:20:33 AM »
Kailan mo ba kailangan yan?  Mahirap maghanap ng mga smd  components, usually ino-order pa ayn and in bulk quantities.
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #5 on: September 19, 2010, 08:51:23 AM »
Try mo kay eGizmo din. Damihan mo ang quantity para it will be worth the abala. It is very to lose 2x0.01uF SMD parts for example.
By chance, do you know our moderator Marce? You are near him.
BTW, some of those SMD parts were also in the PICkit2.
"Set your mind free!"
Offline gie62
  • Pogi/Ganda Points: 56
« Reply #6 on: September 19, 2010, 10:26:56 AM »
Offline NanotecH
  • Pogi/Ganda Points: 44
« Reply #7 on: September 19, 2010, 10:31:28 AM »
alam ko meron ako lahat nyan (not sure sa 0.01 uF) except 7 segment at pati PB switch smd.
problema lang kailangan kong kontakin brother ko sa cavite dahil nasa kanya lahat ng parts ko.
kelan mo ba kailangan yan?
kung rush yan baka di kita matulungan...
