Author Topic: help: component values for stereo amplifier  (Read 522 times)
Offline cybercarlos02
  • can't hardly wait....
« on: September 24, 2010, 01:48:20 AM »
patulong naman sa binubuo kong amplifier kit
magkakaiba kasi ung ibang component values na nasa schematic, sa pcb lay-out, tsaka yung included component sa kit
wala kaya maging effect un??
e2 pala sila
               schematic,pcb,included
capacitor- 202, .005, (203 or 502)
               203, .02, (203 or 502)
resistor-    5WR22J, (included 5WR39J)
PATULONG NA REN SA BASIC TROUBLESHOOTING! DI KO MAPAGANA EE!
THANKS IN ADVANCE!
" i'm not a complete IDIOT, some parts are still missing. "
Re: help: component values for stereo amplifier
« Reply #1 on: September 24, 2010, 01:54:45 AM »
tsaka yung transistor pa pla 2SC945 sa schematic pero D438 ung asa kit
help,,pls!! ;)
Offline Engr. Dacuycoy
  • Pogi/Ganda Points: 162
  • Proton Orcad EasyPCB User
« Reply #2 on: September 24, 2010, 02:04:09 AM »
202 = 0.002uF
203 = 0.02uF
502 = 0.005uF
5WR22J = 5WATTS 0.22 OHMS +/-5% = J
« Reply #3 on: September 24, 2010, 02:17:30 AM »
the transistor 2sc945 is equivalent of d438 (2SD438)
do check the datasheet for pin configuration.
« Reply #4 on: September 24, 2010, 02:26:14 AM »
salamat sir!
di bale swak na ren yung 0.22 ohms at 0.39 ohms
maliit lang naman difference.
pahirapan na lng sa paghanap ng problema,,sana mapagana..
thanks ulit!
« Reply #5 on: September 24, 2010, 02:39:02 AM »
you are welcome. much better if you can post the schematic so that other may give you some hints.
Offline yokogawa
« Reply #6 on: October 24, 2010, 12:47:35 AM »
tama..post mo nlng yung schem diag para ma analyze ng mga engrs dito...
Offline akosiikem
  • Pogi/Ganda Points: 4
« Reply #7 on: October 24, 2010, 12:56:33 AM »
good luck sa built. Post mo lang dito pag may problema ka.
