Author Topic: Sony KV-14JDR1 auto shut OFF  (Read 2351 times)
Offline Erol
  • Pogi/Ganda Points: 6
« on: October 02, 2010, 06:54:11 AM »
Patulong mga masterz, auto shut off sya after 2 blinks.
Ito info:
may supply ang B+ = 115v, may supply din to vertical = 11.5v.
mga ask ko po kung normal pa ung voltage sa regulator pin#1 na 324v sa schematic is 226V lng.
Thanks in advance mga masterz....
Offline Triple_D
  • Pogi/Ganda Points: 164
Re: Sony KV-14JDR1 auto shut OFF
« Reply #1 on: October 02, 2010, 07:29:13 AM »
anu mga nagawa mo na sir?naghinang ka na ba?
Offline Erol
« Reply #2 on: October 02, 2010, 09:41:44 AM »
nagpalit na ako ng mga ecaps sa primary sir saka check resistors.
Offline J@M
« Reply #3 on: October 02, 2010, 10:16:56 AM »
Bro!   palit ka ecap sa vertical mo, 100uf ata un 2pcs sakit na yan ng sony TV set. alam me sa vertical lng yan 2 blink Nd auto shut oFF kunti lng aman ecap sa Vertical palitan u na lhat...
sna mkatulong....
Don't Give up
Offline Erol
« Reply #4 on: October 02, 2010, 11:34:36 AM »
cge sir try ko muna palitan lahat un sa +15v pa lng kac pinalitan ko. thnx sir
  • Pogi/Ganda Points: 231
« Reply #5 on: October 02, 2010, 11:46:03 AM »
TS.. tanong ko lang nakakapag Oscilate pa ba ang flyback bago sya mag shut off? may raster ba sya bago mag off, Check mo yung B+ voltages nya during mag oscilate ang Flyback, also try mo muna paganahin sa 110V.
Offline Erol
« Reply #6 on: October 02, 2010, 12:02:42 PM »
Sis meron oscillation kasi may nasusukat ako sa secondary bago mamatay at stable ang B+ na 115v.
« Reply #7 on: October 02, 2010, 12:34:53 PM »
pag nag shut off, wala na din bang ilaw yung LED standby?
Offline Erol
« Reply #8 on: October 02, 2010, 01:02:00 PM »
meron sir naka-ilaw. pag-nagooscillate patay ang LED.
« Reply #9 on: October 02, 2010, 03:00:41 PM »
check supply sa  system  at jungle IC, check also vertical section.
  • Pogi/Ganda Points: 909
« Reply #10 on: October 02, 2010, 04:48:01 PM »
vertical
Offline Triple_D
« Reply #11 on: October 02, 2010, 04:52:43 PM »
check HOT and vert.
Offline Erol
« Reply #12 on: October 02, 2010, 04:59:07 PM »
cge sir check ko vertical section, good ung HOT sis.
Offline Erol
« Reply #13 on: October 03, 2010, 06:40:24 AM »
mga masterz napalitan ko na lahat ng ecaps sa vertical same pa rin. Kompleto rin supply ng jungle and systen ano pa kaya pwede mga sis? thanks sa mga 2long nyo.
Offline NORTH LUZON
  • Pogi/Ganda Points: 811
« Reply #14 on: October 03, 2010, 08:50:40 AM »
palit vertical out muna
Offline Erol
« Reply #15 on: October 03, 2010, 02:41:20 PM »
cge sis try ko magpalit sana may mabilhan pa ne2 LA7830 Vertical IC nya. hehehe luma na ata 2 eh
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
« Reply #16 on: October 03, 2010, 03:22:50 PM »
ganito rin problem dati nun tv ko, nasisira rin pala mylar capacitor, nakita ko kasi may kaunti parang maitim na nakalagay siya sa vertical ic nun pinalitan ko ok na.
Offline pEN DoTA
« Reply #17 on: October 03, 2010, 04:50:46 PM »
direct replacement muna sa Vertica IC.
GOD LOVES YOU
Offline Erol
« Reply #18 on: October 04, 2010, 06:19:19 AM »
Sir Pendot nagpalit na ako ng vertical IC same pa rin ano pa kaya pweding sira nito?.
Offline enriz622
  • Pogi/Ganda Points: 284
« Reply #19 on: October 04, 2010, 10:00:58 AM »
