Author Topic: pa2long naman po sa clock with stopwatch  (Read 401 times)
Offline sonic05
« on: October 03, 2010, 05:30:54 PM »
http://drop.io/e2_po
ayan po ung schematic nya ung 1st po bli ung ginawa q pero common cathode po ginamit q and binase q naman po ung connection ng transistor dun sa second schematic po...
e2 po ung program ng clock at ung balak q po sana gumawa ng clock na pwede ring maging stopwatch pero d q naman po alam kung pano gagawin at isisingit d2 sa program please pa2long naman po...na kapag pinindot ung switch na idadagdag dun lang po sana mag rurun ung stopwatch,.
#include <16F877A.h>
#fuses XT,NOWDT,PUT,NOBROWNOUT,NOLVP
#use delay(clock = 40000000)
#byte PORTA=0X05
#byte PORTC=0x07
#byte PORTB=0X06
#define A0 PIN_A0
#define A1 PIN_A1
#define A2 PIN_A2
#define A3 PIN_A3
#define A4 PIN_A4
int sec1,sec2,min1,min2,hour1,hour2;
int num1=5,num2=5,num3=5;
int counter=125;
int flag=0;
const int table[10]={0b00111111,
0b00000110,
0b01011011,
0b01001111,
0b01100110,
0b01101101,
0b01111101,
0b00000111,
0b01111111,
0b01101111};
void main()
PORTB=0X00;
PORTC=0X00;
set_tris_a(0xff);
set_tris_c(0x00);
set_tris_b(0x00);
set_RTCC(6);
setup_counters(RTCC_INTERNAL,RTCC_DIV_32);
enable_interrupts (INT_RTCC);
enable_interrupts (GLOBAL);
for(;Wink
PORTB=table[sec1];
PORTC=0X01;
delay_ms(3);
PORTB=table[sec2];
PORTC=0x02;
delay_ms(3);
PORTB=table[min1];
PORTC=0x04;
delay_ms(3);
PORTB=table[min2];
PORTC=0x08;
delay_ms(3);
PORTB=table[hour1];
PORTC=0x10;
delay_ms(3);
PORTB=table[hour2];
PORTC=0x20;
delay_ms(3);
if(flag==1){
flag=0;
 if(input(A4)==1)
                        disable_interrupts(INT_RTCC);
                      if(input(A2)==1) { --num1; }
                      if(num1==0){
                           if(++min1>9) {
                                       min1=0;
                                if(++min2>5) {  min2=0; }
                                        num1=5;
                      if(input(A3)==1){ --num2; }
                               if(num2==0) {
                                     if( ++hour1>9 )
                                                  hour1=0;
                                                 ++hour2;
                                     if( (hour2==1) & (hour1==3) )  {
                                                              hour1=1;
                                                               hour2=0;
                                                       num2=5;
                     if(input(A1)==1) { --num3; }
                      if(num3==0){
                           if(++sec1>9) {
                                       sec1=0;
                                if(++sec2>5) {  sec2=0; }
                                        num3=5;
                    else if(input(A4)==0){
                                enable_interrupts(INT_RTCC);
#int_RTCC
void microII()
{ //void switch_time();
if(--counter>0)return;
counter=125;
flag=1;
if(++sec1>9){
sec1=0;
if(++sec2>5){
sec2=0;
if(++min1>9){
min1=0;
if(++min2>5){
min2=0;
if( ++hour1>9 )
hour1=0;
++hour2;
sec1=0;
sec2=0;
min1=0;
min2=0;
hour1=1;
hour2=0;
Re: pa2long naman po sa clock with stopwatch
« Reply #1 on: October 03, 2010, 07:22:23 PM »
first glance,
maybe
#use delay(clock = 4000000)
Offline sonic05
« Reply #2 on: October 03, 2010, 07:28:50 PM »
opo cge po...
Offline sonic05
« Reply #3 on: October 03, 2010, 07:47:56 PM »
satingin nyo ?? kakayanin po ba??
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #4 on: October 03, 2010, 08:38:46 PM »
   SPAM ba 'to ?
mas ok sana kung naka-upload din mismo yung proteus file.. :)
and hi-tech C compiler ang gagamitin.
anong gamit mong crystal?
also, use [ code]  ... [/ code ] for your source codes
//your code here
Offline sonic05
« Reply #5 on: October 03, 2010, 09:13:19 PM »
sorry po newbie lang po aq...
Offline sonic05
« Reply #6 on: October 03, 2010, 09:20:19 PM »
d po kc sya gumagana sa ISIS po eh in actual lang po talaga d q po alam kung bakit and ang gamit ko pong crystal ay TIC 4.000D po
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #7 on: October 03, 2010, 09:45:15 PM »
dun sa inupload mong original diagram,
gumamit sila ng 6.5536MHz xtal, kaya nakakagenereate sila ng accurate ng clock source.
hindi magandang alternative yang ginagamit mong crystal na 4MHz.
Offline sonic05
« Reply #8 on: October 03, 2010, 10:05:23 PM »
pero tama naman po ung bilis ng second nya...please help naman po sa pag build ng clock with stopwatch...
Offline sonic05
« Reply #9 on: October 04, 2010, 06:35:12 PM »
[ code]...[/ code ]
testing
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #10 on: October 04, 2010, 08:33:03 PM »
^ remove the "spaces" :)
