Author Topic: Leach Low TIM Amplifier V4.5  (Read 32311 times)
Offline abeTIR
  • Pogi/Ganda Points: 96
  • the show must go on...
Re: Leach Low TIM Amplifier V4.5
« Reply #580 on: May 31, 2012, 03:00:57 PM »
nice work sis!, akmang-akma sa heatsink a', how was the sound nung tone amp? nakumpleto mo na rin pala...
- The Method of DePalma
Offline jlester87
  • Pogi/Ganda Points: 74
« Reply #581 on: May 31, 2012, 03:04:49 PM »
Tnx uli! Update ko lang >>> nakabili na ako ng heatsink 4.5" x 12" halagang P200.
sa deeco mo ba sir binili? 165 lang kasi dati bili ko dyan..
Offline pEN DoTA
« Reply #582 on: May 31, 2012, 03:58:07 PM »
Tnx uli! Update ko lang >>> nakabili na ako ng heatsink 4.5" x 12" halagang P200. At last na testing
ko na rin. Ok nga itong amp na ito malinis ngang tumunog at pag moderate lang ang sound hindi halos
mag init ang power trannies. I temporary used 2 pairs muna for testing at binabad ko na ng mahigit
3hrs na tumutunog with 12"/200W woofer, ok naman lahat no trouble found.
HeatSink 4.5 x 12 inches
Positioning power output Tr
Actual testing, temporarily with just 2pairs of power Tr.
4 pieces of 1N4007 in series to form a Thermal Sensor installed at the center part of H.Z.
With my diy tone control.
wow! very nice yung diy mo sis.
+1 pa rin :) 58 ka na
GOD LOVES YOU
Offline Pinoy_Tech
  • Pogi/Ganda Points: 180
    • My YT-Channel
« Reply #583 on: May 31, 2012, 04:31:59 PM »
Ok naman sis. Lalo pang gumanda ng ikabit ko pa yung isa ko pang tone control na may mic-echo & audio mix. Lumalakublob na nga dito kaso di ko mataasan ang volume baka mabato na ako ng kapitbahay. Maganda naman yung tunog buong-buo.
Bali ang setting ko now is >>> CD player > tone control with mic & echo na may mid-range > then yung cute na tone control tapos Leach amp. Either of the two ang isagad ko ang volume setting tapos control sa isang volume ng tone control, wala namang distortion. Since morning gumagana na ito ng moderate volume level, (pero kung masilan ang kapit bahay ko baka binato na ako) di ko makitahan na nag-iinit ang power output stage ng amp.
Offline Pinoy_Tech
    • My YT-Channel
« Reply #584 on: May 31, 2012, 04:36:15 PM »
Bali sa Lionco ko nabili (deeco rin naman yun). Ang aga ko nga dun as early as 7:30am nung Tuesday, after 8:30 pala sila nagbubukas  ;D . P200 bili ko pero sa tantya ko tumaas ang price dahil mas mabigat sya kesa dati or nanibago lang ako.
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #585 on: May 31, 2012, 10:57:54 PM »
@pinoy_tech
+1 sir , nice DIY :)
Offline abeTIR
« Reply #586 on: June 01, 2012, 08:15:57 AM »
Good to hear that sis, makapangalap na nga rin ng mga piyesa dun sa build ko... ;D Impressive din ang protective circuit nian (VI limiter) safe-na-safe ang mga power output. Yung build ko na-overload ko dati pero biglang cut-off kagad ang signal, kala ko nga sunog speakers kase endi na tumunog pero nag-reset lang pala yung amp after powering off and on, hataw uli... ;D
Offline Pinoy_Tech
    • My YT-Channel
« Reply #587 on: June 01, 2012, 09:26:52 PM »
Complete assembly na. Ran the whole day today, not found any abnormalities, very worth to build  ;) .
Bottom view with my diskarte sa thermal sensor.
Complete Ass'y.
DC offset 3.6mV
Offline Pinoy_Tech
    • My YT-Channel
« Reply #588 on: June 01, 2012, 09:32:54 PM »
Sir pendota & mund24 thanks sa pnts.
Offline jlester87
« Reply #589 on: June 01, 2012, 09:44:52 PM »
ilan po bias current niyan sir? kaya po ba ng heatsink? thanks
Offline pEN DoTA
« Reply #590 on: June 01, 2012, 09:46:59 PM »
ang ganda ng pagkagawa mo sis, lalo na sa pcb mo. ano gamit mo sis sa pcb layout plantsa method po ba? ???
GOD LOVES YOU
Offline Pinoy_Tech
    • My YT-Channel
« Reply #591 on: June 01, 2012, 10:47:52 PM »
Wala akong dummy load na heavy to test and say na kaya ng heatsink pero sa load kong 200W/12"/8Ω with two mid range & 1 tweeter, tenesting kong paandarin maghapon kanina, sa observation ko di man lang nilagnat yung heatsink...
Idle current, wala akong dig ammeter to measure DC current pero I'm sure very normal ito kasi sinubukan kong i run ng matagal ng walang input signal at di rin man lang nilandang yung power trannies. My base bias voltage setting on power Tr's without input signal & load is about 0.45VDC. Almost identical for both NPN/PNP with respect to output terminal. I can reduce some more without hearing any distortion at the speaker during very low level setting of volume control but I keep it as 0.45VDC because I know thermal servo circuit will take care of it in case of gradual changes of temperature. My VR adjustment almost below 1/3 part of the entire adjustment (clockwise). Center voltage is almost identical with just about 3~4mV potential difference.
Offline Pinoy_Tech
    • My YT-Channel
« Reply #592 on: June 01, 2012, 10:51:45 PM »
Oo plantsa lang sir pero nakakapili ako ng magandang klase ng toner, di kasi lahat pwede.
Offline pEN DoTA
« Reply #593 on: June 01, 2012, 10:57:09 PM »
anong klase ng paper ginamit mo sis?
GOD LOVES YOU
Offline Pinoy_Tech
    • My YT-Channel
« Reply #594 on: June 01, 2012, 11:57:57 PM »
Glossy magazine lang sis, yung tipong madaling natunaw pag ibinabad sa tubig. Di maganda yung manipis at sobrang makintab. Marami yan parang brochure ang dating. May nabili dati yung kapatid ko sa National B/S parang ordinary plane paper lang pero di naman ordinary at swak sya sa toner making pcb method, di ko lang alam yung tatak ng cover. Bale nakapasok sya sa isang case na ang laman siguro ay nasa 20 to 50sheets.
Offline t68kv
« Reply #595 on: June 02, 2012, 02:41:26 AM »
@Pinoy Tech
Ganda sir +1
Sana makita pa kung anong brand yung gamit nyong paper sa plantsa method hehe.
Offline ricdelros
  • Pogi/Ganda Points: 68
« Reply #596 on: June 02, 2012, 08:42:52 PM »
Best paper to use is "STAPLES" brand..Photo Basic Gloss Paper..
Offline mund24
  • Certified Boy'z
« Reply #597 on: June 02, 2012, 10:26:21 PM »
Complete assembly na. Ran the whole day today, not found any abnormalities, very worth to build   .
ganyan ang tunay na pinoy madiskarte  ;)
Offline ricdelros
« Reply #598 on: June 02, 2012, 10:34:33 PM »
Tama rin yung sinasabi ni pinoy_tech Glossy magazine page din ang gamit ko...careful lang sa printing (powder ink printer) baka kumulubot at masunog ang papel at masira printer, baka mag bayad pa kayo sa sa internet shop.
Offline pEN DoTA
« Reply #599 on: June 04, 2012, 03:13:37 PM »
balak kung mag assemble ng leach amp., sa ngayon collect at ipon muna na mga components.
at ito  yung gagamitin kung heatsink galing junk shop
dami ko ng heatsink at ang kapal pa nito,. nadaana ko lang sa junk shop, bale P100 yung lahat. :) :)
GOD LOVES YOU
