Author Topic: Symmetric Power Supply without CT Transformer for amplifiers  (Read 591 times)
  • Pogi/Ganda Points: 316
« on: October 14, 2010, 10:15:12 PM »
Offline labgruppen
  • Pogi/Ganda Points: 87
Re: Symmetric Power Supply without CT Transformer for amplifiers
« Reply #1 on: October 14, 2010, 10:32:41 PM »
pwede din, kaya lang magiging half-wave na lang effectively bawat rail which means much more capacitance is needed para sa mga filter capacitors.
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
« Reply #2 on: October 14, 2010, 11:16:43 PM »
There is another way at looking at the circuit- a voltage doubler.
The circuit will definitely work, albeit, at low current applications only. Large output current will require proportionately large capacitors. Mas OK pa rin ang center tapped pag medyo malaki ang current na kailangan mo. ;)
Offline danny
  • Pogi/Ganda Points: 323
« Reply #3 on: October 14, 2010, 11:21:17 PM »
just to add on to that, make sure to
use a nice low ESR caps  :)
danny
Offline rommelpm
  • Pogi/Ganda Points: 13
  • learning is a continuous process...
« Reply #4 on: October 15, 2010, 04:18:11 AM »
« Reply #5 on: October 15, 2010, 07:01:15 AM »
thanks po ng marami :)
kala ko di pede heheheheh,baka sumabog na namn IC :D
  • Pogi/Ganda Points: 524
« Reply #6 on: October 15, 2010, 08:22:35 AM »
pwede po ba ito?
http://img63.imageshack.us/i/72015130.jpg/
the full-wave bridge rectifier with center tapped transformer is actually 2 voltage doublers combined.....this is obvious upon inspection...
this is a full wave rectifier, meaning that current flows thru the transformer secondary for the full 360 degrees....
