Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Analog and Mixed Signal
Electrical Circuits and Devices
(Moderators:
marcelino
DyoodekS
Symmetric Power Supply without CT Transformer for amplifiers
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Symmetric Power Supply without CT Transformer for amplifiers (Read 587 times)
Disabled
Solar Power Satellite
Pogi/Ganda Points: 315
on:
October 14, 2010, 10:15:12 PM »
pwede po ba ito?
http://img63.imageshack.us/i/72015130.jpg/
Logged
on:
labgruppen
Lead Acid Battery
Pogi/Ganda Points: 87
Re: Symmetric Power Supply without CT Transformer for amplifiers
Reply #1 on:
October 14, 2010, 10:32:41 PM »
pwede din, kaya lang magiging half-wave na lang effectively bawat rail which means much more capacitance is needed para sa mga filter capacitors.
Logged
Reply #1 on:
Born2BeWired
Technical People
Diesel Generator
Pogi/Ganda Points: 168
Gender:
Analog and Precision Circuits Junkie
Reply #2 on:
October 14, 2010, 11:16:43 PM »
There is another way at looking at the circuit- a voltage doubler.
The circuit will definitely work, albeit, at low current applications only. Large output current will require proportionately large capacitors. Mas OK pa rin ang center tapped pag medyo malaki ang current na kailangan mo.
Logged
Electronics <- Once you got a taste of it, you will never get enough.
Insanity <- Doing the same thing, expecting different results.
"The more I learn, the more I am humbled."
Reply #2 on:
danny
Technical People
Pogi/Ganda Points: 323
Gender:
Reply #3 on:
October 14, 2010, 11:21:17 PM »
just to add on to that, make sure to
use a nice low ESR caps
Logged
danny
Reply #3 on:
rommelpm
Size C Battery
Pogi/Ganda Points: 13
Gender:
learning is a continuous process...
Reply #4 on:
October 15, 2010, 04:18:11 AM »
Quote from: hengilbert on October 14, 2010, 10:15:12 PM
pwede po ba ito?
Yup, naka gamit na ako nyan.
Logged
Reply #4 on:
Disabled
Reply #5 on:
October 15, 2010, 07:01:15 AM »
thanks po ng marami
kala ko di pede heheheheh,baka sumabog na namn IC
Logged
tony
Technical People
Pogi/Ganda Points: 519
Gender:
leach amp afficionado
Reply #6 on:
October 15, 2010, 08:22:35 AM »
pwede po ba ito?
the full-wave bridge rectifier with center tapped transformer is actually 2 voltage doublers combined.....this is obvious upon inspection...
this is a full wave rectifier, meaning that current flows thru the transformer secondary for the full 360 degrees....
Logged
http://www.diyaudio.com/forums/power-supplies/191730-tonys-latest-traffo-diy-build-10.html
Reply #6 on:
Print
Pages: [
1
Go Up
« previous
next »
(Moderators:
marcelino
DyoodekS
