Author Topic: Sakura amplifier (right channel output damage)  (Read 1008 times)
Offline edtechph
  • Pogi/Ganda Points: 15
« on: October 18, 2010, 05:48:43 PM »
Patulong mga sir basag kasi tunog ng kabilang channel ng amplifier. nacheck na lahat ng transistor ok naman. anu kaya posibleng problem nito.
Offline sundyhips
  • Pogi/Ganda Points: 5
  • E=MC2
Re: Sakura amplifier (right channel output damage)
« Reply #1 on: October 18, 2010, 05:54:33 PM »
sis check u tone control ic yong 8 pin cya dyan sa tone control section,replade u nalng tatlo yan cya or dalawa ic,naka trouble na ako ng ganyan,
I believe that it's in our failures that we learn the most.
Offline Roland
  • I always compete to myself
« Reply #2 on: October 18, 2010, 08:34:58 PM »
hang mo input ng amp section at direkta mo po syang pasikan ng audio source, kung basag pa rin nasa amp section ang problema(forget the tone and preamp section)
Kung nsa amp ang problema, check agad transistors and resistors, hang at least isang paa para di ka maloko ng tester. If sa tingin mo ok lahat ito agad ang tanong mo:
ilan  dc offset? how many volts  in the base of the drivers? ilan  standby current ng mga output trannys? how many volts in the emitter of deffrentials?
Offline edtechph
« Reply #3 on: October 19, 2010, 08:16:11 PM »
nacheck na po namin yung mga transistor sa amp kasi dinirekta namin yung input and disconnect yung tone and preamp. yung lang voltage di pa, anu po ba usual voltage ng mga yan? compare ko na lang sa other channel. thanks mga sis.
Offline Roland
« Reply #4 on: October 19, 2010, 09:19:12 PM »
better compare.
Offline Roland
« Reply #5 on: November 01, 2010, 02:56:01 PM »
ano na nangyari sir? umusok na ba? :D
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #6 on: November 01, 2010, 03:07:32 PM »
:D :D :D
WootsPC2 Videos  Woots Page
Offline jiggins20
« Reply #7 on: November 01, 2010, 05:42:41 PM »
kung basag ang tunog at di mo maitodo ung volume....pm mo ako...
Audio amp addict
Offline edtechph
« Reply #8 on: November 01, 2010, 06:42:56 PM »
di ko pa maasikaso bc pa po sa dami gawa. post ko po pag ok na. pag mahina ok naman pag itinaas yun nga basag.
Offline edtechph
« Reply #9 on: November 03, 2010, 07:24:47 PM »
ok na amp isang resistor lang nakuha ko open sya. thanks sa lahat ng nagsuggest pogi points  roland and jiggins20.
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #10 on: November 03, 2010, 07:33:45 PM »
ang galing naman
sana may magturo dito papano magtroubleshoot ng ampli
Offline Roland
« Reply #11 on: November 03, 2010, 08:51:52 PM »
galing mo naman sir
 salamat sa points
normal lang yan sa sakura at konzert masira yong mga maliit na resistors lalo na yong emiiter resistor ng drivers. syado kasing tipid pagkagawa tapos abusado ang gumagamit. sabagay mura lang naman ang sakura.
ang galing naman
calling master danny....
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #12 on: November 04, 2010, 07:23:01 AM »
congrats sis sana may mgpost na mga master troubleshootiung ng amp.para aware tayo lahat...
