Author Topic: Help po,. Sharp 20v-L80M (standby only when power on)  (Read 4229 times)
Offline nid4speed
« on: October 21, 2010, 11:26:01 AM »
Mga master, pahelp naman oh. Pag power standby red led indicator lang... Saan po kaya problema nito?
Offline pEN DoTA
  • Pogi/Ganda Points: 187
Re: Help po,. Sharp 20v-L80M (standby only when power on)
« Reply #1 on: October 21, 2010, 12:06:46 PM »
mag resolder ka tapos voltage measurement ka sa P.S section at B+
GOD LOVES YOU
Offline nid4speed
« Reply #2 on: October 21, 2010, 12:24:08 PM »
Thanks sir,. Ok naman po ang b+ plus.. Sir may 2 pcs ng resistor palagay change value na..
>R47J = ang reading nya 1.9ohms nlang
>R472= ang reading ay 4.5K ohms
kulay gray ang resistor na prnted ang value.. Ung ibang may sign ng ohms pero etong dalawa ay wla.. Dapat ko na bang palitan toh mga sir?
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #3 on: October 21, 2010, 12:25:29 PM »
agree check B+ if present,focus on PS first,check reg ic and other peripherals.
Offline Triple_D
« Reply #4 on: October 21, 2010, 12:27:21 PM »
ilang volts ang nasukat mo at saan ka nagmeasure?
Offline nid4speed
« Reply #5 on: October 21, 2010, 01:22:49 PM »
>181vdc sa + ng primary cap.
>131vdc sa colector ng h0t.
>131vdc sa 2pcs 2ndary caps..
>4vdc sa remoc0n reciever..  May problema po kaya ako sa ps?
Offline nid4speed
« Reply #6 on: October 21, 2010, 01:31:10 PM »
Mga ung mga resistor? Change value nb cla? Eto loc nila sa board r616 at r620.. Makaka apekto ba ung sa pag power ng unit?? Ang layo kasi value eh.. Tia
Offline Mr Vin River
« Reply #7 on: October 21, 2010, 01:56:25 PM »
mga master baka may idea kayo sa trouble sharp tv, 20v-L70m, good sounds but no raster, mataas supply ng RGB cathode 175v, na chk ko na abl res, at crt socket. tda9387ps/ jungle.
Offline techies
  • Pogi/Ganda Points: 7
« Reply #8 on: October 21, 2010, 02:25:10 PM »
sis river gwa k n lng ng bgong thread pra mpnsin k ng mga master kc nhhijack mo c ts bkka mlito mga master..
ONE FOR ALL ........ALL FOR ONE
Offline nid4speed
« Reply #9 on: October 21, 2010, 05:05:07 PM »
Up ko lang mga sir.. Kindly post yous advice.. Wla pa update sa unit..
Offline Triple_D
« Reply #10 on: October 21, 2010, 05:26:48 PM »
replace mo muna yong mga resistor na sinasabi mo na change value,ok ba ang HOT mo?
Offline Roland
  • I always compete to myself
« Reply #11 on: October 21, 2010, 08:02:30 PM »
may B+ ka at may 5 volts ka, hindi cguro nagtrigger system ic mo. Pagpindut mo power button check mo daw ang pin#4 ng ic601 kung may boltahe kang masukat.
Offline nid4speed
« Reply #12 on: October 22, 2010, 11:42:08 AM »
  _IC601(KIA 7808A) sis ay 3pin lang..
  • Pogi/Ganda Points: 237
« Reply #13 on: October 22, 2010, 12:08:02 PM »
check supply ng jungle ic
Offline nid4speed
« Reply #14 on: October 22, 2010, 12:20:43 PM »
90vdc nlang ang nasusukat ko sa colector ng h0t.. Nag gr0und ako(-) ng primary cap.. Tama ba pag check ko?
Offline nid4speed
« Reply #15 on: October 22, 2010, 12:22:38 PM »
« Reply #16 on: October 22, 2010, 12:29:36 PM »
sis.. kung mag susukat ng voltages sa secondary ng chopper dapat ang grnd reference mo ay nasa secondary rin ng chopper doon ka mag ground sa may palibot ng tube. kung sa primary naman doon ka sa Negative ng malaking capacitor.
Offline sirjon
  • Pogi/Ganda Points: 133
« Reply #17 on: October 22, 2010, 01:16:55 PM »
Check mo muna kung me horiz. oscillation ka. Kung me B+ ka sa collector ng H-out at tingin mo eh normal voltage as indicated sa diag., set mo yung tester mo sa ac voltage, x1000 ACV para di masira tester mo, dapat more than 300 ac voltage. around 700v. ac, indicates there is high-voltage coming out from the jungle ic. Pag wala, baka naka hold-down ka, me nadedect na mali system ic. Check +5DC volts, dun sa 3 paa ng IR receiver ka magsukat para di mo na tine-trace 5 DCvolts line.
Offline Roland
« Reply #18 on: October 22, 2010, 01:35:42 PM »
iba pala schem ko.
try mo nalang tanggalin ang eprom tapos power on mo kung gagana. kung hindi, post mo system at jungle baka may kapareho sa mga collection ng mga masters.
Offline nid4speed
« Reply #19 on: October 22, 2010, 02:20:14 PM »
May 5vdc naman sya sir..
>eeprom nya ay surface m0unt
>ic nya Ang daming numbers eh post ko lahat isang ic lang toh sis..
TDA9387PS/N2/3i1154
cc4474
k3k052
IX3564CEN4
sino may diagram mga master pashare po @ nid4speed_1107@yahoo.com
