Author Topic: vacuum tube advantages in power amps  (Read 2077 times)
Offline gorex
  • Pogi/Ganda Points: 47
Re: vacuum tube advantages in power amps
« Reply #20 on: April 09, 2012, 10:53:17 PM »
Mga SIR sabi ng lolo ko yung vacuum tubes daw na audio amplifier yun daw ang first tinatawag na HI FI. kasi me Grundig daw sila dati na ampllifier na vacuum tubes. during the 60s daw yun. yung mga Phono ang ginagamit nila at 45 na plaka at vinyl LPs. maganda daw ang tunog nun. para daw magic sa ears niya...my lolo is 77 years old na...music nila dati nat king cole at platters.. :) ;) :D ;D
Offline efren
  • Pogi/Ganda Points: 211
  • old school audio fanatic
« Reply #21 on: April 09, 2012, 11:10:50 PM »
you have to listen yourself to a real tube amp para mawala ang "daw", which is synonymous with doubt ;D ;)
"just keep 'em glowing"
Offline gorex
« Reply #22 on: April 09, 2012, 11:26:46 PM »
Sir sa electric guitar na amps lang ako naka kinig ng tube amps. yung  marshall amps.na try ko din kasi during sa school program dati local band na member ako as a guitarist.mga 17 pa ako nun. two years ago. sa audio amp yung me music naka play na cd wala pa talaga kaya gusto ko makarinig ng tube amps. tinanong ko kasi lolo ko kanina sabi niya maganda talaga sound ng tube amplifier. pag umi init ang tubes lalong gumaganda ang music.lalo na sa boses ni nat king cole ;)
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 138
  • Make it simple
« Reply #23 on: April 10, 2012, 12:42:16 AM »
Playing a piano oftentimes uses two same notes/keys where one is one octave higher than the other. And this sounds good. And this is what is produced by second order distortion that tube amps produce. A warm sound.
Maybe this is where the magic comes. Same with orchestra voices, same notes, and the blending sounds good.
Offline danny
  • Pogi/Ganda Points: 324
« Reply #24 on: April 10, 2012, 02:56:01 AM »
tsk tsk
no comment
walang katapusan iyan
danny
Offline ricdelros
  • Pogi/Ganda Points: 73
« Reply #25 on: April 10, 2012, 08:23:07 AM »
...and add to that the emotion an artist or singer projected towards the listener, it cannot be heard , it is rather felt, others call this character of tube sound "palpable presence" :)
That's True, even when you're listening to Tube FM radio, you have a feeling that the DJ is infront of you.
Offline ricdelros
« Reply #26 on: April 10, 2012, 08:38:58 AM »
< Some Tube Sounds Expressions >
..."Tube Sounds Natural"
..."Great Valve Tone"
..."Soft and Mild Sound"
..."Warm, rich and relaxed"
...Soft Ceiling in Dynamic range.
...Full and Airy Sound.
...Midrange Clarity and Fatness.
...A Sound that rings "true" when you hear music through it.
..."Sounds Fantastic"
..."Liquid Smooth"
..."Robust"
..."Musical"
...The Sound of the Music itself.
...Expanded musical Beauty.
..."Tube seem every bit as lifelike"
  • Pogi/Ganda Points: 540
« Reply #27 on: April 10, 2012, 10:21:08 AM »
ako naman, i keep an open mind wrt to how tube sounds.....i let the listener decide.....i am into tubes mainly because i can....... :D :D :D
Offline gorex
« Reply #28 on: April 10, 2012, 10:56:41 AM »
The magical glow of the tube cast a spell on you... ;)
« Reply #29 on: April 10, 2012, 11:14:11 AM »
^totoo yan, "fire in a bottle".............
Offline abeTIR
  • Pogi/Ganda Points: 104
  • the show must go on...
« Reply #30 on: April 10, 2012, 12:41:55 PM »
Hmm..title states "advantages" nice to hear adjective praises for the tubes  ;D
Ilan sa mga nag-comment ang nasa 20 below age bracket?...ahehe joke lang po  ;D
I, also kept on wondering why tubes is coming back I thought it was being displaced by "less is more" tech.
I only see one heck of a reason as an advantage, "popularity". When it's popular it's in demand...just a thought though... :D
- The Method of DePalma
Offline gorex
« Reply #31 on: April 10, 2012, 12:45:45 PM »
reminiscing...
  while listening to its wonderful sound...
  colorful memories flashes back...
  its radiance brings sweet nostalgic moments...
  wishing a never ending happiness...
  And that is magical...  ;)
Offline efren
« Reply #32 on: April 10, 2012, 01:01:30 PM »
tsk tsk
no comment
..and probably will not settle down in the near future  ::)
if you're 20 below, tube is a complete alien thing ;D
perhaps there is a reason why it is popular, objective listening is the key, sir tony was right, after you listen you decide, then perhaps a more in depth reason for the "popularity" thing :)
reminiscing...
when i want to travel back in time, i just let my triode SE glow for about 10 seconds, switched on the B+, select "Remember When" by the Platters, sit back & close my eyes 8), who needs time machine anyway.... ;D
Offline Tukkar
  • Pogi/Ganda Points: 27
« Reply #33 on: April 10, 2012, 01:41:08 PM »
Tubes are more forgiving that solid state devices, once i accidentally put a 12vac heater voltage on a 6.3vac heater and after noticing that it really has a bright glow i power it off then check the wiring then put proper voltages and its still works nicely.
I like the tube glows.....especially the bluish ones...but some put a blue LED on base to imitate blue glow...
Offline efren
« Reply #34 on: April 10, 2012, 01:47:11 PM »
isa ako dito ah ;D ;D eventually i realized it destroys the vintage aspect, so i removed it ;)
Offline gorex
« Reply #35 on: April 10, 2012, 02:13:40 PM »
Mga sir na try ko na yan sa marshall amps. a guitar tube amps. pag switch ko ng distortion sa guitar effects wow andun na yung magic na warm sound im using korg g3 guitar effects at  KORG pandoras bOX.  STONE TEMPLE PILOT's song PLUSH. puwde din yung Born to be wild ni stephen wolf.1968 song and at a lot of alternative songs i like 90's music like dishwalla band.vertical horizon. di ko masyado type hip hop. :) ;) :D ;D
Offline ricdelros
« Reply #36 on: April 11, 2012, 09:08:53 AM »
Try mo Frank Sinatra...He will be infront of you.Hahaha!
Offline gorex
« Reply #37 on: April 11, 2012, 09:38:15 AM »
yung frank sinatra with jobim hehehe!
Offline efren
« Reply #38 on: April 11, 2012, 10:59:04 AM »
guitar amps & high fidelity amps are two worlds apart...
« Reply #39 on: April 11, 2012, 11:03:08 AM »
^and design considerations are entirely different.....in hifi amps, distortion is minimized, in guitar amps, distortion is encouraged and desired....
