Author Topic: TLC Vertical Problem TCL-14175  (Read 2249 times)
Offline SCOTT
« on: October 31, 2010, 11:05:45 AM »
Hi guys, Help po nagpalit na ko ng vertical IC  and some discrete components(C302,C301) sa vertical side pero ganun pa rin. Present naman yung +/-14V and 2.2Vsa Vref pin nya...Is it possible na sira yung IC na nabili ko?  Post ko sana yung pix dito kaso, I'm not allowed to post Links... Haysss... Thanks po!
Offline enriz622
  • Pogi/Ganda Points: 304
Re: TLC Vertical Problem TCL-14175
« Reply #1 on: October 31, 2010, 11:22:52 AM »
ano problema ng vertical mo sis guhit lang ba? or kulang sa height  more info po
Offline SCOTT
« Reply #2 on: October 31, 2010, 11:41:47 AM »
Yes sir kulang sa height and may horizontal traces on top... Pano ko po ba mapo-post yung Pix dito?
Offline enriz622
« Reply #3 on: October 31, 2010, 11:55:03 AM »
upload mo sa photobucket.com at kunin ang link or post ang pic andoon naman ang instruction kung paano
Offline SCOTT
« Reply #4 on: October 31, 2010, 12:25:21 PM »
  Eto po yung Pix.
Offline NORTH LUZON
  • Pogi/Ganda Points: 834
« Reply #5 on: October 31, 2010, 12:26:57 PM »
new model ba to?
ndi pa kasi ako nakakabukas ng ganyang unit
Offline SCOTT
« Reply #6 on: October 31, 2010, 12:27:23 PM »
Ty po na upload ko na...
Offline SCOTT
« Reply #7 on: October 31, 2010, 12:38:34 PM »
new model ba to?
No idea sir...
Offline enriz622
« Reply #8 on: October 31, 2010, 12:47:42 PM »
napalitan mo na ba ang rectifier ng vertical ic sis baka may leak na,buti di nagshashutdown yan ganyan na ang itsura
Offline enriz622
« Reply #9 on: October 31, 2010, 12:59:14 PM »
parang sa service mode ata yan, hintay natin si sir master bobbie
Offline SCOTT
« Reply #10 on: October 31, 2010, 01:13:22 PM »
Sir Enriz622... Look at this... after replacing the Diode... I never suspected it , tinanggal ko na yun and tested it OK naman, yun pala sya ang culprit....oh Yeah!..Thanks to you and to electronics lab...  ^__^
Offline NORTH LUZON
« Reply #11 on: October 31, 2010, 08:41:25 PM »
hehehehehe
kung diode nga yan bakit may nasukat ang ts na +- 14vdc?
fiesta na ng patay bukas
Offline bobbie
  • Pogi/Ganda Points: 63
« Reply #12 on: November 02, 2010, 10:37:33 AM »
CONGRATS @TS SCOT......
DIODE talaga yan, buo siya pag na tester mo siya maski naka hang up.... sa analog tester, pag sinukat mo ang voltahe ay hindi mo mapapansin na babagsak ang voltahe mo pagtawid ng ANODE niya ( o CATHODE ba yun), pero if you are using a digital tester, BE AWARE sa voltage drop niya, dapat 14VDC siya, pagtawid niya sa kabilang side e below 13VDC  siya, minsan 10 Vdc na lang...
Offline Roland
  • I always compete to myself
« Reply #13 on: November 02, 2010, 12:20:28 PM »
  Eto po yung Pix.
master kagawad at master bobbie di ba humming to?
Offline bobbie
« Reply #14 on: November 02, 2010, 12:59:21 PM »
humming??? ang alam ko jan sa vertical ang problema niya, kadalasan yung diode talaga yan sis
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #15 on: November 02, 2010, 02:53:54 PM »
congrats sis pakape ka na.
Offline enriz622
« Reply #16 on: November 02, 2010, 03:16:21 PM »
congratz sis :) madalas kasi ako maka experience ng ganyang scenario kaya ko nabanggit ang diode
Online m@r
  • Pogi/Ganda Points: 76
« Reply #17 on: November 02, 2010, 03:25:26 PM »
galing talaga ng mga master...  :D
Offline Roland
« Reply #18 on: November 02, 2010, 06:02:34 PM »
i mean humming sa vertical.
Kung sa audio amplifier maririnig mo yong "mmmmmmmmmmmmmmmmm" ;D
Offline SCOTT
« Reply #19 on: November 02, 2010, 06:46:06 PM »
hehehehehe
May Tama ka sir kasi nawawala yung +14VDc sa internal power amplifier ckt nung STV9302 twing magloloko yung Rectifier. I'll post yung schematic ng Vertical ckt and also yung internal ckt blk diagram nung STV9302 later para maliwanag..^__^
Again Thank ulit sa mga Masters specially kay SisEnriz622. ^__^
