Author Topic: Serial Port (PC) and Serial Cable loopback  (Read 1690 times)
Offline Winterburn
« on: April 24, 2008, 08:01:30 PM »
Gusto ko sana itest kung may continuity yung bagong bili kong serial cable para sa PIC programmer ko, mahirap na kasi, baka while testing magkaloko-loko dahil sa noise. Can I simply tie Tx and Rx ng kabilang dulo ng serial cable ko then hyperterminal para macheck kung ok siya? Hindi ba dangerous yun?
Re: Serial Port (PC) and Serial Cable loopback
« Reply #1 on: April 24, 2008, 08:15:26 PM »
ok lang yan...
« Reply #2 on: April 24, 2008, 08:28:05 PM »
I normally do that using a flat screwdriver. ;D
Offline Winterburn
« Reply #3 on: April 24, 2008, 08:44:38 PM »
Onga noh, 2 and 3 nga lang pala, magkatabi lang. Ang hirap dito sa bahay, walang kagamit-gamit. Hahaha!
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #4 on: April 24, 2008, 09:49:45 PM »
time to invest!  ;D
Offline glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« Reply #5 on: April 25, 2008, 08:14:25 AM »
actually natry ko rin yan nung monday lang, wala namang problema,and there should be no problem naman talaga,
« Reply #6 on: May 21, 2008, 10:57:16 PM »
Ok un tested kung gusto mo nman dalawa serial port tpos icross mo ung 2 and 3.
Prang mas mahirap pa ata un. he he he
