Author Topic: Micropone Problem  (Read 445 times)
Offline Warstg_20
Micropone Problem
« on: October 31, 2010, 05:23:08 PM »
mga master tulong naman po,..
Bumuli po kZ m kanina nga head set with microphone, gumagana ang head set pero mic ayaw,. try namin to sa binilihan gumagana naman,..
ang mga kinlikot ko d2 kanina ay installed ako bago driver ng sound card, tapos napansin na dpo clikable young vulume ng mic sa properties..
ito po ang mic properties,..
http://warlitobaya.blogspot.com/2010/10/problem-on-microphone.html
thanks...
http://lm-eccsc.blogspot.com/
"If YoU WeRE RiGHT No ONe's REMmeMBer, iF YOu WeRE WRoNG No ONeS FoRGet"
Micropone Problem
Offline Warstg_20
Re: Micropone Problem
« Reply #1 on: October 31, 2010, 07:00:38 PM »
 ;D
Sinsya na mga master dko po alam gawin thumbnails ang pic.. :) :) :)
« Reply #2 on: October 31, 2010, 07:11:51 PM »
minsan tamad yung  technician na ilagay yung headers sa FRONT PANEL
kung may mic in sa likuran dun mo i try... or vise versa
Offline Warstg_20
« Reply #3 on: October 31, 2010, 07:29:52 PM »
 ;D ;D
Sir na try ko na po. .
  • Pogi/Ganda Points: 414
« Reply #4 on: October 31, 2010, 07:59:43 PM »
Check mo master sa Control panel then sound and audio devices.Under volume tab tick advance on device volume(xp). Expand the synthesizer box uncheck lahat ng mute then full up all volume.
Check your mic switch if it have.Then test or use ym call feature to calibrate or test the said mic. Or some software you know.
Offline ~Q~
« Reply #5 on: November 03, 2010, 02:53:39 AM »
if hindi clickable mga options sa sound option ng control panel mo or dyan sa audio properties mo basically if nothing is clickable i suggest u re-install ur drivers but if still doesnt work... ako usually reformat katapat ko lang nyan... ahahahaha para di na ako mahirapan ^_^
