Author Topic: Sanyo tv 14" ST-14CE1V Pakatapos i On, mayamaya mamamatay going to standby cya.  (Read 3488 times)
  • Pogi/Ganda Points: 231
TS.. okay pa ba ang B+ cap nya?
  • Pogi/Ganda Points: 915
fax sent....
aba aba  unique   hah  ;D
di email email  ;D
@TS  palitan  mu  muna filter  caps  nyan.. baka palya ang kuryente mu..sundin  mu  muna ang payo ni sis ccasiser
suyud ng kunti sa vert. sect..
check the fusible path...
subukan mu din ang heater sect. ha...
Offline m@r
  • Pogi/Ganda Points: 59
makitambay lang  ;D
Offline sirjon
  • Pogi/Ganda Points: 127
aztig ahh! hahaha
pakigawa lang to kapatid
alisin muna sa heatsink ang hot ng unit
then power on mo,observe mo pag nagshutdown at kapain agad ang hot kung mainit agad ng masiguro natin saang section ang problema.
No offense sayo kakosa, di kaya masibak yung h out kasi walang heat sink?
Question lang sa nag post nito, yung SMPS ba eh kontrolado ng SysCon, meaning at half voltage lang sya kapag naka off? Kasi, kung ganun, either me na-dedetect na akala ng system ic ay malfunctioning sa other stages pero ok naman pala. Try the lines na vert and h samples going to system ic, pag wala 1 dyan, mag-o-off yan. Have you considered the IR receiver? Hang mo din...
Offline Roland
  • I always compete to myself
bago ba? :D :D :D sosyal
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
nagshushutdown in a few seconds lang daw sir sirjon eh
para malaman lang sana kung abnormal ang init ng hot b4 shutting down
Online lhan
  • Pogi/Ganda Points: 182
  • agta maloko
fax sent....
tukayo bigtym kn ngaun ha fax fax b naman hehehe, ung tinukoy u pin 72, power failure un db, ano normal voltahe nya kz pag mababa shut off cya db
Offline Roland
nakahiram kase ako ng fax machine tukayo :D :D :D
Yeah pin72 is power failure, ginagamit ng sanyo(inthis model) for monitoring the status of 24V(vcc of vert), 180v (crt circuit), vertical output pulse(via transistor), and flybcak current(via transistor).
Normal is 4 to 5 volts sya tukayo, kapag bumagsak ibig sabihin somethiong is wrong and ic will trigger the standby mode.
Kaya ginagawa ng iba ihahang nila yong dalawang diode  which totally i disagree , di dapat ihang, dapat palitan.
agreed yan nga ang power failure pin, in short jan manggagaling ang pagpasok ng signal para madeterct nya  kong may abnormalities
kaya  naman  pala... may fax machine kana
@sis Roland  fax mu nga  sa akin dito  PM ko sau ang number....
kong makakaabot  ba dito
WARNING  Long distance  po yan  ;D ;D ;D
Offline Roland
sori master ultra, pang 500 meters radius lang tong fax ko. ;D
Online lhan
  • agta maloko
tukayo dagdagan u ng umabot naman d2, paki fax naman manual ng ganyan model sa email ko kung abot din tukayo ;D ;D
Offline Roland
tukayo wala ako ganyang model,  meron ako medyo kapareho lang for refference lang.
Offline Triple_D
  • Pogi/Ganda Points: 164
sis roland baka pwede rin umabot sa cavite yan.
paki-fax din ..lynniel_1@yahoo.com
thanks in advance hehe..
Offline Roland
Offline Triple_D
thanks sis roland.+1 sayo.
Offline NORTH LUZON
nahuli ako ah
sana umabot din dito sa pangasina yan
Offline m@r
fax sent to
lynniel_1@yahoo.com
lhan_prettyboy69@yahoo.com
dexter_baja@yahoo.com
sir roland baka abot pa yang fax mo dito sa mindanao pakisend naman... marx_dc@yahoo.com thanks...
Online lhan
  • agta maloko
nahuli ako ah
nsan kinulang ata ung wire ng fax nya umikot kz ndi n dumaan jan hahahahaha,
Offline Roland
master kagz, wala akong f4cks number mo.
f4cks sent to sis marcdoctor
Offline m@r
sis roland na send mo na ba wala kasing laman fax message mo sa akin...? baka pwede mo ulit masend sir yong meron na laman... heheheh
