Author Topic: Programmer won't burn on the IC  (Read 829 times)
Offline jelly26
« on: November 09, 2010, 10:40:47 PM »
I bought an 8051 programmer in Alexan. I've been using it for a while but then the programmer won't burn on my IC. I tried a new AT89C2051 IC in case my former is damaged but still it won't burn. I tried older programs that worked before but still it didn't burn to my IC.
What could be wrong with it? Did I do anything wrong?
Thanks for the reply.
Re: Programmer won't burn on the IC
« Reply #1 on: November 10, 2010, 08:43:22 AM »
wrong... malamang wala pero kulang prolly yes.
check mo yung vcc ground and programming pins while programming. baka may issue lang.
kung ok yung voltages, then proceed ka kung may data na napasok sa programming pins nang 8051 mo.
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #2 on: November 10, 2010, 09:01:16 AM »
may issue din ako sa programmer ng alexan na nahiram ko sa officemate ko, dalawang bagong AT89C2051 succesful ang programming pagdating sa verification error, tapos pag unchecked ang verify OK, read mo yung IC parehas pagkasalpak sa LED blink circuit, parang naka tri state padin mga pins, tried it on USB to Serial and Real serial port.
Tingin ko may issue ito sa generation ng VPP, since ang kailangan para mag enter sa programming mode ay 5V muna bago itaas sa 12V. Kaso yung 12V ay kinukuha mula sa adapter mismo.
May one time lang na napagana ko nung eksaktong 12V sa DMM ko yung pinasok ko sa kanyang DC Jack
8051 stuff
« Reply #3 on: November 10, 2010, 10:13:09 AM »
@jelly, ano kaya kung gumawa ka nalang ng programmer mo...
madami sa internet. i would trust yung mga parallel-interfaced type.
Offline jelly26
« Reply #4 on: November 10, 2010, 10:07:08 PM »
Thank you po sa mga reply. :D
@ don martin: okay pa naman po yung mga pins. Wala pong data na pumapasok sa IC nung kinabit ko sa 7-segment kong ginagawa. Kahit na nung una ay gumagana pa.  :'(  Nagtry din po ako sa bagong 2051 pero ayaw parin.  :'(  :'(
@ tiktak: ganyan din po ang nangyari sakin.. Bigla nalang pong di gumana matapos ang ilang programming.  ???
@ marcelino: gusto ko din po sanang gumawa nalang ng sarili kong burner. Kaya lang baka po kasi hindi pwede ang mga nakalagay sa net para sa USB to Serial. Laptop lang po kasi ang gamit ko eh. May maisa-suggest po kaya kayong schematic para sa 8051? Sana po pwede sa at89c2051 at at89c4051?  :)
Salamat po!  ;D
Offline engineer7@home
  • Pogi/Ganda Points: 13
  • Google Search--> Noel Rios Circuit Cellar
« Reply #5 on: August 18, 2011, 04:56:26 PM »
Check mo using a scope or DMM yung Vpp Super voltage sa pin 1 ng AT89C2051 habang pinu-program.  Dapat may 12 Volts.  Check mo rin kung nag-ve-verify yung code na sa PC at code na  nasa AT89C2051 Microcontroller.
Love the Lord your God with all your heart & soul and with all your mind & strength.And love your neighbor as yourself.
The devil only comes to Kill,Steal & Destroy John 10:10
UKrobotics
Microcircuits gave me schizophrenia for Php2600/month in 1992
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #6 on: August 18, 2011, 06:25:04 PM »
nabuhay
Offline Baltazar
  • Life begins at 40...
« Reply #7 on: August 19, 2011, 06:16:02 PM »
Inquire ka sa DEP Mechatronics ( formerly Nipa Hut, same http address pa rin. ).. may 8051 programmers ang Nipa hut before so i guess meron pa rin sila under development pa lang yung site - yun nga lang , bibili ka uli ng bago  :D Pero sigurado naman yunng hardware. marami rito ang bumili doon  nang programmers especially noong nag promo sila ng Genuine PIC Kit2  ;D. I have the all-in-one for MCS-51 from them.
My life has just began... :-(
