Author Topic: E-Gizmo's Ethernet TCP/IP to Serial Shield  (Read 3730 times)
Offline LTSGü
  • Pogi/Ganda Points: 10
  • ~two things in life: RIGHT and WRONG~
Re: E-Gizmo's Ethernet TCP/IP to Serial Shield
« Reply #60 on: April 19, 2011, 03:55:02 PM »
eto na ung bigger version XD
Extremely Cute Engineer
~Craving for Knowledge~
Offline LTSGü
« Reply #61 on: April 19, 2011, 09:35:25 PM »
yung sa router ko eto mga reference ko...
http://portforward.com/english/routers/port_forwarding/Prolink/9200S/BitTorrent.htm
http://www.pixelsplasher.com/_knowledgebase/How.To.Forward.Port.Web.Server.ProLink.H9200.ADSL.Modem.Router/
http://portforward.com/english/routers/port_forwarding/Prolink/H9200/TELNET.htm
halos pareparehas lang naman sila... nalilito ako kung ano gagamitin ko ng ip address.. ang local address ng router ko is 193.168.1.3... yung sinet ko na static ip address ng ethernet module is 192.168.2.2... tapos yung public ip address eh siyempre pabago-bago.. tinitignan ko dito http://www.canyouseeme.org/
bali ang setup ko kasi eh..
computer---VB6--->globe modem---->internet---->router--->ethernet module
bali dalawang internet connection yung ginagamit ko... isang globe para sa computer tapos isang dsl nakarj45 para sa ethernet shield..
kinonfigure ko yung router kaso di ako sure kung tama ba yung ginawa ko... di ako sure kung ano ilalagay sa mga TOs and FROMs  :-[ inesting ko na bagubaguhin yung pwedeng magamit na addresses sa configurations sa router.. waley.. ayaw umikot ng mga binabato kong message...
...yung program na gamit ko sa VB eh yun padin naman.. iniiba ko lang yung remote address tsaka yung port.. ayun..
Offline LTSGü
« Reply #62 on: April 23, 2011, 01:32:54 AM »
SUCCESS!!! XD after several days of stupidity.. salamat kay kuya gigz!!! :))) alam ko na kung ano problema ko.. wahahaha pasenxa na din sa pangungulit.. di naman pala siya ganun kahirap... isa akong malaking BOBO wahaha.. SOBRANG dali lang pala nito.... kung ano2 pa pinagaaral kong technical materials..
matagal pala magloopback yung message kapag IMBA SLOW yung connection na gamit ko -.-"
basta salamat sa mga examples dito tsaka kay tita gigz ;))) igiling mo!!
« Reply #63 on: April 23, 2011, 04:44:56 AM »
malamang umikot pa nang mundo (earth) yung loop back mo.
Online glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« Reply #64 on: April 23, 2011, 10:51:41 AM »
wala akong naintindihan,hehehe,
tutorial master....
Offline LTSGü
« Reply #65 on: April 23, 2011, 12:56:14 PM »
bale ang ginawa ko lang sir glutnix eh nagportforward papunta sa ip address ng ethernet shield...
sabi nga ni tita gigz kapag nakaportforward yung router papunta dun sa ethernet shield lahat ng packets na pumapasok sa public ip address eh napupunta dun sa private ip address.. see here http://portforward.com/
iba-iba yung way ng pagpoportforward for different model ng routers...
eto yung procedures na ginawa ko..
1.kinonfigure ko muna yung ip address ng ethernet module.. through lan.. (nasa manual kung pano.. tsaka nasa tutorial ni sir seven)
2.portforward.. papunta dun sa ip ng ethernet module.. ang port na ginamit ko is port 23 for telnet...
3.make sure na yung mga ip address ng ethernet module tsaka sa computer eh hindi magcacause ng error.
(tama ba toh??  >:( ??? wahaha ;D )
4.after i-configure yung mga ip addresses.. ang hardware setup ko eh ganito:
HOST:
ISP----->router----->ethernet shield (with rx tx connected)
CLIENT:
Globetatoo----->Computer----->vb program
5.yung program ko sa vb.. ang ginagawa lang niya ay:
a.Connect sa host's IP... tapos yung port (public ip address/external ip address ng router)
yung nakikitang ip address and port dito yung kinocall ko... http://www.ipchicken.com/
b.send and receive message... tapos ididisplay lang sa textbox..
6.ayan.. ganyan po.. sana wala ako nakalimutan XD
Online glutnix_neo
« Reply #66 on: April 23, 2011, 06:19:40 PM »
thanks sa pagsummarize sir, I'll that one too...
pogi point for you...
« Reply #67 on: April 23, 2011, 06:31:21 PM »
HOST:
CLIENT:
or kung may DMZ feature ang router mo, you can enable this, just assigned the target IP.. this will open all your Ports directed sa assigned IP mo=)
so if you have:
Device IP: 192.168.1.3 - assigned port is 23
ISP IP: 222.91.204.63
enable DMZ.. assign 192.168.1.3 as its IP..
then you can access your device by:
222.91.204.63:23
where 23 is the port number:
What is DMZ?
Some home routers refer to a DMZ host. A home router DMZ host is a host on the internal network that has all ports exposed, except those ports otherwise forwarded. By definition this is not a true DMZ (Demilitarized Zone), since it alone does not separate the host from the internal network. That is, the DMZ host is able to connect to hosts on the internal network, whereas hosts within a real DMZ are prevented from connecting with the internal network by a firewall that separates them, unless the firewall permits the connection. A firewall may allow this if a host on the internal network first requests a connection to the host within the DMZ. The DMZ host provides none of the security advantages that a subnet provides and is often used as an easy method of forwarding all ports to another firewall / NAT device.
http://en.wikipedia.org/wiki/DMZ_%28computing%29
Offline LTSGü
« Reply #68 on: April 23, 2011, 07:52:42 PM »
^sige sige.. salamat!! ttry ko yan.. ;D etong sayo!!! pampagiling!!!!  ;)
@sir glutnix thanks!!!  :)
Offline LTSGü
« Reply #69 on: April 23, 2011, 09:11:40 PM »
ask lang ulit... possible kaya yung ganitong setup sa smartbro modem/router?? oh no... need namin kasi ilagay yung ethernet sa mobot...
« Reply #70 on: April 23, 2011, 10:01:37 PM »
if dynamic ang IP, consider to have ddns instead..
try dyndns.org for ddns account =)
then set this ddns in your router ;)
Offline metalChip
« Reply #71 on: December 04, 2011, 02:26:14 AM »
Mga Masters, ask ko lang po if possible po bang maglagay ng HTML web page inside E-gizmo's ATC-1000M shield using arduino. I'm a newbie po kasi and bumili po kasi nito a month ago. Iba pla ang communication nito with arduino compared to wiznet ethernet shields (which is SPI). Natry ko pa lang po kasi na program dito ay tulad po ng examples nyo dito sa thread na to which is accessing this module through telnet port 23. kaya din po kaya nito magawa ang nagagawa ng wiznet ethernet shield as a web server (with web page)? salamat po mga masters!  :)
Offline Foxshet
« Reply #72 on: January 30, 2012, 06:18:20 AM »
gumana po kaya ito wirelessly? kabitan ko siya ng wireless router?
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« Reply #73 on: January 30, 2012, 06:27:01 AM »
Yup, you can consult picuser tungkol dyan.
