Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Computer Repair (Computer Technicians Forum)
(Moderator:
dickgs
PC PSU model (chs psiv-350-1 ) 300w
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: PC PSU model (chs psiv-350-1 ) 300w (Read 679 times)
BANNEDMemberAccount
Gas Turbine
Pogi/Ganda Points: 130
You have No GOD?, You have No Peace of mind.
on:
November 23, 2010, 05:40:27 PM »
Hi po;
Ano kaya sira ng PSU na ito, Click lang tapos nde tumutuloy. solution na ginawa ko:
- pinalitan 3 na leaky capacitor
- Resoldered
Pinaghihinalaan ko baka yung PULSE WIDTH MODULATION IC dbl494 siya.
isa pa tanong nakalimutan ko kung ano yung ipagdidikit para mag-run yung psu kahit wala CPU. anong number ng pins po ba yun?
thanks
Logged
Wag HIHITHIT ng Katol para hinde Tamang Hinala Account is permanently BANNED due to Accumulation of forum rules and violations.
on:
Solar Power Satellite
Pogi/Ganda Points: 433
Re: PC PSU model (chs psiv-350-1 ) 300w
Reply #1 on:
November 23, 2010, 07:14:25 PM »
IIRC pin 14 at katabi netong ground wire. Green saka black para mapull down ground yung pin14. May marka rin minsan na PS on tapos jump mo sa ground nya.
Logged
Reply #1 on:
Reply #2 on:
November 23, 2010, 07:16:30 PM »
Ito nga pala ay sa 20pins . iba na kapag 20+4 pins na pinagsama.
Logged
Reply #2 on:
BANNEDMemberAccount
Gas Turbine
Reply #3 on:
November 23, 2010, 07:37:17 PM »
http://www.overclock.net/faqs/96712-how-jump-start-power-supply-psu.html
http://pcsupport.about.com/od/toolsofthetrade/ht/power-supply-test-multimeter.htm
sir iba ba sa atx ang CHS, sa site kasi 16 pins yung PS_ON# Green Power Supply On or hanapin ko nalang yung green wire
Logged
Reply #3 on:
Reply #4 on:
November 23, 2010, 10:28:57 PM »
Di ko maget yung meaning ng CHS mo.
Pero satin naman standard yang ganyang header. sa 20 pin, pin 14 yan bale green wire, tapos tigkabilang katabi nyan ay black wire which is com or ground niya. Pwede mo na ishort sila para mapower yung PSU ng siya lang. Kapag 24pin naman bale nadagdagan ng dalawang wire sa kada linya niya kaya papatak siya sa pin 16.
Ganito bilang nyan sa ganang akin 1 2 3 4 5 6 7 8 9 10
11 12 13 14 15 16 17 18 19 20
Karaniwan naman nyan green wire at isang black wire ang ishort.
Logged
Reply #4 on:
BANNEDMemberAccount
Gas Turbine
Reply #5 on:
November 26, 2010, 12:47:09 AM »
thnkx sir naayos na +1
Logged
tony
Technical People
Pogi/Ganda Points: 540
Gender:
leach amp afficionado
Reply #6 on:
November 26, 2010, 07:17:30 AM »
to trouble shoot that psu, you need to find out if the 5 volt standby circuit is alive...me masusukat kang ~3.5 volts sa pin 14, then kung meron yan, ishort mo yung pin 14 sa katabing black na wire, dapat mapower up sya, iikot na yung fans.....
Logged
http://www.diyaudio.com/forums/power-supplies/191730-tonys-latest-traffo-diy-build-10.html
jfar223344
Size AAA Battery
Pogi/Ganda Points: 2
Reply #7 on:
January 02, 2011, 12:19:13 AM »
Pag di naman mag popower up ano naman ang sira nito?
Logged
Reply #8 on:
January 02, 2011, 12:21:30 AM »
Marami sir dahilan yan.
Logged
Reply #8 on:
Print
Pages: [
1
Go Up
« previous
next »
(Moderator:
dickgs
