Author Topic: CNC Milling DIY ,gusto kong mag-assemble, kayo ba?  (Read 41683 times)
Offline j2sip
Re: CNC Milling DIY ,gusto kong mag-assemble, kayo ba?
« Reply #660 on: June 11, 2012, 11:46:57 AM »
napamahal pa nga kaunti kasi I opted for 3-5 days shipping... pero ok lang, ayaw ko naghihintay eh hehehe...
Nice:) Wood router din po ba yung cnc nu?
Offline kinsa
  • Pogi/Ganda Points: 12
« Reply #661 on: June 11, 2012, 11:53:07 AM »
Kung unipolar ang stepper mo, linistepper is a good choice. Halos walang ingay ang motor mo.
42
Offline j2sip
« Reply #662 on: June 11, 2012, 11:58:48 AM »
Ok daw yung linistepper pero it works best sa low amp high voltage na stepper motors. Good for cnc pcb millers but afaik mejo kulang para sa mga cnc wood routers na medium sized na.
Offline kinsa
« Reply #663 on: June 11, 2012, 12:20:06 PM »
Depende sa motor, applicable cya up to 2 amps w/o mods. Mas ok pag adjustable ang supply mo.
Para cyang linear mode na power supply instead of switchmode. Hindi cya efficient but better ang current control, so smoother ang operation ng motor.
42
Offline kinsa
« Reply #664 on: June 11, 2012, 12:27:14 PM »
Nema 32, nasa 7 amps nga :)
42
Offline j2sip
« Reply #665 on: June 11, 2012, 12:33:32 PM »
Pwedeng ganyan ang power supply para sa hobbyCNC driver pero for simplicity's sake yung 36v ay ok na. Newbie pa din kasi ako sa electronics:)
Offline JojoD818
  • Pogi/Ganda Points: 23
  • Rest when you're dead...
    • JD Labs Projects
« Reply #666 on: June 11, 2012, 04:23:09 PM »
Strictly for pcb isolation routing ang ginawa ko sir... :)
Offline JojoD818
    • JD Labs Projects
« Reply #667 on: June 11, 2012, 04:25:23 PM »
I have considered other brands pero after asking those who are really into cnc hobby they all voted Gecko hands down. Even those owning Keling 6050 types are still dreaming of using Geckos. I've learned my lesson, hindi na ako magpapatumpik-tumpik pa ulit. :D
Offline j2sip
« Reply #668 on: June 12, 2012, 01:41:12 PM »
Hehe nice one sir. PAg nag upgrade ako definitely geckos. PAhabain ko yung isang axis ng machine ko para mejo mahaba naman ang tatakbuhin pag g540 na ang driver nya hehe.
Offline JojoD818
    • JD Labs Projects
« Reply #669 on: June 12, 2012, 09:43:30 PM »
naship na siya kayapon, $437 yun g540 at 3 nema 23 stepper motors. yun shipping ang nagpamahal pero ok lang express na para mabilis makarating. yun customs na lang dito ang ewan ko... hay...
Offline j2sip
« Reply #670 on: June 13, 2012, 07:40:40 AM »
I used pobox.ph's service. Quite cheap and they ship to the provinces. What sized is your router? I think the geckos are way too much overkill for pcb routing:)
Offline kinsa
« Reply #671 on: June 13, 2012, 04:53:29 PM »
Eto yung nagawa ko na 3 axis driver na based sa linistepper:
Inside: (driver, brains, power supply)
Transistor array:
42
Offline j2sip
« Reply #672 on: June 14, 2012, 04:30:52 AM »
Ganda naman nyan sir kinsa. Baka pwedeng ishare yung circuit:)
Offline JojoD818
    • JD Labs Projects
« Reply #673 on: June 14, 2012, 12:35:08 PM »
Better overkill, I've learned my lesson already and I'm not looking back. ;D My router is a Paul Jones Engineering spindle.
Offline JojoD818
    • JD Labs Projects
« Reply #674 on: June 14, 2012, 12:37:36 PM »
very nice build sir kinsa, are you running your motors on 12V?
Offline kinsa
« Reply #675 on: June 14, 2012, 02:59:32 PM »
Salamat :)
Adjustable yung supply, 2-24. Pero 5v lang ang motor ko. Using 8v para minimal ang heat.
Combined ko lang ang 3 driver circuits but using 1 pic to drive all.
Di pa tapos ang code, tini-test ko pa yung experimental na interface to emc2. Pero working na cya using parallel port. Tsaka using subset lang ng features of linistepper kasi  limited ang io ng pic.
Yung board limited ako sa max size ng free version of eagle kaya separate yung pic. Hack lng yung layout para mapagkasya :)
42
Offline JojoD818
    • JD Labs Projects
« Reply #676 on: June 14, 2012, 06:18:20 PM »
Salamat :)
ah ok mababa lang pala ang voltage rating ng motor mo, ok yun mas mataas ng kaunti for the loses to be factored.
baka makatulong lang sir, meron dito dati post about eagle ba walang size limit. paki search and download mo na lang yun link kasi nasubukan ko yun and it works and walang size limits.
Offline kinsa
« Reply #677 on: June 14, 2012, 07:54:51 PM »
pinulot lang sa basura ang motors, hehe.
Kicad ang gamit ko ngayon, proof of concept lang talaga yung ginawa ko. Instead na perf board, quick na design ang ginawa ko. kaya nakakahiyang i-post ang board layout.  ;D
42
Offline JojoD818
    • JD Labs Projects
« Reply #678 on: June 14, 2012, 08:05:15 PM »
hahaha ako overkill na para yun mga luma motor pwede sa isa pa smaller cnc.
Kicad is also nice, nahumaling lang talaga ako sa linuxcnc kaya di na ako lumipat. ;D
Offline j2sip
« Reply #679 on: June 16, 2012, 11:18:29 AM »
I'm really lost when it comes to technical terms:)
EMC2 ba yung linuxcnc? ano mas maganda sa kanila ng mach3?
GAnda nung spindle. Ano ang ginamIt na mOtor dun?
