Author Topic: paano po ba naggegenerate ng heat ang vacuum tube?  (Read 585 times)
Offline BABIness
« on: December 12, 2010, 10:40:35 PM »
pahelp naman po.. maraming salamat po!  ;D
  • Pogi/Ganda Points: 539
Re: paano po ba naggegenerate ng heat ang vacuum tube?
« Reply #1 on: December 12, 2010, 10:50:01 PM »
the same way that incandescent and halogen lamps do, they have filaments that produces heat and light...
Offline BABIness
« Reply #2 on: December 12, 2010, 11:46:49 PM »
pano po process? thanks po =)
Offline Shey
  • Administrator
  • Pogi/Ganda Points: 154
    • Elab.PH
« Reply #3 on: December 13, 2010, 01:35:45 AM »
it's from your Physics and Circuits 1 subject -----> I2R Loss..
http://en.wikipedia.org/wiki/I2R_loss
Alone I look for the way
Hoping you are waiting for me
where the hostile world has no say
that is where I always want to be.
Where my eyes want to follow
When I'm far, far away,
When life brings me sorrow,
Into silence I escape.
hoping you are waiting for me
Where my rush of thoughts
in oblivion drowns
to forget the evil lot
I will sleep in safe arms.
« Reply #4 on: December 13, 2010, 06:39:20 AM »
just wondering, there are lots to learn about vacuum tubes, why ask this question?
anyway ang process ay convection and radiation....
Offline 01110011
  • Pogi/Ganda Points: 101
« Reply #5 on: December 10, 2011, 06:49:23 PM »
a simple example is shorting a power source using a wire diba umiinit?
ganyan din ang nangyayari sa mga tubes,incandescent bulbs at marami pa.
hindi naman mahirap intindihin kung bakit sila umiinit diba?? :)
Offline Mhavskie
  • Pogi/Ganda Points: 77
  • NeverShoutNever!
« Reply #6 on: December 10, 2011, 07:08:15 PM »
bakit kailangan ng filament/Heater? ang mga tubes
Offline motion55
  • Pogi/Ganda Points: 245
« Reply #7 on: December 10, 2011, 09:16:47 PM »
There is a second less obvious source of heat aside from the filament heater.
Electrons evaporating from the cathode are accelerated by the voltage difference between the cathode and the anode. The accelerated electrons strike the anode and this generates heat on the anode plates. The heat generated by this process is calculated from the equation:
P = V x I, where V is the voltage across the anode and the cathode and I is the anode current.
It is the same power dissipation equation that applies to transistors.
Sa cathode ray tube (CRT). the energy is given of as light instead of heat.
"Set your mind free!"
Offline iyo karpo
  • Pogi/Ganda Points: 18
« Reply #8 on: December 10, 2011, 09:51:13 PM »
. When hot, the filament releases electrons into the vacuum, a process called thermionic emission....
http://en.wikipedia.org/wiki/Vacuum_tube
