Author Topic: Multi-coin acceptor. Need your advise  (Read 258 times)
  • Pogi/Ganda Points: 53
« on: December 14, 2010, 06:19:50 AM »
Mga sir patulong po ako sa pagpili ng multi-coin acceptors yung madaling programman po at iinterface sa pc... thanks po
Re: Multi-coin acceptor. Need your advise
« Reply #1 on: December 14, 2010, 10:37:54 PM »
up! pashare po ng code panu pg program nito using vb...
« Reply #2 on: December 15, 2010, 10:19:16 PM »
up! up! up!
Meron na kong nakita CH926
here's the specs...
http://www.ziddu.com/download/12983130/CH-926_multi_coin_selector.doc.html
