Author Topic: Arduino-Based Music Synchronized Light Controller  (Read 565 times)
Offline anthonydp
  • Pogi/Ganda Points: 54
    • My Empty Blog
« on: December 21, 2010, 12:59:01 PM »
Being the Christmas season, it would be nice to decorate the house for the holidays.
So, here's a project for the holidays: an arduino-controlled midi-synchronized light controller
the code was based from the Tom Scarff's MIDI Drums to LEDs, modified to respond on the DOREMI of music instead of drums and to display it on 10-LEDs for all notes on all octaves.
The controller is 10-channel only, although nothing should stop you to increase the number of channels.
enjoy.
 NAME:                 MIDI Drums to 16 TTL Outputs
 WRITTEN BY:           TOM SCARFF
 DATE:                 12/1/2009
 FILE SAVED AS:        midi_drums_LEDS.pde
 FOR:                  Miduino ATmega168
 CLOCK:                16.00 MHz CRYSTAL
 PROGRAMME FUNCTION:  Detect midi Drum inputs and send 16 corresponding TTL outputs.
 IMPORTANT:
 The Miduino might not start if it receives data directly after a reset,
 because the bootloader thinks you want to upload a new progam.You might
 need to unplug the MIDI IN cable until the board is running your program.
 Also when programming the Miduino disconnect the MIDI IN cable.
 HARDWARE NOTE:
 The Midi IN Socket is connected to the Miduino RX through an 6N139 opto-isolator
 * To send MIDI, attach a MIDI out Female 180 Degree 5-Pin DIN socket to Arduino.
 * Socket is seen from solder tags at rear.
 * DIN-5 pinout is:                                         _______
 *    pin 2 - Gnd                                          /       \
 *    pin 4 - 220 ohm resistor to +5V                     | 1     3 |  MIDI jack
 *    pin 5 - Arduino Pin 1 (TX) via a 220 ohm resistor   |  4   5  |
 *    all other pins - unconnected                         \___2___/
// define the output pins (anthonydp: i only use 10 outputs)
#define Output0 2
#define Output1 3
#define Output2 4
#define Output3 5
#define Output4 6
#define Output5 7
#define Output6 8
#define Output7 9
#define Output8 10
#define Output9 11
//#define Output10 12
//variables setup
byte midiByte;
byte MIDIchannel = 0; //drum channel (anthonydp: channel 1, but we'll use all channels and filter channel on PC side)
byte channel;
byte status=0;
byte statusType;
byte statusTest;
byte volume_now=0;
byte volume_past=0;
byte x;
byte startTest=0;
byte runningStatus;
byte Flag;
byte LedPin = 13;   // select the pin for the LED
byte runStatusFlag=0;
byte realTimeTest;
byte count;
byte note;
byte startNoteFlag=0;
int startNote=60;
int channelTest=0;
void setup() {
  pinMode(Output0,OUTPUT);
  pinMode(Output1,OUTPUT);
  pinMode(Output2,OUTPUT);
  pinMode(Output3,OUTPUT);
  pinMode(Output4,OUTPUT);
  pinMode(Output5,OUTPUT);
  pinMode(Output6,OUTPUT);
  pinMode(Output7,OUTPUT);
  pinMode(Output8,OUTPUT);
  pinMode(Output9,OUTPUT);
  pinMode(12, INPUT);     // Program Switch
  digitalWrite(12, HIGH); // Set inputs Pull-up resistors High
  pinMode(LedPin,OUTPUT);   // declare the LED's pin as output
  for (x=1; x<=4; x++){
    digitalWrite( LedPin, HIGH );
    delay(300);
    digitalWrite( LedPin, LOW );
    delay(300);
   Serial.begin(38400);  //start serial with midi baudrate 38400 Roland MIDI
  //Serial.begin(31250);  //start serial with midi baudrate 31250
    Serial.flush();
void loop() {
  // Midi in to out
  midiThru();
//_____________________________________________________________________________________________________
// Functions:
void midiThru(){
  if (Serial.available() > 0){      //If MIDI available read the incoming MIDI byte and transmit it thru
    midiByte = Serial.read();
    digitalWrite(LedPin, HIGH);   // sets the LED on
    statusType= midiByte&0xF0;
    statusTest=midiByte&0x80;
    channel=midiByte&0x0F;
    if(statusTest==0x80){        // if midi status and NOT data
      if(midiByte>=0x80 && midiByte<=0xEF){ //if midi channel command
        runningStatus=midiByte;
      status=midiByte;
      Serial.print(status,BYTE); // transmit midi status byte
      txMidi();                   // transmit following data bytes
    if(statusTest!=0x80&&status!=0){      // if running status and NOT starting data byte
      status=runningStatus;    // insert status byte
      channel=status&0x0F;
      statusType= status&0xF0;
      Serial.print(status,BYTE); // transmit midi running status byte
      txMidi2(status);                   // transmit following data bytes
  digitalWrite(LedPin, LOW);    // sets the LED off
void readMidi(){
  while (Flag==0){
    if (Serial.available() > 0) {
      Flag=1;
  Flag=0;
void txMidi(){
  if(statusType==0xF0){
    getStatus1(status);  // complete status byte
  else if(statusType!=0xF0){
    getStatus2(status); // status with channel removed
void getStatus1(byte val){
  switch (val) {
  case 0xF0:                //Begin System Exclusive 11110000 (F0)
    while (midiByte!=0XF7){      // until End of Sysex
        Serial.print(midiByte,BYTE);
    break;
  case 0xF1:                //MIDI  Time Code 11110001 (F1)
    mididata1Tx();
    break;
  case 0xF2:             //Song Position Pointer  11110010 (F2)
    mididata2Tx();
    break;
  case 0xF3:            //Song Select  11110011 (F3)
    mididata1Tx();
    break;
  case 0xF7:           //End System Exclusive 11110111 (F7)
    break;                // single byte data
  case 0xF8:           //Timing Clock 11111000 (F8)
    // single byte data
    break;
  case 0xFA:           //Start 11111010  (FA)
    // single byte data
    break;
  case 0xFB:          //Continue 11111011 (FB)
    // single byte data
    break;
  case 0xFC:          //Stop 11111100 (FC)
    // single byte data
    break;
  case 0xFE:          //Active Sensing  11111110 (FE)
    // single byte data
    break;
  case 0xFF:         //System Reset 11111111 (FF)
    // single byte data
    break;
  default:
    break;
void getStatus2(byte val){
  val = val & 0xF0;          //remove channel info
  switch (val) {
  case 0x90:                // Note-On Event            1001bbbb (9X)
    //mididata2Tx();
    count=2;
    while (count!=0){
      readMidi();             // get midi
      realTimeTest=midiByte&0x80;   // if Real Time dont decrement count
      if (realTimeTest==0){
        //if(count==2 && channel==MIDIchannel){  //anthonydp: commented this out so we'll allow all midi channels
        if(count==2){                            //anthonydp: added this
          note=midiByte;
        //else if (count==1 && channel==MIDIchannel){    //anthonydp: commented this out so we'll allow all midi channels
        else if (count==1){
          if(midiByte==0){
            getNoteOff(note);
          else if(midiByte!=0){
            getNoteOn(note);
        count=count-1;
      }            // data byte
      Serial.print(midiByte,BYTE); // transmit midi
    break;
  case 0x80:                //Note-Off  Event          1000bbbb (8X)
    //mididata2Tx();
    count=2;
    while (count!=0){
        //if (count==2 && channel==MIDIchannel){    //anthonydp: commented this out so we'll allow all midi channels
        if (count==2){                              //anthonydp: added this
          getNoteOff(midiByte);
        count=count-1;
      }            // data byte
    break;
  case 0xA0:                //Control Polyphonic Key Pressure  1010bbbb (AX)      0kkkkkkk  0fffffff
    mididata2Tx();
    break;
  case 0xB0:                //Control Change           1011bbbb (BX)
    mididata2Tx();
    break;
  case 0xC0:                //Program Change           1100bbbb (CX)
    mididata1Tx();
    break;
  case 0xD0:                //Channel Pressure         1101bbbb (DX)
    mididata1Tx();
    break;
  case 0xE0:                //Pitch Bend               1110bbbb (EX)
    mididata2Tx();
    break;
  default:
    break;
void txMidi2(byte val){      // running status mode data 1 available already in midiByte
  switch (val) {
    //if(channel==MIDIchannel)                 //anthonydp: commented this out so we'll allow all midi channels
    {  note=midiByte;
    Serial.print(midiByte,BYTE); // transmit midi data
    // mididata1Tx();
    count=1;
    while (count!=0){
        //if (count==1 && channel==MIDIchannel){    //anthonydp: commented this out so we'll allow all midi channels
        if (count==1){
          if(midiByte==0){
            getNoteOff(note);
          if(midiByte!=0){
            getNoteOn(note);
        count=count-1;
      }            // data byte
    break;
    Serial.print(midiByte,BYTE); // transmit midi note data
    // mididata1Tx();
    count=1;
    while (count!=0){
        count=count-1;
    break;
    Serial.print(midiByte,BYTE); // transmit midi Polyphonic Key Pressure  data 1
    mididata1Tx();
    break;
    Serial.print(midiByte,BYTE); // transmit midi control data 1
    mididata1Tx();
    break;
    Serial.print(midiByte,BYTE); // transmit midi program change data
    break;
    Serial.print(midiByte,BYTE); // transmit midi channel pressure data
    break;
    Serial.print(midiByte,BYTE); // transmit midi Pitch Bend  data 1
    mididata1Tx();
    break;
  default:
    break;
void mididata2Tx()
  count=2;
  while (count!=0){
      count=count-1;
    }            // data byte
void mididata1Tx()
  count=1;
  while (count!=0){
      count=count-1;
    }            // data byte
void getNoteOn(byte var)
  byte i = var % 10;
  digitalWrite(2 + i,HIGH);    //anthonydp: we allow all notes on all octaves to be displayed on our 10 lights
void getNoteOff(byte var)
  byte i = var % 10;
  digitalWrite(2 + i,LOW);    //anthonydp: we allow all notes on all octaves
Re: Arduino-Based Music Synchronized Light Controller
« Reply #1 on: December 21, 2010, 09:49:37 PM »
Nice project huh!  ;)
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #2 on: December 21, 2010, 10:11:46 PM »
ano yung nagkiklick?  parang relay ang tunog eh.
Offline anthonydp
    • My Empty Blog
« Reply #3 on: December 21, 2010, 10:16:04 PM »
relay po yun.  i intend to use triacs and opto-triacs but budget limits me to what's on my bin.  anyway, the only disadvantage with using relays is i can't do dimming.
i used Anvil Studio on the PC side.
Follow this instruction on how to connect your USB to a MIDI interface.
For those really serious about christmas lights with music like from this video:
you may want to visit http://www.vixenlights.com/
there's lots of professional DIY stuff there, all free.
