Author Topic: Comparing Actual to Simulation PIC Programming  (Read 277 times)
Offline lloydi12345
  • Pogi/Ganda Points: 16
  • Design, Program, Pray and Compile.
    • Electronics FUN
« on: December 22, 2010, 07:35:30 AM »
Matanong ko lang kung yung simulation ay exactly the same kung iprogram na sa actual. Assuming crystal oscillator with 4Mhz(Actual)
This will be the simulation properties:
PIC on Proteus set to 4Mhz
Project setting of MikroC compiler 4Mhz XT OSC
Am I missing something to adjust?
Will the simulation be exactly the same with the actual PIC? Or not because of certain factors? Anyone confirmed this already?
Offline subzer0
  • Pogi/Ganda Points: 38
  • Garbage In Garbage Out.
Re: Comparing Actual to Simulation PIC Programming
« Reply #1 on: December 22, 2010, 10:34:07 AM »
actually sa akin wag mag rely masyado sa simulation,guide lang yan para di tedious sa madaming hardware kumbaga may possibilidad na gagana sa actual.kumbaga simulation are tools para sa paulit-ulit na gagawin.based naman sa proteus medyo malapit na din sa hardware pero sa delays wag masyado kampante,nasa computer kasi yan kapag mabagal yung computer mo don't expect na pareho yan.ang proteus pang check talaga kung gagana yung codes mo kung i-aactual mo.
Signing Off...
Offline lloydi12345
    • Electronics FUN
« Reply #2 on: December 22, 2010, 01:45:43 PM »
ganun ba? salamat! :)
Offline Mystiza
« Reply #3 on: December 26, 2010, 04:48:43 PM »
tama cya... gumagana kung panu ang flow nya pero may chance din na hindi 100% working in realtime...
« Reply #4 on: December 26, 2010, 04:53:38 PM »
^ sa simulation OK na OK lang na hindi Realtime. just watch the "actual simulated time"  ;)
