Author Topic: keypad interfacing using z8f6421  (Read 959 times)
Offline miss_kalanchuga
  • Better be better than good.
« on: December 24, 2010, 11:40:30 PM »
help naman po mga master..
im new to zilog, pano po ba maginterface ng keypad? anu po schem? meron ako nung gizmo 4x3 keypad.. and anu po yung row and column scanning? ??? nbasa ko lang din po sa isang thread.  ;) thanks po!
Offline Mystiza
Re: keypad interfacing using z8f6421
« Reply #1 on: December 26, 2010, 04:19:08 PM »
Connections of keypad contains 7 if you use 4x3. 4 rows and 3 columns or vice versa... ung tinatawag nilang scanning is just like this
Set column as your main scanning procedures(output)
Set row as your input
At time 1, the column 1(the number 1,2,3) must be ON, the rest of column is off then checking if 1 of the row received input
At time 2, the column 1(the number 4,5,6) must be ON, the rest of column is off then checking if 1 of the row received input
At time 3, the column 1(the number 7,8,9) must be ON, the rest of column is off then checking if 1 of the row received input
At time 4, the column 1(the number *,0,#) must be ON, the rest of column is off then checking if 1 of the row received input
then gumamit ka ng conditional statement na magsasabi kung anu ang napindot...
example:
if col=1 and row=1 then number=1
if col=2 and row1 then number=4
etc...
i hope maintindihan mo...
Offline Mystiza
« Reply #2 on: December 28, 2010, 09:46:42 AM »
Edit ko muna... hehehe copy paste na nga laman ginawa ko eh mali pa,, bale i2 ung tama
Set column as your main scanning procedures(let say the column is an output)
Loop:
At time 2, the column 2(the number 4,5,6) must be ON, the rest of column is off then checking if 1 of the row received input
At time 3, the column 3(the number 7,8,9) must be ON, the rest of column is off then checking if 1 of the row received input
At time 4, the column 4(the number *,0,#) must be ON, the rest of column is off then checking if 1 of the row received input
example:
Goto Loop when to scan it again
etc...
« Reply #3 on: December 28, 2010, 01:28:25 PM »
salamat sis!
Offline Mystiza
« Reply #4 on: December 29, 2010, 08:42:22 AM »
lol... boy ako....hahahaha
« Reply #5 on: December 29, 2010, 11:42:07 AM »
kaw naman kase, mystiza screen name. lol :)
Offline jeffmaster12
« Reply #6 on: December 31, 2010, 05:03:27 PM »
hi po...marunong ka na po mag keypad interfacing using z8f6421...pwd po b makahingi ng sample code kung panu paganahin ang keypad..salamt po
Offline rpsenining
« Reply #7 on: March 03, 2012, 03:35:33 PM »
mga master penge ng tips and codes panu mag interface ng 4x4 universal keypad and display terminal sa rfid at z8f6421
pleeeease :-[
Offline chrisa
« Reply #8 on: March 12, 2012, 01:25:46 PM »
