Author Topic: ps one wont boot up!  (Read 1051 times)
Offline jfar223344
« on: December 26, 2010, 12:42:10 AM »
Sir may alam po ba kayong solution panu ayusin yung di na nagboboot-up na ps one. Wala pong lumalabas na logo niya! Kasunod na modelo nung pina kaunang playstation na lumabas. Playstation then PS ONE version. Sayang din po kc kung di maayos kysa i-ju junk na lang sa haus! Thanks in advance! Meri X-mas na rin po sa inyo.
Offline jfar223344
Re: ps one wont boot up!
« Reply #1 on: December 30, 2010, 11:03:42 PM »
Dati na pong nacheck ng technician nsa fuse po ang problem nag try ng jumper di pa rin nag bo boot. Sayang din kc pag nakatambay lang kung pwede pa namang ayusin.
  • Pogi/Ganda Points: 911
« Reply #2 on: December 31, 2010, 01:00:24 AM »
anung model number ba ang PS console yan ?
Offline jfar223344
« Reply #3 on: January 01, 2011, 10:15:10 PM »
Ps One (SCPH-103C) po. May adapter na 7.5 supply.
Offline jfar223344
« Reply #4 on: January 01, 2011, 10:18:59 PM »
Dati na pong nacheck ng technician nsa fuse po ang problem nag try ng jumper as temporary di pa rin nag bo boot. Sayang din kc pag nakatambay lang kung pwede pa namang ayusin.
« Reply #5 on: January 02, 2011, 06:03:22 PM »
yan na pala  iyong maliit na PS module(portable).. anung ibig  mung sabihin na wlang  LOgo ?  black screen lng po ba ?
oh  may dispaly  pero  No Disc ang nakalagay.. ?
kong black  screen lng  baka  problemado lng ang yung AV  cord  nyu...
kong No Disc  lng ?  try  mu buksan ang CD loader nya.. tapoz  press mu  yung micro switch sa loob.. kong iikot ba ang CD
Offline jfar223344
« Reply #6 on: January 02, 2011, 06:45:15 PM »
Xencia na po wrong title ata me dapat pala di na nagpopower-up. Di n rin naka ilaw yung LED indicator kaya walang logo na lumabas. Tinest ko kgbi yung adapter nya umabot ng 8volts dapat ay 7.5v lang. Master ano po sira nito. Kaliit ng mga piyesa. Anu po ba twag sa gnto kaliit mga SMT type ho ba!
« Reply #7 on: January 03, 2011, 05:40:52 PM »
yapz SMT/SMD na nga yan.. surface mounted devices
kong meron kayong 8V nasusukat sa PS adapter ay pwepwede pa yan.. in short ok ;D  it respect to its proper polarity ha.. baka di lng accurate ang tester mu...
baka pinagpalit ng huli tech nyan.. hula  lang  ;D
now regarding with ur probz.. buksan mu ang PS module  mu..  sundan ang path ng DC supply  kong hanggang saan  lng  ang kuryente malamang may open path/open fusible..
Offline jfar223344
« Reply #8 on: January 03, 2011, 08:09:47 PM »
Wala naman nag try lang xa nung jumper din pag press on sandali nagblink ang led pero wala p ring nangyaring power up. San po tau mkakabili ng ganung kaliit. Meron kya sa mga electronics store?
« Reply #9 on: January 06, 2011, 01:45:51 AM »
nag  blink lang ba kamu.. ?
baka  sira ang main switch  nyan.. sa pagkakaalam ko dapat steady ang light ng LED mu sa ganyang modelo...
try mu nga press mu nangmatagal ang ang main power/reset button  diba pinag-isa  na yan....
pagnagpower  yan  at tuloy tuloy... baka  yan lng nga  ang salarin.. sana  nga lng.. ;D
Offline jfar223344
« Reply #10 on: January 10, 2011, 12:24:15 AM »
Yap sira din pala ang switch nya, na trace napo ang probz nsa zener at resistor. Dapat daw nsa 5volts something lang ang supply nya pero umabot sa 8volts. Sana walang IC na  masira. Pinagawa ko na lang sa ibang tech. Balikan ko pa if may pag asa pa na makumpuni. Sana rin may mahanap xang pampalit nito. Up !
« Reply #11 on: January 10, 2011, 06:31:55 PM »
hhmmmm... kahit ako hndi ko maaasure na wlng bumigay sa ganyang trouble scenario.. kong ang input  ay 8v simula sa adapter at papasok sa power reg ng PS module na wla man lng voltage regulation into lower, patay kang quad  ic ka pagnagkataon... sana lng may nag-open path agad... (fusible) dahil pagwla ay.... wag nmn sana
