Author Topic: Konzert KW - 2600 10" hi-fi Subwoofer dual impedance 8ohms - 8ohms ???  (Read 1122 times)
Offline j a y k e z
  • gimmegaggigsss
Mga sis tanong ko lang ngayon ko lang napansin, bakit dalawa ung speaker terminal ng subwoofer ko para saan ung isa??
Mode: Konzert
Model:KW - 2600
10" hi-fi Subwoofer
ganito itsura nya
(image cortesy of pinoydvd http://www.pinoydvd.com/index.php?topic=3529.930)
Yung isang terminal lang ang kinabit ko eh.
  • Pogi/Ganda Points: 412
Re: Konzert KW - 2600 10" hi-fi Subwoofer dual impedance 8ohms - 8ohms ???
« Reply #1 on: January 05, 2011, 11:25:49 AM »
dual voice coil yan (DVC) para may option ka pumili ng impedance...if dual 8 Ohms yan pwede mo parallel into 4 Ohms or series to 16..
Offline j a y k e z
  • gimmegaggigsss
« Reply #2 on: January 05, 2011, 12:04:43 PM »
ty sis +1 4 u ;D
waaaaaaaaaa ganito ginawa ko sa sub ko sa bahay T_T akala ko ok lang un mali pala T_T
Does It Matter How The Voice Coils Are Wired To Each Other?
A dual voice coil speaker will behave exactly the same way whether it is wired with its coils in series or parallel. The only thing that changes is the impedance that the amplifier sees. This means that enclosure calculations are constant for dual voice coil woofers no matter how the coils are connected to each other, as long as both are connected.
A common misconception with regard to dual voice coil speakers is the assumption that nothing changes if you power only one of the voice coils. With only one coil hooked up, a dual voice coil speaker will suffer a loss in reference efficiency of about 3dB (only half the coil windings are being energized) as well as a significant shift in its Thiele/Small parameters. This renders any enclosure calculations inaccurate unless you remeasure the speakers parameters with only one coil hooked up. Failure to account for the different parameters of a dual voice coil speaker with only one coil powered can result in very poor performance.
(source: http://pinq.wordpress.com/2007/05/11/tutorial-dual-voice-coils-dvc/ )
 ??? nasa province pa naman un huhuhuhu  ???
« Reply #3 on: January 05, 2011, 12:08:22 PM »
ok lng yun..no harm done naman sa speaker...yun nga lang sayang yung feature nya...
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
kapg sa kotse gagamitn 4 ohms pag sa bahay 8 ohms :)
WootsPC2 Videos  Woots Page
Offline fantom_mayonaise
  • Pogi/Ganda Points: 30
« Reply #5 on: October 18, 2011, 11:29:16 PM »
Sir Jikz : saan po nakakabili ng ganitong driver? meron din po bang 12"?
Offline j a y k e z
  • gimmegaggigsss
« Reply #6 on: October 21, 2011, 09:54:11 AM »
^ binigay lng po sa akin....
Offline Mhavskie
  • Pogi/Ganda Points: 77
  • NeverShoutNever!
« Reply #7 on: October 21, 2011, 10:49:25 AM »
Kung capable yung amps mo na mag drive ng 4ohms, i parallel mo na yung speaker mo na DVC, para swak na. :D
