Author Topic: hi...mga master i need your help bout my problems...  (Read 1063 times)
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« on: January 09, 2011, 12:20:38 AM »
mga master..hingi po sana ako ng tulong..f wat problem sa tv na phillips model 21pt2325/71..
kasi poh...ung vertical ic nya na stv 9302 ay umiinit at hindi poh normal ung labas ng video nya..
pinalitan ko na po ng vertical ic hindi parin..
un parin poh ang kalabasan..hope poh matulongan nyo ako bout my problems...tnx...plz..........
  • Pogi/Ganda Points: 911
Re: hi...mga master i need your help bout my problems...
« Reply #1 on: January 09, 2011, 12:33:17 AM »
normal ba ang vert. supply mu ?
dual  yan sis  ;D
« Reply #2 on: January 09, 2011, 12:35:23 AM »
may linya sya na patakbo-tabo...sagabal tingnan..at parang sasabog talaga ung ic.sa subrang init..kaya hindi ko matagalan sa pag-on.ano poh kaya sira nito..master?..
i think hndi normal  ang Vert. supply  mu baka masxadong mataas  o hndi  kaya  hndi balanse...
ilang nga pala  ang B+ mu ?
Offline BUMBLEBEE
« Reply #3 on: January 09, 2011, 12:39:22 AM »
normal lang poh young voltage..nya..
Offline BUMBLEBEE
« Reply #4 on: January 09, 2011, 12:41:16 AM »
7 pins poh...cxa..pang tatlo ko na poh palit pero un parin
Offline BUMBLEBEE
« Reply #5 on: January 09, 2011, 12:46:49 AM »
9 pins poh pala..
« Reply #6 on: January 09, 2011, 12:50:49 AM »
sukatin  nyu muna a ng supply ng vert. drive  nyu..
yung pin 2 & pin 6
« Reply #7 on: January 09, 2011, 12:55:29 AM »
parang may  mali  aku.. dual  nga ba ito ? ??? ;D
Offline BUMBLEBEE
« Reply #8 on: January 09, 2011, 01:01:45 AM »
for now poh hindi ko macheck ..try ko lang poh bukas..and ask lang poh anong kalimitang supply ang nsa pin2 and pin 6
Offline BUMBLEBEE
« Reply #9 on: January 09, 2011, 01:13:10 AM »
hindi poh kaya sira ung ic nya?ang problema spider type cxa
« Reply #10 on: January 09, 2011, 01:33:26 AM »
+13V for pin2 & 6
-13V nmn for pin4
Offline BUMBLEBEE
« Reply #11 on: January 09, 2011, 01:39:37 PM »
tnx poh sa input..pag-lampas poh yung voltage nya?sira poh yong fbt?
« Reply #12 on: January 09, 2011, 01:44:02 PM »
malamang ;D  o mataas ang B+ mu
Offline BUMBLEBEE
« Reply #13 on: January 09, 2011, 10:35:40 PM »
na check ko napoh yung voltage..sa pin1 at pin6 ..yung pin1-13v,pin6-13.5v yata...hanggang ngayon hindi ko parin nakita talaga ung sakit nya...umaabot na poh to ng 1 month master eh..dalawang unit ung nandito sa akin..magkatulad din ng sakit..at model...
« Reply #14 on: January 10, 2011, 06:43:35 PM »
sis nalilito aku sa update mu..
xa nga pala  ang naaninag mu sa video display ng pixtube.. ?
baka kasi misinterpret na nmn aku  ;D
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #15 on: January 10, 2011, 07:37:00 PM »
palitan mo lang ng ecap sa buong vert section yan sure solve na agad problema nyan
ndi na pinagtatagal sa 30 minutes yan kapatid
« Reply #16 on: January 10, 2011, 08:00:17 PM »
yan  ang gusto  sau sis  kagz... tinutumbok mu agad ang salarin ;D
 pinabibilis mu ang troubleshooting ;D
Offline pEN DoTA
« Reply #17 on: January 10, 2011, 09:38:00 PM »
pag napalitan mo na ung veretical IC. pa check mo nlang muna ung FBT, mostly sa mga philips FBT ang magloko.
GOD LOVES YOU
« Reply #18 on: January 11, 2011, 12:58:09 AM »
agreed aku jan sis pendot. 80%  lagi yan ang sira sa mga philips chassis  lalo na ang L7.1a & PV4.0... but first we need to check the peripheral.
bago magproceed sa major parts ;D
Offline NORTH LUZON
« Reply #19 on: January 11, 2011, 07:34:10 AM »
pag umiinit ang vert out ay malayong lipadlikod ang salarin
tama si master ultra na pwdeng mataas ang b+ or mataas ang horiz osc
pag napalitan na ng ts ang mga ecap sa paligid ng vert out at ganun parin ay alam na natin ang salarin jan heheheh
