Author Topic: Atmega8515 SMS Controller - Alternative F/W for EPE SMS Controller  (Read 2104 times)
Offline Mayalin22
  • Pogi/Ganda Points: 400
Re: Atmega8515 SMS Controller - Alternative F/W for EPE SMS Controller
« Reply #20 on: March 26, 2011, 03:30:05 PM »
uy kailangan ng disassembler... meron ka bang magandang disassembler?
pag nadisassembled natin yan at least magkakameron tayo ng idea how it works  :D
  • Pogi/Ganda Points: 412
« Reply #21 on: March 26, 2011, 04:10:45 PM »
dito ka na lang kaya umuwi sa bahay?? Impakta ka talaga!!
Offline Mayalin22
« Reply #22 on: March 26, 2011, 04:15:38 PM »
 ;D ;D ;D
hirap gumawa pag hindi mo alam nangyayari  :P ;D ;D ;D
Offline Mayor Johnaray
  • Pogi/Ganda Points: 238
« Reply #23 on: March 26, 2011, 04:24:04 PM »
;D ;D ;D
Pwede naman gumawa ah lalo na sa dilim ;D ;D ;D
Offline Mayalin22
« Reply #24 on: March 26, 2011, 04:27:39 PM »
mahirap sa dilim baka may espda  ;D ;D ;D
« Reply #25 on: March 26, 2011, 04:30:30 PM »
kapain mo na lang....;D
« Reply #26 on: March 26, 2011, 10:33:54 PM »
pinakamahirap hanapin yung 7.3728 MHz na crystal, ginamitan ko dati ng 8MHz pero ayaw gumana.
« Reply #27 on: March 28, 2011, 10:49:44 AM »
last time ko gumamit nyan is with this...
meron pa akong 3pcs xtal nyan..di ko lang alam if saan ko natambak...;D
« Reply #28 on: March 29, 2011, 10:24:14 AM »
Ini-improve ko pa yung gsm code ko sa PIC  ... tapos ipoport ko na dito sa atmega8515.   Meron din ako nadownload na c source code for FBUS kaya lang I dont think its worth it to develop anymore dahil pahirap na ng pahirap makahanap ng good condition and working  3310.
« Reply #29 on: March 30, 2011, 10:42:45 AM »
sa 3310/3315/3410/3350 dumabaha pa dito sakin sis...hehehe...
« Reply #30 on: March 30, 2011, 11:43:39 AM »
Eh di gawin mo na sis itong epe sms controller.
MC34064P-5 under-voltage sensor - actually not needed kung atmega8515 ang gagamitin pero may available nito sa deeco.  Just enable BOD sa atmega8515.
AT90S8515-8 or ATMega8515-16 microcontroller (40 pin) - 125 petot sa Alexan
ULN2803 Darlington transistor array - meron din sa Alexan, nakalimutan ko na presyo
220μH ferrite choke - kinuha ko yung inductor from some generic 50 petot car cellphone charger na gumagamit ng mc34063 kasi karamihan ng design na nakikita na 12Vdc source na step down dc-dc converter uses 220uH inductor.  Pwede din naman lm317 na lang ang gamitin or huwag na lang gamitin.
7.3728MHz crystal - meron ka na pala nito so OK na OK
« Reply #31 on: March 30, 2011, 11:46:47 AM »
hinay-hinay....sobrang dami ko Do It Yourself ngayun...but never naka DONE It Yourself!
lahat walang casing...;D
Offline romel_emperado
« Reply #32 on: May 24, 2011, 10:41:52 PM »
pweding pahingi nyan sis?.. pag eexperimentohan ko lang.. madali kasi ang buhay pag sa AT commands... hihi
« Reply #33 on: May 25, 2011, 06:45:39 PM »
pag natapos ko  no problem  ....   on and off  kasi yung pag gawa eh, masyado maiksi attention span ko, mabilis ma-divert sa ibang projects.
Offline 1diyMARKET
    • 1 am 1diyTEAM
« Reply #34 on: May 25, 2011, 08:26:55 PM »
Kaya ko naisip gumawa alternative f/w kasi gusto ko gawan ng sms functionality yung neSS2 and I noticed na pin to pin compatible ang 8515 sa 89s52.  Medyo napabayaan lang at nadivert yung attention ko sa ibang project.
This is nice Sir Alyas,  1diyTEAM would be glad to see your masterpiece -  the GSM module working on NE2ss  Educational Learning Trainer Board.
It is right, ATmega8515  or ATmega612  is pin to pin compatible with the AT89S52,  what is actually needed to change on the hardware of NE2ss is the Reset.   AVR is active low,  8051 is active high.
Good luck and more power.
« Reply #35 on: May 26, 2011, 06:02:56 PM »
I mean yung FBUS protocol po ang hihingin ko di bale na yang AT commands based.. :)
« Reply #36 on: May 26, 2011, 06:33:03 PM »
You will need an mcu with lots of RAM otherwise simple on and off application lang magagawa mo.  FBUS will eat a lot more RAM than using AT commands and if you will check the net, you will find that most fbus projects uses higher end mcus (faster and more RAM).
Google mo lang n6110.c,  it's fbus driver for the pc but pwedeng i-port to an mcu with big amount of RAM.
Offline Dandy
  • Pogi/Ganda Points: 31
« Reply #37 on: May 26, 2011, 06:51:07 PM »
interesting..   subscribing
« Reply #38 on: May 26, 2011, 11:34:06 PM »
ito po ba??
http://de.wammu.eu/docs/devel/internals/n6110_8c_source.html
ang haba naman lol.... matutulog nalang ako... hihi
Offline jazMyn<3u
« Reply #39 on: February 23, 2012, 07:18:58 PM »
nice thread sis...ask ko lang natapos nyo na po yung pang at commands for at89s52?...
sarap isipin hirap gawin.,need more info.,:D:D
TiA
