mga bro's.
need help po
...kung ano po yung tamang algorithm sa pag receive ng sms. we are using a python 2.6 program.. we need to get the data message from a phone. na-a access naman namin yung message from the phone pero kulang, imbes na 7 messages, 3 lang ang pinapakita nya..
eto po yung program.
import serial
import time
# configure the serial connections (the parameters differs on the device you are connecting to)
ser = serial.Serial(
port='/dev/ttyUSB0',
baudrate=9600,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
bytesize=serial.EIGHTBITS,
timeout=
ser.close()
ser.open()
if ser.isOpen():
ser.write('at\r');
s = ser.readline(); s = ser.readline()
s = s.strip() #cut the newline or spaces at end
if s == 'OK':
print 'Connection is made.\n'
ser.write('AT+CMGF=1\r') # AT command to switch to text mode
ser.write('AT+CPMS="me","sm"\r') #.. //this line po ba ang may problem Huh //
s = ser.readline(); s = ser.readline(); s = s.strip()
print '\nMESSAGES: \n'
if s == 'OK':
ser.write('AT+CMGL="ALL"\r');
s = ser.readline(); msg = ''# initialize message
while msg != 'OK':
s = ser.readline()
s = s.strip()
msg = s
print msg
else:
print 'Connection failed.'
ser.close()
else:
pass
