Author Topic: 390 ohms  (Read 775 times)
Offline dEn:)
  • Pogi/Ganda Points: 4
390 ohms
« on: January 25, 2011, 08:17:26 PM »
mga master tAnong qlng kong ilang wats pwd q ipalit s 390 ohms resistor hnd ko alam kong ilang wats nbalatan n kac ung kaperaso lang nbasa ko 390 ohms nkalagay try q lagyan ng series 400 ohms prang habang tumatagal nasu2nog...
ano po kya mganda teknik pra malagyan ng tamang wats ung 390 ohms???
galing syang fbt papuntang yoke or >:( COLD po ata ung nkaprint s board nya??????
390 ohms
Offline NORTH LUZON
  • Pogi/Ganda Points: 811
Re: 390 ohms
« Reply #1 on: January 25, 2011, 09:10:50 PM »
dapat same sa laki ang ipapalit mo sis
sure ka ba na 390 ohms yan?
baka 39 ohms lang?
mas ok sana kung post mo dito ang modelo ng unit mo at baka may schema ang mga master
Re: 390 ohms
Offline dEn:)
Re: 390 ohms
« Reply #2 on: January 26, 2011, 02:42:54 PM »
burado n po model nya,sure po 390 ohms plane white xa tpos tester qna din xa. kya ko po pa2litan kac bka sya ung cause pag 30 mins.n nka on ung set sound nlang wla n display subrang init kac
Re: 390 ohms
Offline Triple_D
  • Pogi/Ganda Points: 164
Re: 390 ohms
« Reply #3 on: January 26, 2011, 06:19:30 PM »
square ba? saan ba nakakabit sis?
5w 0r 10 lang yan anu ba sukat?
Re: 390 ohms
  • Pogi/Ganda Points: 909
Re: 390 ohms
« Reply #4 on: January 26, 2011, 06:25:19 PM »
need  more  info sis
Re: 390 ohms
Offline dEn:)
Re: 390 ohms
« Reply #5 on: January 26, 2011, 06:41:18 PM »
hindi po xa square kakulay lng nya un. halos kacng sukat xa ng 1/2 resistor...nkalagay xa malapit s fbt hnd ko n po tanda kong ppuntang vertical section nsa work n kac q...basta nong my display n cnara qna xa kala q kac ok n tpos nong paAlis nq biglang dahan dahang dumilim uli hangang sounds  nlng natira sabi q ba2likan ko nlng...
Offline Triple_D
Re: 390 ohms
« Reply #6 on: January 26, 2011, 07:21:57 PM »
ganun ba,pwede na 1/2w jan.
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
Re: 390 ohms
« Reply #7 on: January 27, 2011, 09:05:39 AM »
try mo magseries ng multimeter para ma measure actual current para may idea ka.
  • Pogi/Ganda Points: 231
Re: 390 ohms
« Reply #8 on: January 27, 2011, 10:40:14 AM »
tutukan mo ng tester yung mga voltages sa CRT board hangang sa mag Dim, measure mo ang Heater, Screen Voltages o G2, RGB volatges. sana makatulong
Offline NORTH LUZON
Re: 390 ohms
« Reply #9 on: January 27, 2011, 09:57:48 PM »
kahit isang bayong na carbon type resistor ang ilagay mo jan ay sure mangingitim pa
baka flame proof resistor ang orig nyan
FPR ang sagot sa tanong mo kapatid na TS
Offline kinyo
  • Pogi/Ganda Points: 25
Re: 390 ohms
« Reply #10 on: January 27, 2011, 11:38:57 PM »
di kaya symptom lang yung umiinit na resistor?
something is causing it to heat up, find the cause of the problem
 ;D
Offline ferdie444
Re: 390 ohms
« Reply #11 on: January 28, 2011, 02:05:35 AM »
@TS,paki check mo kung may nakakabit na transistor dyan sa r-390 ohms @ baka yon ay may leak or may konting short na(out of circuit test)kung kaya't matapos maipower on eh nag-iinit na yang 390r @ magdrop na ang voltage.thanks and good luck....
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
Re: 390 ohms
« Reply #12 on: January 28, 2011, 05:47:00 AM »
TS san papunta ung 390ohms? sundan nyo at i chek mga parts load ng resistor na yn
Offline dEn:)
Re: 390 ohms
« Reply #13 on: January 29, 2011, 09:20:32 PM »
slAmat ng marami s mga reply......nsa work p po kac q update q nlng po kau pag uwi q.... :)
Offline dEn:)
Re: 390 ohms
« Reply #14 on: March 10, 2011, 08:38:16 AM »
update lng po my nabuksan akong tv d2 s work q ito ung model 21v-k80m ganito po pala ang model nya....
galing pala xa ng vertical papuntang yoke...hndi kulang nbasa value nya kac speaker lng ang cra kaya hind q ntangal s board ung resistor pra tingnan...
Offline panyero
  • Pogi/Ganda Points: 93
  • scratch my back and i scratch another back
Re: 390 ohms
« Reply #15 on: March 10, 2011, 09:12:12 AM »
patambay para matutu naman ako..
@ ts hindi lahat ng umiinit yon ang sira kahit lagyan pa ng 2watt yan iinit parin,may ibang problema kaya umiinit ang resistor baka sa yoke.
Offline Triple_D
Re: 390 ohms
« Reply #16 on: March 10, 2011, 09:20:58 AM »
sayang sis dapat tiningnan mo na body marking di na kelangan baklasin yon...
Offline taqui
  • ang ganda ko
Re: 390 ohms
« Reply #17 on: March 10, 2011, 10:21:04 AM »
sharp pala ito.. san po ba konektado itong resistor? hindi ba galing b+ to?
Offline Triple_D
Re: 390 ohms
« Reply #18 on: March 10, 2011, 04:28:34 PM »
sa board daw sis...jok
yakang yaka na ng ts yan...
Offline taqui
  • ang ganda ko
Re: 390 ohms
« Reply #19 on: March 10, 2011, 04:46:23 PM »
baka normal lang na umiinit yan, check sa load ng resistor..bka my nag leak na..anu ba voltage na pumpasok sa resistor?
Re: 390 ohms
