Author Topic: panasonic tc-2155R sound distorted pag nilakasan vol.  (Read 1028 times)
Offline marz
« on: February 08, 2011, 02:18:51 PM »
Gud day po mga master help nman po TC-2155R,garalgal po un sound prng distorted pag nilakasan un vol. sa halos lahat ng tv channel,pEro sa AV mode ok nmn using dvd player khit isagad un volume nya hndi garalgal, san po kya posible problema nito. cnsya na po baguhan lng po.
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
Re: panasonic tc-2155R sound distorted pag nilakasan vol.
« Reply #1 on: February 08, 2011, 03:44:46 PM »
if section, if sound try pihitin konti, tandaan exact position bago mg pihit,
  • Pogi/Ganda Points: 231
« Reply #2 on: February 08, 2011, 04:00:44 PM »
check mo muna dyan sa Menu baka hindi nakaset ng tama ang Audio or hindi naka Ntsc..
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #3 on: February 08, 2011, 09:30:49 PM »
multi system yata ang unit na to ah
Offline marz
« Reply #4 on: February 08, 2011, 10:00:08 PM »
multisystem nga po sir 17 system,na check ko na din po menu ok 4.5mhz sound sys, color sys ntsc...isang if x4mer lng po nakita ko malapit sa ic an5192k(pal/ntsc ctv system) at mron din board na maliit nkatayo ang kabit pinul out k un board den resolder binalik ko uli nklagay dun ic M52317SP(multiple SIF converter) at mga ceramic filter po yta un value 4.5/.5.5/6.5mhz nag resolder na rin ako sa mainboard kaso ganun pa din po...
Offline NORTH LUZON
« Reply #5 on: February 08, 2011, 10:07:34 PM »
resolder na ba lahat?
ung ecap sa sif ckt direct mo na
Offline marz
« Reply #6 on: February 08, 2011, 10:13:53 PM »
sir na resolder ko na po halos lahat jungle ic,tuner,psu pero wla pa po akong pinapalitan na e caps dun p ln po ako sa resoldering ng board at un if pinihit kn din po
Offline taqui
  • ang ganda ko
« Reply #7 on: February 08, 2011, 10:18:19 PM »
wala bang pag babago nung pinihit? sis try nyo direct replace ng xtal 4.5mghz..
Offline marz
« Reply #8 on: February 08, 2011, 10:20:14 PM »
update ko po kau bukas mga sir try ko mag palit ng e caps sa sif bukas tnx po god bless...
Offline marz
« Reply #9 on: February 08, 2011, 10:26:28 PM »
wla pong pinagbago sir,,,pero wla pk pinapalitan bukas po try ko palitan mga un...
Offline lhan
  • Pogi/Ganda Points: 182
  • agta maloko
« Reply #10 on: February 08, 2011, 10:31:31 PM »
anong ntsc ginamit sis 443 o 358 sa rf? check mo din sound system kung may bg, I,
m n setting?
Offline NORTH LUZON
« Reply #11 on: February 08, 2011, 10:41:14 PM »
ung 5192 na jungle minsan ay nasisira na ganyan ang trobol sau
Offline marz
« Reply #12 on: February 08, 2011, 11:14:59 PM »
sir 3.58mhz po, sa sound system un lng 4.5,5.5 @6.5mhz wla po ako npansin na I bg dk sa setting
delikado po pla un 5192 ko posible rin po pla dun mngaling ang problema, mga sir tnx sa reply. update na lng po uli
Offline taqui
  • ang ganda ko
« Reply #13 on: February 08, 2011, 11:20:23 PM »
merun ako dati nagawa jvc distorted sound, 4.5mgz pinalitan ko ng 3.58 ng ok naman., try mo din sis,di naman maselan yn
Offline J@M
  • Pogi/Ganda Points: 122
« Reply #14 on: February 09, 2011, 01:51:46 AM »
Subscribing......
Don't Give up
Offline enriz622
  • Pogi/Ganda Points: 288
« Reply #15 on: February 09, 2011, 06:33:50 AM »
patambay nga po
Offline NORTH LUZON
« Reply #16 on: February 09, 2011, 08:41:04 AM »
HEHEHEHEHEHEHE
ibig mo ba sabihin sis ay ung 4.5 saw filter ay pinalitan mo ng 3.5 color xtal?
ayos yan ah,masubukan nga
Offline taqui
  • ang ganda ko
« Reply #17 on: February 09, 2011, 11:03:45 AM »
yap sis insider, jeje palage kc ko nang huhula sa tv, and ayos naman experiment ko
Offline Tripler02
  • Pogi/Ganda Points: 85
  • Saka na my own pic
« Reply #18 on: February 09, 2011, 12:30:02 PM »
Sub..
Offline lhan
  • agta maloko
« Reply #19 on: February 09, 2011, 01:28:29 PM »
HEHEHEHEHEHEHE
naku nsan baka mapalo k nyan,, 5.1 n audio out nyan
