Author Topic: Potentiometer Controlled Wireless Mimic Robotic Arm  (Read 423 times)
Offline punongpanlarangan
« on: February 08, 2011, 02:47:39 PM »
need help po ASAP. how possible po ito using PIC 16F877?
ano po yung mga devices na gagamitin?
servo motors po yung kailangang controlin wirelessly.
may sample program po ba kayo dito? thanks so much.
Re: Potentiometer Controlled Wireless Mimic Robotic Arm
« Reply #1 on: February 08, 2011, 02:49:34 PM »
using e-gizmo's uhf serial transciever.
16f877a ang servo driver ko
and 16f88 naman yung remote control.
« Reply #2 on: February 08, 2011, 02:54:01 PM »
thanks sir martin.. para saan po pala yung remote control?
« Reply #3 on: February 08, 2011, 02:57:36 PM »
bale
analog potentiometers (angle control)
papasok sa ADC port nang PIC 16F88
gagawin nya na yung voltage from potentiometers mo to serial data.
itratransfer nya ngayon sa wireless UHF serial modules.
rerecieve nang PIC 16f877a
then magpaparse nang data from serial to PWM signals
para sa pag galaw nang angular movement nang servos mo.
« Reply #4 on: February 08, 2011, 03:03:36 PM »
may sample pictures po ba kayo? ang source code?
« Reply #5 on: February 08, 2011, 03:13:50 PM »
bale ito po yung mga devices na ginamit namin.. 8 potentiometers connected sa PIC 16F877 then connected sa tranceiver. eto po yung specs ng ginamit naming tranceiver:
Product Number   RMB-CM12111
Product Name   Wireless RF Transceiver 431-478MHz GFSK Data Transfer x 2
Size (only PCB)   39.60mm(L) X 19.30mm(W) X 4.32mm(H) ±0.2mm
Net Weight   28g/1.0oz
Brief Introduction:
This package consists of two mini half-duplex wireless data transceiver modules and each such module is highly integrated with an ultra speed MCU and a powerful RF chip. With the introduction of the innovative yet higly-efficient encoding method, its anti-interference ability and sensitivity are significantly improved. Features like various channel options, ultra long transmission distance (1000 meters) or abundant interfaces (UART/TTL, RS-485 & RS-232) helps make the transmission of data of any size possible and eliminate the needs of writing transmission program and running complicated settings. A software application ("RF-Magic") is offered for free so that users can modify the settings of the module. Besides, its slim size and wide power supply range makes itself the most popular sel ection of many applications in different fields.
Features:
•   Ultra long transmission distance: 800-1000 meters @1200bps
•   Working frequency: 431-478Mhz (1KHz step)
•   +3.3-5.5V wide power supply range
•   -112dBm(9600bps) high sensitivity
•   Over 100 channels
•   GFSK modulation
•   Highly efficient cyclic interleaving error correction encoding
•   Flexible software programme option settings
•   Selectable RFID index
•   UART/TTL, RS-485 & RS-232
•   Large data buffer: 512bytes
•   Suitable for massive data transfer
•   Built-in watchdog ensures long-term operation
Specifications:
Parameter   Value
Power Supply   3.3 – 5.5 (± 50mV ripples)
Frequency Range   431MHz to 478MHz (1KHz frequency step)
Frequency Interleaving   200KHz
Output Power   20mW ( 10 levels adjustable)
Receiving Sensitivity   -117dBm@1200bps
airborne speed   1200 – 9600bps
Speed In Port   1200 – 9600bps
Parity Check   8E1/8N1/801
Operating Humidity   10% - 90%
Operating Temperature   -20℃ - 70℃
Transmission Mode Current   ≦35mA@10mW
Receiving Mode Current   ≦28mA
Sleep current   ≦5uA
Transmission Distance   800-1000m (visible range in open area)
Pinout:
Pins   Definition   Description
1   GND   0V
2   VCC   3.3V-5.5V
3   EN   POWER ENABLE(≧1.6V) or SUSPENDED ENABLE(≦0.5V Hibernation)
4   RXD   UART input, TTL
5   TXD   UART output, TTL
6   B/RX   RS485- or RS232 RX
7   A/TX   RS485+ or RS232 TX
Dimensions:
Settings of "RF-Magic (Ver:4.2)":
Settings   Options   Default
Series Rate   1200,2400,4800,9600bps   9600bps
Series Parity   Disable, Even parity, Odd parity   Disable
Types of Series   RS485, RS232   RS485
RFID Disable   Disable, Enable   Disable
RFID Index   0-65536 (16 bit)   12345
RF Frequency   431-478MHz (1kHz step, accuracy ±100Hz)   434MHz
Series rate   1200,2400,4800,9600bps   9600bps
Freq Deviation   5.4, 10.8, 21.6, 43.2, 86.4KHz   21.6 KHz
RF Power   1-10 (10 indicates 20mW)   10 (20mW)
then sa receiver side, connected po yung receiver sa isa pang PIC 16f877 and then, sa mga 8 servo motors.
