Author Topic: HP dv2700 laptop mabilis mag init tpos nawala display  (Read 1734 times)
Offline shopa0
« on: February 10, 2011, 04:51:48 PM »
mga sir patulong naman po, mbilis mag init then after 1yr na yata nwala ung display s screen pero gumagana nman po ung OS kc naririnig ko ung start up. bka backlight lang gumagana s monitor. Ano po kya sira nito? Kung dadalhin ko po sa repair shop, magkano po kaya paayos at saan po malapit near mrt boni? Salamat po.
Offline josayu
  • Pogi/Ganda Points: 5
Re: HP dv2700 laptop mabilis mag init tpos nawala display
« Reply #1 on: February 10, 2011, 04:57:06 PM »
sir, white display po ba yan?
pag white maaring LCD na yan or flex
Offline shopa0
« Reply #2 on: February 10, 2011, 09:53:44 PM »
indi po sya white sir, gray po. Parang nka stanby video sa t.v. ang kulay.
sinubukan ko plug s m0nitor ng CPU ung laptop wla pa rin.
sinubukan ko rin power reset, tanggal ko batt. tapos 1min press ng ON, then kabit charger, wla rin.
help naman po, anong step pwede kong gawin.
Offline /
  • Pogi/Ganda Points: 317
« Reply #3 on: February 10, 2011, 10:13:16 PM »
check mo ang processor fan kung umiikot kasi konting singit lang ng mallit na bagay stop na agad yan, meron na akong binuksan na ganyan pavillion din, tumigil lang ang fan.
Offline slsiasat_14
  • Pogi/Ganda Points: 12
« Reply #4 on: February 10, 2011, 10:16:36 PM »
subscribing....
agree check fan kung umiikot or d na normal ang bilis ng pagikot.....
Offline marleona
« Reply #5 on: February 10, 2011, 10:21:32 PM »
try mong tapatan ng fan, ung nabibili sa cd-r king o di kaya basta maganda ung ventilation ng laptop mo. Pavillion ung gamit ko rin eh kaso dv6000. May heat issues kasi.
It is not the answer that enlightens, but the question.
Don't hesitate to ask question.
If you don't ask, you don't get.
Offline /
« Reply #6 on: February 10, 2011, 10:29:21 PM »
yan ang sakit ng hp kasi punong puno ng piyesa sa loob kaya ang bilis uminit..
  • Pogi/Ganda Points: 413
« Reply #7 on: February 10, 2011, 10:31:15 PM »
Ahhhm, ganun pala yun sis hunter.
Offline /
« Reply #8 on: February 10, 2011, 10:32:57 PM »
parang ganun nga sis, madami na akong na encounter na ganyang problema sa hp.
« Reply #9 on: February 10, 2011, 10:36:23 PM »
Eh paano sis yung parang flickering sa pinakababa ng screen niya sa compaq naman? Heat related din ba ito? Sakit na daw ito.
Offline /
« Reply #10 on: February 10, 2011, 10:44:17 PM »
sa LCD yan, baka may sira ang electronics component ng LCD mo.
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #11 on: February 10, 2011, 11:12:15 PM »
subscriving mode  ;D ;D ;D
Offline shopa0
« Reply #12 on: February 11, 2011, 12:25:43 AM »
salamat po s reply mga sir & mam, need ko po b buksan ung laptop para mkita kung imiikot ung fan s lo0b kc ang naririnig ko lang ung fan s may hulihan tapos mga 3mins. mainit kaagad binubuga na hangin. Tinanggal ko muna harddsk baka masira. Sinubukan ko baklasin hanggang turnilyo lang ako, para kcng may lock sa lo0b at baka masira ko lang. Pano nman po ung display? nwala po un habang gumagamit ako ng internet, bigla nagcrash.
« Reply #13 on: February 11, 2011, 02:53:40 PM »
Kung heat related sis magcrash talaga yan. Baka meron na yan hermal shutdown sensor.
Offline /
« Reply #14 on: February 12, 2011, 02:17:32 AM »
^kaya po nag sshutdown yan kasi po umiinit na..
Offline marleona
« Reply #15 on: February 12, 2011, 09:58:06 AM »
^yep tama po sila. Ganyan din ung HP laptop ko may thermal shutdown sensor. kaya siya biglang nagshutdown. basta maayos na ventilation lang kailangan niyan kahit buong araw mo pang gamitin yan
Offline /
« Reply #16 on: February 12, 2011, 01:56:55 PM »
sakin din 24/7 ginagamit di naman umiinit..
nasa aircon eh.. :D
Offline marleona
« Reply #17 on: February 13, 2011, 12:48:38 AM »
^Nyaks hahaha kaya pala. Minsan lang makatikim ng aircon laptop ko eh. Karaniwan nakapatong lang siya sa isang maliit na libro para may ventilation (leverage). walang pambili ng fan hehehe
Offline shopa0
« Reply #18 on: February 13, 2011, 03:22:16 PM »
tnx po sa reply, indi ko tlaga magetz ^_^ sencya na wla kc talaga ak0ng alam s pag repair ng laptop. Alam ko lang magpalit ng hardware at basic ng electronics. S LCD po ba or s m0therboard ang sira? Ang hirap pala buksan.
Offline /
« Reply #19 on: February 13, 2011, 03:27:05 PM »
^ang unang inaalis dyan sa pavilion ay yong parting may mga led, pag nabuksan mo na yon mabbuksan mo narin lahat.
