Author Topic: LG color tv no AV  (Read 841 times)
Offline ars
  • Pogi/Ganda Points: 7
  • No man is an island
LG color tv no AV
« on: February 16, 2011, 11:40:56 AM »
Mga master tulong po,,meron akung ni repair na lg tv 14 inc..  ok po ung sa tuner kasu av wla po signal na papasok. Ung IC na gamit d2 LG8838-04D,  tapus ung chroma TB1238BN.  Possible po ba na eto ung sira, o d lang po nag work at may iba pang dahilan?  Sana meron pong nka encounter ng ganito...pls help.    TIA
LG color tv no AV
Offline Triple_D
  • Pogi/Ganda Points: 164
Re: LG color tv no AV
« Reply #1 on: February 16, 2011, 11:49:06 AM »
switching ic mo sis.
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #2 on: February 16, 2011, 11:59:58 AM »
sis ask ko lang .. naka isolate ba av nyan? hindi ba sa heater kumuha ng supply? check mo muna vcc.. baka absent..
Offline ars
« Reply #3 on: February 16, 2011, 12:04:47 PM »
Triple_D.....ung connection po nya sis diritso po sa chroma wla na pong ibang ic.
taquinaga....tnx try ko advice mo sis
Offline taqui
  • ang ganda ko
« Reply #4 on: February 16, 2011, 12:07:32 PM »
meron kc LG na naka isolate ung grounding nya sa chassis.. and ung iba sa heater kumuha ng supply.. then daan ng transformer..
Offline ars
« Reply #5 on: February 16, 2011, 12:18:09 PM »
So possible po na ok po ung chrome to na TB1238BN sis...
Offline taqui
  • ang ganda ko
« Reply #6 on: February 16, 2011, 12:23:15 PM »
di pa naten masasabi sis.. jungle yn db? silipin nyo likod ng board kung naka bukod ung ground ng av sa chassis ground.. if naka bukod.. aun check nyo vcc..
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #7 on: February 16, 2011, 12:54:58 PM »
eeprom yan
Offline nymra
  • Pogi/Ganda Points: 25
« Reply #8 on: February 16, 2011, 01:18:02 PM »
Try mo muna sis suggestion ni sis insider, baka eeprom nga yan..
''don't forget where you came from, you might need to get back''
''You'll know you have everything, when you have nothing to lose"
Offline nymra
« Reply #9 on: February 16, 2011, 01:22:17 PM »
Offline taqui
  • ang ganda ko
« Reply #10 on: February 16, 2011, 01:33:13 PM »
deretso pala choroma, try nga muna suggestion ni sis kagz..
Offline Triple_D
« Reply #11 on: February 16, 2011, 01:54:21 PM »
try mo muna suggestion ni master kagz,
pag wala pa rin saka mo na pagdiskitahan ang ic...
Offline enriz622
  • Pogi/Ganda Points: 287
« Reply #12 on: February 16, 2011, 02:15:29 PM »
pwede malaman ang model nito sis
Offline ars
« Reply #13 on: February 16, 2011, 02:36:17 PM »
enriz622,,,,,update ko po kau bukas nasa offc aku ngayon  nasa bahay po ung unit sis...ung nabasa ko po dun sa front ng case platinum medyo gray ung kulay nitong unit.
Offline ars
« Reply #14 on: February 16, 2011, 02:38:39 PM »
I N S I D E R 2011,,,,,master ito po ba ung LG8838-04N  ang tnutukoy mo na may sira? Pwedi paki explain po.
Offline NORTH LUZON
« Reply #15 on: February 16, 2011, 07:10:45 PM »
ndi po yan ang eeprom
Offline taqui
  • ang ganda ko
« Reply #16 on: February 16, 2011, 07:15:43 PM »
eeprom 8pin po yan, mostly 24C01A, 24C02C,
Offline nymra
« Reply #17 on: February 16, 2011, 07:55:07 PM »
Ang pgkakaalam ko 24C04 ang memory ng unit na yan ts, bsta hanapin mo lng ung cnsbi ni sis taquinaga un na un.
Offline taqui
  • ang ganda ko
« Reply #18 on: February 16, 2011, 08:00:06 PM »
,near system control..
Offline ars
« Reply #19 on: February 17, 2011, 09:38:13 AM »
enriz622,,,,ito po ung model na nkaprint po sa likoran ng case model CP-14K41G,,
So mga master confirm ko lng pwedi ko ba itong palitan ng eeprom na bago o reflash nlang.
