Author Topic: arduino programming  (Read 762 times)
Offline veronica
arduino programming
« on: February 16, 2011, 05:19:53 PM »
our thesis will use arduino,and it should check the value in the serial port. if the value is "1", it will do a certain task. then there is an override switch which when pressed will reset the process of that task from the start. i have tried to program it but it doesn't do what it suppose to do.
i dont know if the problem is with the program sending the "1" to the serial port or the program reading the serial port which is the arduino..
please help poh..:)
arduino programming
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
Re: arduino programming
« Reply #1 on: February 16, 2011, 05:21:17 PM »
please post your code so the masters can help you debug your program easily
8051 stuff
Online glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« Reply #2 on: February 16, 2011, 09:50:25 PM »
my guess is, you're sending an ascii 1 and comparing it with int 1
 :D
« Reply #3 on: February 16, 2011, 10:15:50 PM »
Madali lang yan andyan si master glutnix
Offline veronica
« Reply #4 on: February 17, 2011, 11:40:12 PM »
ang gagawin po kc dapat ng design namin. pag my "1" s serial port, iaactivate nia ung dc motor. para po un dpat s pinto pero dahil prototype lang small motor lang or LED lang gmit nmin..pag my "1" s serial port, mag on ung motor for 3 secs ng clockwise then stop for 1 sec and then counterclockwise for another 3 secs. meron pong override switch, na pag pressed, at pasarado na ung pinto (counterclockwise), magrorotate sya ng clockwise kung ilang seconds na ng rotate ung motor ng counterclockwise.
eto po ung code namin s arduino:
const int input = 2;
  const int motor1Pin = 3;    // H-bridge leg 1 (pin 2, 1A)
  const int motor2Pin = 4;    // H-bridge leg 2 (pin 7, 2A)
  const int enablePin = 6;    // H-bridge enable pin
  const int override = 5;
  const int pin1 = 1;
char val;       // variable to store the data from the serial port
int p=0, r=0, q=0, t=0, s=0;
void setup() {
  Serial.begin(9600); // connect to the serial port
 // set the switch as an input:
   pinMode(override, INPUT);
    pinMode(input, INPUT);
    // set all the other pins you're using as outputs:
    pinMode(motor1Pin, OUTPUT);
    pinMode(motor2Pin, OUTPUT);
    pinMode(enablePin, OUTPUT);
    pinMode(pin1, OUTPUT);
    // set enablePin high so that motor can turn on:
    digitalWrite(enablePin, HIGH);
void loop () {
  // activate motor only when you receive data:
   if (Serial.available()) {
        val= Serial.read();
      if (val == '1') {
        if (r==1){
        //if r =1; set motor for forward for q seconds. and also set r back to 0
      digitalWrite(motor1Pin, LOW);   // set leg 1 of the H-bridge low
      digitalWrite(motor2Pin, HIGH);  // set leg 2 of the H-bridge high
      delay(q);
       r=0;
       t=1;
        if (t==0){
          // this will set the motor to forward (clockwise direction)
      delay(3000);
        //stop motor for 1 second
      digitalWrite(motor2Pin, LOW);   // set leg 2 of the H-bridge low
      delay(1000);
      p=1;
      unsigned long REDMillis = millis();//save the current millisecond when motor will be reverse
      digitalWrite(motor1Pin, HIGH);  // set leg 1 of the H-bridge high
      if ((digitalRead(override) ==HIGH) && (p=1))
        unsigned long ORMillis = millis();//save current millisecond when override switch was pressed
        q=ORMillis-REDMillis; //seconds that the motor operated on reverse
        //turn off motor
        r=1;
        s=1;
      if(s==0){
      delay(3000);//the motor should be on reverse (counterclockwise) for 3 secs
      //motor stops
    // if there is no "1" in serial port, motor will turn off
    else {
Online glutnix_neo
« Reply #5 on: February 18, 2011, 08:20:13 AM »
repost ko yung code with proper indentions
  const int pin1 = 1;
void setup()
void loop ()
      val= Serial.read();
      if (val == '1')
        if (r==1)
          delay(q);
           r=0;
           t=1;
        if (t==0)
          delay(3000);
        delay(1000);
        p=1;
          //turn off motor
          r=1;
          s=1;
        if(s==0)
          //motor stops
      else
isang napuna ko eh
eto
      else
ay nasa loob ng "if (val == '1') " condition ito ba ang intent nyo? or gusto nyo gawing else sya nung if na yun?
Online glutnix_neo
« Reply #6 on: February 18, 2011, 08:26:04 AM »
isa pang maisasuggest ko eh ihiwalay nyo ng function yung pagrotate ng clockwise or counterclockwise ng motor para di kayo nahihirapan.
may ilang parts na hindi malinaw sa code like ano yung mga variables na int p=0, r=0, q=0, t=0, s=0;.
Ang suggestion ko eh name your variables with names na idinedescribe kung ano sya, e.g. ctrclkwise_delay, clkwise_delay, mot1_position, etc.
This way madali maiintindihan ng ibang babasa ang code nyo and kayo rin eh madali nyo maaalala kung para saan ang variable na yun.
huling request ko eh block diagram ng system nyo, kasi napuna ko sa code may dalawang motor kayo,
Online glutnix_neo
« Reply #7 on: February 18, 2011, 08:59:55 AM »
you can start from this, gawan nyo na lang ng code yung door reset function....
const int pin1 = 1;
boolean bl_CommandRecieved = FALSE;
unsigned long DoorOpenTimer;
unsigned long ElapsedDoorOpen;
/*** rename nyo na lang into something more understandable ****/
void setup()
void loop()
      val= Serial.read();
      // run the motors
      if (val == '1')
        bl_CommandRecieved = true;
        DoorOpenTimer = millis(); //mark start of timer
      // turn off the motors
      else
        bl_CommandRecieved = false;
   if(bl_CommandRecieved && !digitalRead(override))
     ElapsedDoorOpen = (millis() - DoorOpenTimer);
     //reset everything back to initial position
     if(digitalRead(override))
       doorReset();
     else
       doorOpen();
   else
void doorReset()
void doorOpen()
  // Clockwise for 3Sec
  if(ElapsedDoorOpen < 3)          // continue clockwise until 3sec has lapsed
    motorsForward();
  // Stop for 1Sec
  else if(ElapsedDoorOpen < 4 )   // pause for 1sec, 3sec opening + 1sec pause
    motorsStopped();
  // Counter Clockwise for 3Sec
  else if(ElapsedDoorOpen) < 7 )   // counter clockwise
    motorsReversed();
  // clear command afte 7 seconds
  else
//*** Low Level Motor Controls *************************************
//void motorsClockwise()
void motorsForward()
//void motorsCntrClockwise()
void motorsReversed()
void motorsStopped()
« Reply #8 on: February 18, 2011, 09:29:22 AM »
agree sa mga suggestions ni sis glutnix. isa pa, kapag bago sa inyo 'yung function, i-test niyo muna kung paano gumagana using outputs na alam niyo kung paano paganahin like LED. tapos saka na lang pagsamahin sa buong code.
mas madali kasing makabuo ng program by sectional testing kaysa buoin muna 'yung program bago i-test kung tama nga.
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #9 on: February 18, 2011, 10:57:03 AM »
^ganyan din ako mag approach.  by section.  kung baga, divide and conquer.  then saka i combine after.
« Reply #10 on: February 18, 2011, 11:05:26 AM »
^ magulo talaga kasi kapag buo na 'yung code bago ite-test. :D mahirap nang alamin kung ano 'yung working at non-working part. ;D
Online glutnix_neo
« Reply #11 on: February 18, 2011, 11:11:23 AM »
may mali pala dito
dapat
if(bl_CommandRecieved)
Offline veronica
« Reply #12 on: February 19, 2011, 08:59:38 AM »
thanks po s mga reply. im editing the code you post. thanks.:)
ung process flow po nung design eto:
>>>computer sends "1" or "0" to serial port
>>> arduino reads serial port
>>>if there is "1", motor will rotate CW for 3 secs to open the door.
      if there is no "1", motor is inactive
>>>(a)motor will pause for 1 sec
>>>after 4 secs, motor will rotate CCW to close the door
>>>motor will begin rotating CCW .while door is closing, override
      switch can be pressed to stop the door from closing completely.
>>>if override is not pressed, motor stops rotating CCW after 3
     secs. if override is pressed, motor will rotate CW depending on
     how long it had rotated CCW.(the door should return to its
     original open position)
>>>after it had rotated CCW(this is when override was pressed), it
      will go back to (a)
>>>for the process where override was not pressed, the motor will
      be inactive and will wait for another signal to activate it.
Offline veronica
« Reply #13 on: February 20, 2011, 08:39:24 AM »
binago ko muna ung mga variables at mga indention nung dating program. eto na sya:
pero inuulit nia lang ung dapat gawin pag SerialValue == '1', hindi sya tumitigil..continuous lang ung loop nia. Dapat pag '0' na ung value stop n sya pero umuulit lang sya.
  int SerialValue;       // variable to store the data from the serial port
  int DoorClosing=0, ElapsedClosing=0, NoPrevOR=0, ORset=0;
  long threesec = 3000;
  long previousMillis=0;
  long onesec=1000;
  unsigned long ClosingMillis = 0;
  unsigned long ORMillis = 0;
  unsigned long currentMillis = 0;
void setup()
void loop ()
  // send data only when you receive data:
   SerialValue= Serial.read();
   if (SerialValue == '1')
     currentMillis = millis();
     if (ORset==1)//if r =1; set motor for forward for ElapsedClosing seconds. and also set r back to 0
        while(currentMillis - previousMillis <= ElapsedClosing)
        if(currentMillis - previousMillis > ElapsedClosing)
        previousMillis = millis();// save the last time you blinked the LED
      ORset=0;
      NoPrevOR=1;
     if (NoPrevOR==0)
        while(currentMillis - previousMillis <= threesec)
        { // this will set the motor to forward (clockwise direction)
       if(currentMillis - previousMillis > threesec)
          while(currentMillis - previousMillis <= onesec)
    if(currentMillis - previousMillis > onesec)
     DoorClosing=1;
      ClosingMillis = millis();//save the current millisecond when motor will be reverse
    if ((digitalRead(override) ==HIGH) && (DoorClosing=1))
     ElapsedClosing=ORMillis-ClosingMillis; //seconds motor operated on reverse
        /*save number of seconds red operated=q.
        get system time when red on. then get system time when override on. subtract them to get q;
        convert hour minute second and milliseconds to milliseconds ==REDmillis
        same s ORmillis.
        //then turn off red.
        //turn off motor
      ORset=1;
        /*ga2win ng override mgggreen
        patay c red; mggreen qng ilang seconds ng red knina bgo mg override
        save number of seconds in variable q..and set variable r to 1.
        p=0;*/
     if(ORset==0)
          //motor stops
    // if there is no "1" in serial port, motor inactive
    else
Offline veronica
« Reply #14 on: February 21, 2011, 01:03:20 AM »
thanks for the code glutnix_neo..it helped me.:)
Online glutnix_neo
« Reply #15 on: February 21, 2011, 09:26:59 AM »
gumana na?
