Author Topic: Freelance Design Engineers Needed  (Read 979 times)
Online glutnix_neo
  • Pogi/Ganda Points: 166
    • Underground Workbench
« on: February 17, 2011, 09:46:02 PM »
May dalawang nagpapahanap sa akin for freelance jobs,
One is yung sa company namin, they need someone to design a FW for factory use, bale ang gagawin ng FW eh magoautomate ng control ng power supply, e.g. startup sequence then susukatin yung delay at slew rate, measure ng fan speed at temperature, possible interface nya sa PC is RS485 or CAN.
yung isa naman eh RF mesh network/system within a building 3x2.5 inch size and for 200mtrs range(of course pwede gumamit ng repeaters) nakalimutan ko itanong application.
if you're interested PM nyo lang ako leave me your contact number and probably prepare kayo ng CV(wag nyo muna send sa akin, hindi ako may kailangan nyan ;D ;D ;D)
Offline _basura_man()
  • Pogi/Ganda Points: 36
    • Learn robotics here.
Re: Freelance Design Engineers Needed
« Reply #1 on: February 17, 2011, 09:48:57 PM »
Ate7 ang mahilig sa CAN  ;D ;D ;D
-John
Online glutnix_neo
« Reply #2 on: February 17, 2011, 09:52:40 PM »
Eto daw yung trabaho na iniwan nung some guy sa factory with initials na J.P.
ipinasa sa FW group kaso walang hahawak, masyado daw advanced ang code.  ;D ;D ;D
« Reply #3 on: February 17, 2011, 10:17:12 PM »
ayan din yung papalit sana sa USBtoI2C na adapter sa mga iMP's using PIC with CAN but Ate7 will who can only do that  :D
-John
Online glutnix_neo
« Reply #4 on: February 18, 2011, 03:14:36 PM »
uP ;D
« Reply #5 on: February 18, 2011, 03:22:40 PM »
ayy parang gusto ko makita yang si jet pangan :D
sya pala dapat gagawa nyan:D
masyadong kulang ang kakayanan ko para jan, interested sana ko talaga :'( (kahit di freelance:P)
Online glutnix_neo
« Reply #6 on: February 18, 2011, 04:33:42 PM »
kaw nga nirerequest ni boss kaso malimit irerequire ka pumunta sa factory, ano kukunin mo?
« Reply #7 on: February 18, 2011, 04:45:13 PM »
waaah  :o :o :o
malapit lang naman dito sa amin yung factory,  :P :P :P
magandang break saken ito, pero baket kinakabahan ako hahaha
ibakante ko lang sir yung nakalatag ko, iPM kita for confirmation thanks=)
Online glutnix_neo
« Reply #8 on: February 18, 2011, 04:54:40 PM »
sige pm mo lang ako, yung RF ayaw mo? ;D ;D ;D
« Reply #9 on: February 18, 2011, 05:05:39 PM »
:D :D :D tapos tayo jan...
usap na lang tayo about jan ulet bukas :D
« Reply #10 on: February 18, 2011, 05:33:31 PM »
IMBA YANG SI GIGZ I'M SURE PASOK KA DYAN   :D :D :D
-John
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
« Reply #11 on: February 18, 2011, 05:37:43 PM »
yan ba yung naka-patent? :)
isang certified impakta lang ag makakagawa nun.. ;D ;D
« Reply #12 on: February 18, 2011, 05:42:26 PM »
aray ko....
lalo akong nawalan ng space :D
pang impakta lang pala talaga :D :D :D
Offline zer0w1ng
  • Pogi/Ganda Points: 305
    • The Cebuano Geek
« Reply #13 on: February 18, 2011, 05:55:24 PM »
Sir Glutnix,
Am interested pero I had already have a very large project on queue right now.
I have an experience in CAN and had made a CAN-based commercial project doing OBD2 in-car diagnostics.
May RF experience rin ako, Nordic and Bluetooth (CSR chipset) that I believe fits for the "mesh" application.
What is their timeline? Baka next month pa ako ma-free.
Magkano kaya ang rate nito? Ballpark figure?
The Cebuano Geek
Online glutnix_neo
« Reply #14 on: February 18, 2011, 08:04:23 PM »
Sir Glutnix,
inform ko boss ko bukas then contact ko kayo or bigay ko contacts nila pagnagkausap kami,
sa rf naman prof ko dati ang naghahanap ng freelancer, kailangan din ng company nila.
regarding sa price and timeline, mas maganda siguro sir kung makakausap nyo sila ng directly. technical details lang nalaman ko eh.
paPM sir zero ng contact number at email nyo.
yung sa amin sa factory mukhang abot pa next month.
Online glutnix_neo
« Reply #15 on: February 18, 2011, 08:08:17 PM »
alam ko yung huling humawak nito sa group namin biglang nagresign, kaya napagdesisyunan na ioutsource na lang baka kasi maubos kami.
malupit talaga yang jet pangan na yan.  ;D ;D ;D
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #16 on: February 18, 2011, 09:30:40 PM »
This sounds like a burn-in oven controller.
"Set your mind free!"
Online glutnix_neo
« Reply #17 on: February 18, 2011, 10:06:28 PM »
not an oven controller but gagamitin sa units under burn-in,
may balak yata pagsabayin unit testing at burn in, hehehehe, joke lang yun
Offline motion55
« Reply #18 on: February 19, 2011, 11:38:37 AM »
Bale the units being burned-in are the power supplies?
The specs sounded like for a project I did years ago. It was for a company making analog devices. Alam mo na ang analog, pwede maraming voltage rails. The power supplies to the devices under test have to be powered ON in the right sequence to avoid damage. Before the next power supply is powered ON, the voltage of the current power supply has to be stable. Temperature, and fan speed to the oven had to be controlled, monitored and correctly sequenced. Duration of the test also had to be monitored. Some devices were burned-in for weeks and so pwede mag brown-out or mag fail ang devices during the burn-in. However, you don't want to throw away the burn-in but simply resume after brown-out.
The FW guys should explain why mahirap. Baka ang platform is not suitable for this project. Baka naman pangit ang hardware and so mahirap i-code ang firmware. Bad hardware design can make life hard for the firmware engineer. Otherwise, any FW group member that can't handle this project should resign like what JP did. If they find an outsourced guy that will be successful, that will be the end of the firmware group. Malamang may mag sabotahe huwag lang gumana.
Online glutnix_neo
« Reply #19 on: February 19, 2011, 09:22:07 PM »
sir motion,
joke lang yung mahirap, inaantay lang namin magreact si jet pangan ;D ;D ;D
kulang lang talaga kami sa manpower ngayon.
