Author Topic: programming arduino  (Read 846 times)
Offline veronica
programming arduino
« on: February 20, 2011, 06:34:10 AM »
i am trying to light up an LED for 3 seconds when there is a value "1" in the serial port and turn it off afterward. when there is no value, then the LED is off. i've made this code but it only turns the LED on constantly.
please help.:)
  const int ledPin = 13;      // the pin that the LED is attached to
  long previousMillis=0;  //previous millisecond
  unsigned long currentMillis = 0;//current millisecond
  int SerialValue=0;
void setup()
  // initialize the serial communication:
  Serial.begin(9600);
  // initialize the ledPin as an output:
  pinMode(ledPin, OUTPUT);
void loop() {
  SerialValue=0;
  previousMillis =0;
  currentMillis =0;
  if (Serial.available()) {
    SerialValue = Serial.read();
    if (SerialValue == '1') //if SerialValue = 1, turn LED on for 3 seconds
      previousMillis = millis();
        currentMillis = millis();
    while(currentMillis - previousMillis <= 3000)
        digitalWrite(ledPin,HIGH);
        digitalWrite(ledPin, LOW);//turn LED off after 3 seconds
    else //if SerialValue is not = 1, LED off
programming arduino
Offline motion55
  • Pogi/Ganda Points: 244
Re: programming arduino
« Reply #1 on: February 20, 2011, 09:10:28 AM »
I have a suggestion and a question.
Try changing "long previousMillis" to "unsigned long previousMillis".
unsigned long previousMillis=0;  //previous millisecond
In the ff. statement:
You are subtracting (signed)previousMillis from (unsigned)currentMillis. I don't know the behavior when millis() is returning a large number. It could be interpreted as a negative number on previousMillis and positive on currentMillis even if they are almost at the same time. Performing the subtraction (currentMillis - previousMillis) will result in a large value greater than 3000. The program will immediately turn OFF the LED.
As a recommendation for better programming practice, you should not lock the program within a blocking loop inside the function loop(). The following code will allow the Arduino board to do something else while waiting for a serial port character to arrive.
int SerialValue=0;
void setup()
    Serial.begin(9600);
void loop()
    SerialValue=0;
            previousMillis  =   millis();       // save the time the LED was turned ON.
    if ((currentMillis  - previousMillis) <= 3000)
        digitalWrite(ledPin, LOW);//turn LED off after 3 seconds from previousMillis
My next question is:
Are you sure low is OFF and high is ON on the LED? On some circuits, low is ON (active low) and high is OFF for driving LEDs. Just being sure.
"Set your mind free!"
Offline motion55
« Reply #2 on: February 20, 2011, 09:31:59 AM »
Oops.. Sorry. Please modify the suggested code above as follows:
int SerialValue=0;
void setup()
    Serial.begin(9600);
void loop()
    SerialValue=0;
    if ((currentMillis - previousMillis) >= 3000)
Offline veronica
« Reply #3 on: February 20, 2011, 11:43:21 AM »
thanks for the reply.. ung code po na bngay nio sinubukan ko po sya i-run..pero ndi po nia napapailaw ung LED ng 3 seconds..hinahanap ko san ng ung mali pero tama naman sya dapat..
Offline motion55
« Reply #4 on: February 20, 2011, 11:47:39 AM »
Ilang seconds siya umiilaw?
Offline veronica
« Reply #5 on: February 20, 2011, 12:00:59 PM »
ahmm..continuous po..ska nailaw lng sya pag continuous din ung "1" sa serial port. gusto ko po sana kasi parang momentary lang ung pag send ko ng "1" :)
Offline toasted siopao
  • Global Moderator
  • Pogi/Ganda Points: 107
    • TeknoBlogger
« Reply #6 on: February 20, 2011, 12:09:36 PM »
di kaya dapat i-clear mo buffer ng serial mo?
wala ako experience pa sa arduino.
Offline veronica
« Reply #7 on: February 20, 2011, 12:28:24 PM »
pno po icclear ung buffer?
Offline motion55
« Reply #8 on: February 20, 2011, 12:43:18 PM »
Linawin natin ha. Importante ito in diagnosing the cause. Pag ON ng Arduino board, patay ang LED. As soon as nasend ang '1' character, mag-oON ang LED at ayaw na mamatay. Please confirm.
  • Global Moderator
    • TeknoBlogger
« Reply #9 on: February 20, 2011, 12:46:44 PM »
void setup()
    Serial.begin(9600);
    digitalWrite(ledPin, LOW); <---- singit mo ito para sure na OFF ang LED sa umpisa
Offline motion55
« Reply #10 on: February 20, 2011, 12:53:40 PM »
Kung nag send ka ng ibang character, like a '0' for example, namamatay ba ang LED? Pag ayaw baka naman maling port nakakabit ang LED?
Offline veronica
« Reply #11 on: February 20, 2011, 01:26:16 PM »
ahmm..ganto po..pag on ng arduino, off ung LED. mag ON lang sya pag nagsend na ko ng "1" then, off na kgad pag inalis ko na ung "1".. pag continuous lang ako nag send ng "1", continuous ON lang din sya.
Offline motion55
« Reply #12 on: February 20, 2011, 01:46:21 PM »
Try this modified code. Describe the result as clear or more detailed than above reply.
int SerialValue=0;
void setup()
    Serial.begin(9600);
void loop()
    SerialValue=0;
    if (Serial.available()>0)
        Serial.flush();
        else
        if (SerialValue == '0')
Dapat if you send a '1' mag ON and if you send a '0' mag OFF.
Offline veronica
« Reply #13 on: February 20, 2011, 01:55:56 PM »
nag ON siya pag my "1" at OFF pag "0". ayun na po un. possible po ba n lagyan un ng time. ung pag ON nia my time na 3 secs. saka pwede ako my press ng switch para mahinto ung pg ON nia ng 3 secs? halimbawa po, nakaka 1 sec pa lang sya n ON pwede na ko mg switch para OFF na kagad siya?
Offline motion55
« Reply #14 on: February 20, 2011, 02:38:08 PM »
That is actually the next step. Here is the modified code:
int SerialValue=0;
void setup()
    Serial.begin(9600);
void loop()
    SerialValue=0;
        Serial.flush();
        if (SerialValue == '1' &&  previousMillis==0)
        else
            previousMillis = 0;         //Rearm the timer
    if ((currentMillis - previousMillis)>=3000 && previousMillis!=0)
Offline veronica
« Reply #15 on: February 20, 2011, 04:48:34 PM »
i uploaded the code but still the same results.:(
Offline motion55
« Reply #16 on: February 20, 2011, 06:05:44 PM »
Same results with what? I getting tired of this. Bahala ka na lang.
« Reply #17 on: February 20, 2011, 06:20:15 PM »
naku, kulang kulang kasi kung sumagot, pinapahulaan pa kung ano ang ibig sabihin.  Tutal ayan lang naman ang ginagawa ng code mo, kalimutan mo na yang millis na yan at gumamit ka na lang ng delay() routine, tapos na ang problema mo.
Offline veronica
« Reply #18 on: February 20, 2011, 06:27:49 PM »
i'm sorry..:( but thanks for all your help..
Offline motion55
« Reply #19 on: February 20, 2011, 07:51:56 PM »
One final advice. Malamang may problema ang millis(). Guess ko that is why namamatay ang LED kaagad. I think sobrang mabilis ang clock. Perhaps mali ang hardware. But since there is no information that is only a best guess ko. Good luck na lang.
