Author Topic: programming arduino  (Read 844 times)
Offline SArioDabidG.
  • Pogi/Ganda Points: 7
  • Gawa lang ito ng tao. Kaya natin ito!
Re: programming arduino
« Reply #20 on: February 21, 2011, 08:06:35 AM »
Here's my code that uses millis() function to generate delay:
  const int ledPin = 13;  // the pin that the LED is attached to
  int serialValue=0;      // variable to hold your serial data
  long interval = 3000;   // time in 3seconds
  long previousMillis = 0;  // will store last time
// setup is executed once
void setup()
  // initialize serial communication:
  Serial.begin(9600);
  // initialize the ledPin as an output:
  pinMode(ledPin, OUTPUT);
  // ledPin13 is off first
  digitalWrite(ledPin,LOW);
// loop is always running
void loop()
  // if data is received in serial buffer register
  if (Serial.available() > 0)
    // read the data and save to a variable
    serialValue = Serial.read();
    // parse the data
    // if '1' is read
    if(serialValue == '1')
      // activate led on arduino Pin13
      digitalWrite(ledPin,HIGH);
        // implement 3s delay using timer module
        // save time to a variable
        unsigned long currentMillis = millis();
        // check the time if greater the 3s
        if(currentMillis - previousMillis > interval)
          // update time
          previousMillis = currentMillis;
          // clear buffer register and data variable
          Serial.flush();
          // turn off led
          serialValue = '0';
    // if '0' is received
    if(serialValue == '0')
      // turn led off on arduino Pin13
Heres another code using delay function:
void setup()
  Serial.begin(9600);
void loop()
    // parse the data
    // if '1' is read
        delay(3000);
          Serial.flush();
          // turn off led
          serialValue = '0';
"One way to back-up your codes is to post them in forums and let others store them for you."
