Author Topic: UPGRADING CCFL TO LED BACKLIGHT  (Read 1193 times)
Offline Vaounsi
  • Pogi/Ganda Points: 146
« on: February 23, 2011, 04:52:03 PM »
may nakapagtry naba nito? saan makabili? ::)
 XB LED Backlight Kit for Laptop Screen:
Much easier to install compare with CCFL replacement, anyone can do it! No technical skill requires. No Soldering skill requires!
The XB series is designed 9 LEDs in a string and total 6 Strings. XB series LED backlight kit comes with a custom Converter. By Upgrading to XB Series, The brightness level will be increasing about 100% compare with CCFL Lamp.
These LED backlight kits are compatible with following screen sizes:
14.1” WXGA, 14.1” WXGA+, 14.1” WSXGA
15” XGA, 15” SXGA
15.4’ WXGA, 15.4” WXGA+, 15.4”WSXGA, 15.4” WUXG
XB Series LED Backlight kit comes with a custom build Converter and one LED Strip
How to connect LED converter?
Identify the pin assignment of your inverter.*
Obtain MS406LEDC converter pin assignment*
Match pin assignments and Connector MS406LEDC to the inverter’s wire harness
The LED Backlight Advantage:
Improved Dynamic Contrast Ratio
Improved Color Gamut for more Lifelike Images
longer lifespan,typically lasting over 100,000 hours
High shock/Vibration resistant
Low Heat Generation.
Environmental Benefits.
Follow these 3 easy steps to upgrading from CCFL to LED Backlight:
Step1:
Disassembly Laptop screen, It is the exact same procedure as replacing CCFL backlight Lamp. Set aside CCFL Reflector assembly (No longer need it).
Remove double side tape cover on LED Strip
Step2:
Tape XB LED Strip at the bottom edge of Laptop Screen, where it use to mount CCFL Backlight.
Step3:
Re-assembly Laptop screen. It is the exact same procedure as replacing CCFL backlight Lamp. Connect Flat cable to LED Converter.
Connecting LED converter to Laptop computer:
XB Series LED converter (MS406LEDC) is designed to be direct replacement of the Laptop inverter. The input pin assignments are compatible with most of Inverter. However, in some cases, you cannot find your model listed. Then you need to purchase a universal XB Kit. This kit comes with a 6 pin wire harness.
Offline wesley14
Re: UPGRADING CCFL TO LED BACKLIGHT
« Reply #1 on: March 01, 2011, 05:28:05 PM »
very interesting. How much naman po ung kit nian?
Offline sergs
« Reply #2 on: February 06, 2012, 07:06:36 AM »
picture naman dyan sir.
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #3 on: February 06, 2012, 07:38:44 AM »
WootsPC2 Videos  Woots Page
Offline ronelex
  • Pogi/Ganda Points: 6
  • JR Computer Technician
    • Ronelex Repair Blog
« Reply #4 on: February 06, 2012, 03:14:05 PM »
wow, very interesting. may kit na rin para maging LED ang CCFL back light, may nakita ako sa net pinalitan ng mga LED yung mga ccfl pero mejo mahirap ang proceso pati na yung pag kabit ng supply sa mga LED :)
Offline MaxieGodde
« Reply #5 on: March 09, 2012, 02:38:10 PM »
gusto ko pa to sana imodify bale yung switching ng light nya tigdadalawa or tigtatatlo or adjustable xa per LED(strobe effect ba yun?   hihih) yan kase alternate lang.. tig iisa. any idea po. plz....im using LM555 IC. to pala diagram ko...
  • Pogi/Ganda Points: 909
« Reply #6 on: March 09, 2012, 04:03:50 PM »
na ka pagtry naku  nito... sa labas sa warranty  ;D
so far so good  ;D
Offline mieebucy
« Reply #7 on: May 22, 2012, 01:27:06 PM »
There are two wires, both transparent, but one wire has a red stripe the other does not.
Any idea to figure out which is positive and which is negative? 12v.
