Author Topic: Bluetooth Module for Sale (Brand New)  (Read 3109 times)
Offline PlCUSER
  • Pogi/Ganda Points: 154
Re: Bluetooth Module for Sale (Brand New)
« Reply #40 on: June 23, 2011, 11:04:30 AM »
REPRICED: Now ONLY 750.00 PHP / pc
1000.00Peso Bluetooth Module
Size Comparison:
20pcs comming this 27th June.
salamat.
« Reply #41 on: June 23, 2011, 11:30:23 AM »
specifications? class? interface? power ratings?
Offline PlCUSER
« Reply #42 on: June 23, 2011, 11:35:28 AM »
interface:
Configuration:
URL]
Class: ClassII bluetooth module
upadate ko ung iba mamaya sir.
« Reply #43 on: June 23, 2011, 11:50:21 AM »
actually, wala naman ako intention bumili... heheh ;D ;D ;D
Gusto ko lang matulungan yung iba.
Suggestion, kung makakaprovide ka pa nga ng footprint ng board mas ok. most kasi ng bibili sayo ay mga students. Most of them don't have much experience.
Sample design interface will also help your buyers. :)
Madami ka pa namang oras... isang buwan pa. ;)
Offline PlCUSER
« Reply #44 on: June 23, 2011, 12:01:03 PM »
yes sir. alam kong para sa iba ung intention mo na yun. ;D
maraming salamat po.
and maraming salamat po uli para sa advice mo na un.
may package lang akong parating kaya nagpasabay lang ako ng 20pcs. kaya rin nag update ako ng thread.
inuna ko lang update ung pinaka importante sa nagbebenta, ung presyo. ;D
Offline PlCUSER
« Reply #45 on: June 30, 2011, 08:08:59 PM »
UART Bluetooth Module with Host/Slave function.
 -Host Bluetooth Module can easily connect to bluetooth device ie. cellphone, even if cellphone doesn't have additional 3rd
  party applications.
 -UART Bluetooth Modules can communicate with each other only when 1 module is configured as Master and the other
  module is configured as slave.
UP tonight.
Offline PlCUSER
« Reply #46 on: July 01, 2011, 08:37:06 PM »
up.
Offline PlCUSER
« Reply #47 on: July 03, 2011, 09:43:11 AM »
up this morning. only 750.00 pesos.
Offline downloaderer
« Reply #48 on: July 12, 2011, 11:38:48 PM »
meron po ba jan arduino compatible na BT?? baka kase mag ganyan nalang ako kesa zigbee.. mahal kase nun eh..
Offline PlCUSER
« Reply #49 on: July 13, 2011, 09:28:42 AM »
arduino compatible naman yan. 3.3v tolerant. 5v ata ang arduino. you can just use voltage divider from arduino tx to bt rx.
just to remind you, class II bt module has distance of 10meters. while standard zigbee is longer. but if 10m is enough with your project, bt is ok.
Offline poorgrammer
« Reply #50 on: August 15, 2011, 10:53:54 AM »
sir, newbie question po. anu po ang minimum circuit setup sa module na to? kung ang kailangan ko po ay basic rs232 communication function, ok lang po ba na i-supply all VCC ang GND connections and then use only the uart-tx at uart-rx and connect it to the db9 connector corresponding tx/rx pins (gagana na po ba)?
Offline poorgrammer
« Reply #51 on: August 15, 2011, 10:56:11 AM »
sir, newbie question po. anu po ang minimum circuit setup sa module na to? kung ang kailangan ko po ay basic rs232 communication function, ok lang po ba na i-supply all VCC ang GND connections and then use only the uart-tx at uart-rx and connect it to the db9 connector corresponding tx/rx pins (gagana na po ba o need po i setup yung exact wiring at components sa diagram provided)?
Offline PlCUSER
« Reply #52 on: August 15, 2011, 11:08:42 AM »
kung pc rs232 mo ikakabit, you will need rs232 level converter like max232 or ds275. 3.3v level kasi yang bluetooth module. 10 -15v ang rs232. kung sa 3.3v mcu uart mo icoconect, diretso ka na lng.
just supply the bluetooth module with 3.3v, ready na ang tx rx pins nyan with default settings.
Offline poorgrammer
« Reply #53 on: August 15, 2011, 11:38:56 AM »
ok tnx sa info sir
Offline poorgrammer
« Reply #54 on: August 15, 2011, 02:33:44 PM »
up!
excited na ako sa bt module ko. sabayan ko na to ng crash course to basic electronics.
Offline PlCUSER
« Reply #55 on: August 15, 2011, 04:54:33 PM »
basa basa ka lang dito sa elab. madami kang matututuhan sir
Offline poorgrammer
« Reply #56 on: August 15, 2011, 05:00:06 PM »
oks tnx sir. medyo na hihipnotize na nga ako sa mga info eh. wala kasi ako experience sa microcontroller at electronics, maliban lang sa konting exercise at lessons nung college tungkol sa MC6800 microprocessor at micro-controller programming gamit yung assembly.
Offline poorgrammer
« Reply #57 on: August 17, 2011, 09:16:21 AM »
tested my bt module last night (tnx for the item sir. ang bilis ng delivery, na exite agad ako). the module got successfully detected and paired with the macos, windows7 and android2.2. sa windows, nagkaroon ako ng 2 virtual serial ports. with a simple c# program using serialports io library, i was able to connect and disconnect to the 2 virtual serial ports at the same time (tig isang connection). ang galing. hehehe.
Q: newbie question po sir (sensya na), panu po ang mapping ng 2 virtual serial ports sa actual pin out ng BT module? (pin 1 tx, pin 2 rx <-- bali sir, anung virtual com port ang naka map sa pin outs na to? or sa anung pin outs pa ako makakakuha ng physical serial connection?) (sa unang pag kaka akala ko (which is mali) ay bibigyan ako ng isang virual com port lang ng BT module which maps directly to the pin1 and pin2. since 2 virtual serial port ang binigay ng module,. edi mas maganda.. baka sakaling hindi lang isang device ang pwede ko i communicate at one BT connection (pwede bang 2 serial device ang naka connect dun sa pin1 at pin2?).)
will try out the physical serial connection part later in the evening.
tia!
Offline PlCUSER
« Reply #58 on: August 17, 2011, 09:32:04 AM »
isa lang sa virtual com ang pwd mong magamit to connect sa uart bluetooth module. to check which port, go to your bluetooth property window, may tab dun for hardware setting. indicated dun which of the 2 virtual com ang para sa bluetooth module mo.
for a start, try to do echo test. send char to bluetooth module using windows serial terminal na gamit mo, and short tx rx pin ng bluetooth module. you should see the char you sent on the bt module in your terminal windows.
ingat sa pag solder sa tx rx pins. madaming users nyan ang naputulan ng connection sa tx rx sa pagtanggal kabit ng wires.
Offline poorgrammer
« Reply #59 on: August 17, 2011, 09:38:28 AM »
tnx sa info sir. ayun pala. yup, yun nga din naisip ko sir, kaya di ko pa ni sosolder yung connections. hanap pa ako ng tray na may mga paa na pwede patungan ng BT module (yung parang tray ng mga ic chips) habang testing palang. inipit ko lang muna yung terminals nya kagabi sa breadboard para ma test.
