Author Topic: Tony's 6H32 pre-amp  (Read 3236 times)
  • Pogi/Ganda Points: 520
Re: Tony's 6H32 pre-amp
« Reply #20 on: March 04, 2011, 03:30:26 PM »
3000 sa preamp pa lang sis Tony??
mura na yang gawa ko, yung TONO violin na localy pruduced preamp nasa 18k......
  • Pogi/Ganda Points: 412
« Reply #21 on: March 04, 2011, 03:39:44 PM »
waaaaaa.....3k isang buwan na sahod na yan ng iba...:P
« Reply #22 on: March 04, 2011, 04:51:24 PM »
kalahating araw ko lang yan sa abroad.........hehehehe.....
« Reply #23 on: March 04, 2011, 05:14:28 PM »
huhuhuhu...iba talaga ekonomiya sa labas...tsk...
  • Pogi/Ganda Points: 411
« Reply #24 on: March 04, 2011, 05:43:21 PM »
Di bale sis makakagawa ka rin nyan.
Offline NORTH LUZON
  • Pogi/Ganda Points: 812
« Reply #25 on: March 04, 2011, 07:07:10 PM »
wak ka na umiyak ate kasamiko
ask mo nalang exact address ni master tony at akyatin mo ung preamp nya (akyat bahay gang)
« Reply #26 on: March 04, 2011, 08:06:10 PM »
yes, every one is welcome to hear this preamp at my house....245 m.h. del pilar street, palatiw, pasig city...call 628-2996 before you come.....
« Reply #27 on: March 05, 2011, 11:26:27 AM »
Nyahahaha! gaga! bad influence ka talaga....
« Reply #28 on: March 05, 2011, 02:05:34 PM »
Paluin ka nyan ni sir tony kapag ginawa mo, kasi baka mahulog ka pa.  ;D  ;D
Pakinggan na lang tunog nun.
« Reply #29 on: June 03, 2011, 08:46:20 PM »
update:
higher B+ and transparent casing:
  • Pogi/Ganda Points: 316
« Reply #30 on: June 03, 2011, 09:09:08 PM »
^ang ganda po master tony, lalo pat transparent! :)
Offline a.out (drako65)
  • Pogi/Ganda Points: 30
« Reply #31 on: June 07, 2011, 11:29:36 AM »
sir tony,
pwedeng mag-order? Magkano po?
thanks
od</dev/urandom
« Reply #32 on: June 07, 2011, 12:05:13 PM »
sir tony,
thanks
pwede, 4,500...
« Reply #33 on: June 07, 2011, 12:40:18 PM »
Sir Tony,
I'm interested to have your 6H32 pre-amp.
Wala na bang tawad ang 4500? he he.
Gusto ko lang kasing subukan ito. Just a newbie amplifier enthusiast.
Kaso sa Iloilo pa ako. Pwede namang LBC siguro?
Tanong lang po:
Pwede pa itong setup?
1. PC sound card ---> 6H32 pre-amp ----> amp --> speakers
2. PC sound card ---> 6H32 pre-amp ----> heaphones
kapag bi-amping po, saan ang pre-amp?
source ----> preamp ---> xover ---->amp1, amp2
Di ba naman magastos sa kuryente kapag may tubes na?Mga ilang watts ba consumption nya?
od</dev/urandom
Offline pEN DoTA
« Reply #34 on: June 10, 2011, 05:58:25 AM »
Sir Tony,
Tanong lang po:
magandang tanung yan. sana may tawad pa.
by the way makabili po ba tayo ng mga parts dito sa pinas sir tony?
GOD LOVES YOU
« Reply #35 on: June 10, 2011, 07:51:50 AM »
Sir Tony,
Tanong lang po:
preamp lang ito, so nasa 6 watts max ang consumption...
pwede and iniisip mong set-up...hindi pwede sa headphones..
mura na ito, sa ngayon meron akong 7 orders confirmed....
hindi available ang tubes locally, magpaparating pa lang ako, mga 4 to 6 weeks....
Offline chinokscapsighter
  • Chinoks_capsighter the imaginative painter.......
« Reply #36 on: June 26, 2011, 09:57:27 AM »
Sir's pwede ba gawing balance ang output at input ng preamp nato....?
« Reply #37 on: June 26, 2011, 12:58:17 PM »
pwede......kaya lang ibang chassis na ang gagamitin, di nakakasya sa HC-091 na casing.
« Reply #38 on: June 26, 2011, 01:06:15 PM »
Magkano ang nagastos mo sa pre-amp nato Sir"s.....?
Offline Tukkar
  • Pogi/Ganda Points: 23
« Reply #39 on: July 06, 2011, 04:02:16 PM »
Mukhang magandang pares ng Luxman ko ito ah...
Tubes revolution on the way....sayang solid state na kasi ako nag umpisa...but anyway trying to do tubes amps...and I'm sure marami ako mapupulot sayo...hehehe
