Author Topic: Vinegar + Hydrogen Peroxide + Salt = Etching Solution  (Read 3340 times)
Re: Vinegar + Hydrogen Peroxide + Salt = Etching Solution
« Reply #60 on: July 20, 2011, 11:52:54 AM »
iba kaya...yung household pagbukas walang fumes..yung industrial may usok..at mas mabilis yung industrial grade...nonetheless household grade ok rin medyo mabagal lang compared sa industrial..
parehas muriatic. hehehe.
  • Pogi/Ganda Points: 412
« Reply #61 on: July 20, 2011, 12:19:43 PM »
nyahaha...dito samin marami ang dalawang klase na yan..pati yung Aqua Oxinada dalawang klase rin..
« Reply #62 on: July 20, 2011, 03:23:42 PM »
agua blue and red. parehas din naman agua...
hek hek.
Offline jaguar3275
  • Pogi/Ganda Points: 126
  • BAKLA LANG ANG MAGTAMPO AT MAG EMOT2X!!!
« Reply #63 on: July 20, 2011, 03:35:49 PM »
sa volumes cguro nagkakaiba kung ilang percent, household at industrial
Exodus 15:2 The LORD is my strength and my song, and he has become my salvation; this is my God, and I will praise him, my father’s God, and I will exalt him.
« Reply #64 on: July 20, 2011, 04:28:53 PM »
TAMA! meon 10% meron naman 20% volumes
Offline viel_dk
« Reply #65 on: July 22, 2011, 12:56:01 PM »
ma try nga yang hydrogen peroxide+salt+vinegar na yan...
bagal kasi ng etching sa ferric chloride
thanks sa mga info :)
no past, no future......
Offline o0oyaskaio0o
« Reply #66 on: September 11, 2011, 11:09:06 AM »
thanks ts. .
1 point 4 u sir. :D
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« Reply #67 on: November 02, 2011, 10:57:46 AM »
Yung muriatic sis dalawang klase yan..yung pang household at industrial strength....pero same price...at least dito sa amin...yung industrial ginamit ko ang bilis ng etching...
Ano nga pala sir ang proportion ng muriatic ACID saka H2O2?
  • Pogi/Ganda Points: 53
« Reply #68 on: November 02, 2011, 11:03:58 AM »
Masmakakatipid ba kung ganitong etching solution gagamitin natin?
Yung asin mura :D
Yung vinegar sa tindahan lang ni aleng Nena :D
Yung Hydrogen Peroxide Magkano ???
Tapos mas efficient po ba ito? I mean pwede pa ulit gamitin yung solution after use?
« Reply #69 on: November 02, 2011, 09:42:31 PM »
basta ako 1 is to 3....
4x6 PCB ng Alexan done flat within 3 minutes..
Offline nucleus
« Reply #70 on: November 02, 2011, 10:54:04 PM »
matgal pala
« Reply #71 on: November 02, 2011, 10:55:00 PM »
^ YMMV.
Daty kung may toyo.
Offline profpat
  • Pogi/Ganda Points: 9
  • "pag gawa ng tao! kaya natin ayusin"
    • LCD REPAIR PHILIPPINES
« Reply #72 on: November 02, 2011, 11:04:49 PM »
i bought muriatic acid( concentrated) and hydrogen peroxide (20%), yesterday at SM, hope to mix them soon and etch some copper boards..
sana makuha ko tamang timpla..
« Reply #73 on: November 03, 2011, 09:57:57 AM »
you don't even need a brain para dito...
1 Muriatic + 2 Hydrogen Peroxide..
remember to ADD ACID to Hydrogen Peroxide NOT the other way around..
Offline pishboy
  • Eternal Flame
    • bosshardhans.comuf.com
« Reply #74 on: November 03, 2011, 09:04:21 PM »
i think the solution is the same as HCl + H2O2
acetic acid = CH3CO2H (according to wikipedia
salt = NaCl
Cl + H = HCL right?
so you end up with HCl and Na + CH3CO2 which can react into Sodium acetate?
Pa-clarify, theory only...
-pirma-
  • Make it simple
« Reply #75 on: November 03, 2011, 10:51:07 PM »
Mabilis nman yata to kumpara sa Fecl2.
Thanks sa info sir.
  • Make it simple
« Reply #76 on: November 03, 2011, 10:54:17 PM »
salt = NaCl
Cl + H = HCL right?
Alin nman po ang mag-react sa copper?
  • Make it simple
« Reply #77 on: November 03, 2011, 11:27:26 PM »
Napag-isip ko tuloy dapat ganito ang formula.
2HCl + H2O2 + Cu2 = 2CuCl + 2H2O
Hydrogen ion is removed from HCl, with it being aqueous, and reacts with the reactive oxygen from the peroxide to form water, leaving the Chlorine ion react and combine with the metallic copper to form copper chloride.
But HCl will not react with the metallic copper without the hydrogen peroxide because copper is not much reactive than hydrogen to Chlorine.
So dapat pala ang ratio ay 2:1
2 Muriatic + 1 H2O2
hehe, sorry po but i stand corrected to other ideas base on theory.
Offline pishboy
  • Eternal Flame
« Reply #78 on: November 04, 2011, 03:45:53 AM »
Small theory as to why I think the salt vinegar agua oxinada solution is similar to the HCL H2O2 solution
It's not really an explanation kung bakit sya nakaka-etch.
Again theory only, IDK if it's true. I'm partly sure for the acetic acid + salt = HCl but not sure with the HCl and Na + CH3CO2 into sodium acetate. Sorry if i'm wrong but i'm open to correct answers.
-pirma-
  • Make it simple
« Reply #79 on: November 04, 2011, 06:45:30 AM »
Tama ka nga, pareho nga lang sila.
Sodium acetate lang yung nadagdag.
Vinegar + Hydrogen Peroxide + Salt = Muriatic acid + Hydrogen Peroxide + Sodium acetate.
Ganun lang ang kinalabasan, ang kailangan lang maitama ay gaano kadami ang bawat isa. Pero dahil gumana na yung proportion na naibigay sa una, sundin na lang.
