Author Topic: sony TV troubleshooting share  (Read 1154 times)
Offline x13r_kit_0
  • Pogi/Ganda Points: 151
  • --__x13r_kit_0__--
« on: March 08, 2011, 06:15:43 PM »
share ko lang to baka sakali may mangailangan at makatulong sa elab members.. ;) ;)
pero mas maganda troubleshooting w/ your own..goodluck mga sus!! ;)
Size    Model    Chassis    Symptom    Problem Description    Fix
29   KV-29XBR85   ANU-1   Power   Relay clicks, but no B+ from power supply   STR6301A, and test power supply for bad caps
30   KV-29XBR85   ANU-1   Power   No raster, No audio, HV is present   IC1502 on D board
30   KV-29XBR85   ANU-1   Video   No Video or Audio, but has OSD   Resolder IC3201 (#875914204, on the P board)
32   KV-32FS10   AA-2   Video   Very faint video on light gray screen   IC354
32   KV-32FS10   AA-2   Video   no color   IC1001 (D/A converter #8-752-058-68)
32   KV-32FS10   AA-2   Video   intermittent horizontal pie crusting   L505 (#1-406-976-11, 68uH, on A board)
32   KV-32FS10   AA-2   Video   no color, picture good but in Black & White   IC1001 (CXA1315M, D/A converter #8-752-058-68)
32   KV-32FS120   BA-6   Dead   Dead   D534 on A-Board
32   KV-32FS120   BA-6   Dead   Dead, relay clicks, 4 blinks   IC702
32   KV-32FS120   BA-6   Dead   Set shutsdown and standby blinks 3 times then 5 times.   IC702, C541, R553
32   KV-32FS120   BA-6   Dead   Dead   D611, Q600, Q601, R615 (all on A board)
32   KV-32FS120   BA-6   Dead   Dead   resolder Q606
32   KV-32FS120   BA-6   Dead   Dead, Standby flashes 4 times   T604, IC601
32   KV-32FS120   BA-6   Power   won't power up, LED blinks 4 times   D611 (on A board)
32   KV-32FS120   BA-6   Dead   Dead, no sound or pic   flyback, Q502, R615
32   KV-32FS120    BA-6   Dead    Dead, 5 blinks    D611 (in power supply), Q502 (HOT, shorted on A board)
32   KV-32FS120       Power   no power, flashes 9 times   R610, Q690
32   KV-32FS13    BA-5   Tuning    Channel stays the same despite OSD changing    D2002 (on from of MA board)
32   KV-32S40    AA-2   Dead    bad tuner, burnt power supply    Removed tuner, replaced with rebuilt tuner. Replaced caps in Power supply G-board
32   KV-32S40    AA-2   Video    No video, has sound, timer light flashes continuously    C368 near IC351
32   KV-32S42    AA-2   Picture    Gets dark and rolls, like AGC or sync problem    C3501 (47uF/25V) on B board behind tuner
32   KV-32S45    AA-2   Video   Sound, but no picture    Used Sencore CR-70 to rejuvenate the screen
32   KV-32TS36    AA-1    Video    Picture was dark    Rejuvenate CRT
32   KV-32XBR250   AA-2   Video   No color in pic   IC1001 (D/A converter #8-752-058-68)
32   KV-32XBR400   ANU-1   Dead   Dead, may be intermittent   IC6501=IC8002 (MCZ3001DB or Hitachi #CP08451U)
32   KV-32XBR450   ANU-1   Power   shuts down with 4 blinks   Bad solder on CN3 on bottom of yoke PCB
32   KV-32XBR450   DX1A   Dead   Dead or intermittent power on   Replace both power supply controller ICs (MCZ3001D)
32   KV-32XBR51   ANU-1   Power   Pic or sound intermittent, sometimes lines flashing in pic   Resolder IC581 and IC582
32   KV-32XBR51   ANU-1   Power   Wont power on, but clicks   Resolder D659
32   KV-32XBR51   ANU-1   Video   Intermittent bright white with retrace lines   Resolder flyback pins
32   KV-32XBR51    ANU-1   Video   Pincushion is bad or Narrow Pic   Replace L501 (#14914813), T501, C524 (.047uF)
32   KV-32XBR70    ANU-1   Video   Lines would appear at top of screen after .5 hours of use    L1502 (33uH, on A Board, #1-408-247-00)
32   KV32FS120       Dead   shuts down and blinks 9 times   Video amp IC on CRT board
32   KV32FS120       Dead   Dead, LED blinks 9 times   D647, R610
34   KD-34XBR960   DA-4   Dead   Dead, led blinks constantly   2x MCZ3001
34   KV-34XBR910   DA-4   Dead   shutsdown on power up, with 7 blink code   Flyback (#1-453-464-11)
36   KD-36FS130   BA-6   Power   TV intermittently does not come on   D647 (#650056701, on A board)
36   KD-36FS130   BA-6   Power   set turns itself on intermittently   D647 (#65005670
36   KV-36HS420   DA-4   Power    Set shuts down with 6 or 7 blinks   C6556 (33uF,160V)
36   KV-36HS420   DA-4   Dead   Dead, 7 Blinks   IC6501=IC8002 (MCZ3001DB or Hitachi #CP08451U)
36   KV-36XBR400   ANU-1   Power   Powers up for a few seconds, then shuts off    SMPS controller in Power supply (MCZ3001D, use Hitachi CP98451U)
40   KDL40S2010   WAX2   Dead   shuts down with 4 blinks   Inverter board (#1-789-500-32)
43   KP-43T70    RA-3   Dead   Dead   C608 (10uF/400V), R607 (4.7ohm), D602 (#8-719-068-00)
43   KP-43T70    RA-3   Dead    Dead    Replace HOT, Q502, L503 and fuse
43   KP-43T70    RA-3   Dead    Dead, replacing blown HOT results in repeat failure    Replace HOT and Flyback transformer simultaneously
43   KP-43T90   RA-3B   Video   No video, but had OSD, bad convergence   C666 (220uF/10V)
46   KDF-46E2000   LCD   video   Pink bar across top of picture   Replace optical block
46   KP-46S55    AP   Dead    Repeat failure of Q508    Q508, C512
46   KP-46V25    RA-1   Power   Power Relay cycles on and off    IC652 on G Board
46   KP-46V25    RA-1   Power   HV would pulsate on/off unless antenna was removed    IC301
46   KP-46WT520   AX-1X   Dead   set is dead, led blinks 9 times   D6301 (#6-500-567-21, on G board)
48   KP-48S35    RA-2   Audio    No Audio, Pic OK    C672 in power supply (12V regulator filter)
53   KP-53HS10    RA-4B    Video   screen flickers when on 1080i input    C693, C694, C696, R600, Q553, R698, C638, Q552
53   KP-53HS10    RA-4B    Power   shuts off when channel changes or with magic focus    splitter block (#859895514)
53   KP-53S15   RA-1   Dead   F1601 blows   IC1601, IC1602 (convergence Ics)
53   KP-53S15   RA-1   Power   power and front led cycle on/off   IC301 (CXA1477AS, #8-752-063-50)
53   KP-53S15    RA-1   Dead   totally dead    T603 (standby transformer), C667 (470uF/25V)
53   KP-53S15    RA-1   Video   No vertical, may cycle on and off   IC301 (CXA1477AS, #8-752-063-50)
32   KV-32HRS10        Picture    Pic has venetian blinds    R527 (.47ohm, near flyback)
32   KV-32S10    AA-1    Video   Audio, but no picture    Used Sencore CR-70 to rejuvenate
   =How about the other side?=
Offline RhUNhA
  • Pogi/Ganda Points: 356
Re: sony TV troubleshooting share
« Reply #1 on: March 08, 2011, 06:26:37 PM »
thnks sis ok 2 ah ;) ;) ;)
points
Offline x13r_kit_0
« Reply #2 on: March 08, 2011, 06:41:22 PM »
Oo nga sis,malalaki nga lang,
related naman yan basta sony.,maipaalala din sakin ng ka-sis natin
pag may trouble ako,di pa kasi bihasa kaya ipasa nalang.thanks sis.
Offline westlygulay
  • Pogi/Ganda Points: 21
« Reply #3 on: March 11, 2011, 11:50:50 AM »
thanks
hindi kasalanan na ipanganak ng mahirap<br />kasalan mo pag namatay kang mahirap<br />dahil hindi ka nag sikap
Offline x13r_kit_0
« Reply #4 on: March 11, 2011, 12:48:07 PM »
may kasama pa nga yan mga sis
kaya lang di ko pa nakikita,mas maliit na model,
abangan na lang ipost ko nalang dito uli
baka may magawa kayo pareho model makatulong..
  • Pogi/Ganda Points: 231
« Reply #5 on: March 11, 2011, 01:04:20 PM »
thanks for sharing sis.. papogi ka muna..1+
Offline x13r_kit_0
« Reply #6 on: March 11, 2011, 01:44:48 PM »
Set starts up and immediately shuts down
Check Q606 collector should be Zero volts. If high replace Line scan transformer. Replacement available from SEME HR7364
No raster, field collapse but blanked out
Check the resistor in series with D804
EW fault, reduced width, TEA2031 replacement failed
Change capacitors C830 and C831 (both 1uF)
6 inch wide bands across screen (black grey white)
Replace C655 (220uF) in the 5v supply to the micro
No raster
Replaced IC651 type STR36301
Frame failing, T.TXT not workingInt no sound from surround speakers
Replace R627 in the power supply
1-141-245-00 trimmer capacitor 30pf
Field foldover
Replace C531 (1000uF,50v)
Powers up then trips off
1. Check IC251 (LA4280) for short circuit 2. Check for dry joints on 12v regulator Q608 also the other adjacent large transistors, the same fault will be experienced 1 to 2 hours after switch on
Int loss of sound and picture
Check for dry joints on the 12v regulator Q608 also resolder the chopper transformer and metal plates earth tabs
Line pulling on macrovision protected recordings
Replace jumper wire JW802, mounted in location L800 with a 330ohms,3w resistor (Pt no. 121590821)
No E.H.T, line scan drive approx 10v
Check D1504 on the scart pcb for s/c
All supply lines come up then go low (standby)
Check pin 9 of CN001, if high the set is in protection mode, disconnect the pin, if set still fails to come on replace memory chip IC002 (Pt no. 875925211)
Starts then shuts down
Remove T601 resolder joints on all pins then refit
Int loss of picture and sound
Check the 12v regulator Q808 for dry joints
o ayan nakita ko na,
21   KV-20TS27    P3B   Dead    Dead    C605 (22uF/250V)
24   KV-24FV300   BA-6   Audio   Volume keeps rising   Replace tact switches on front
25   KV-24FV12    BA-5   Dead    Dead, no standby voltage    D817 (12V zener, near T604)
25   KV-25XBR   P2B   Dead   Dead, won't power up   C1663 (in horz def)
25   KV-25XBR   P2B   Power   No pic or sound, RGB and sleep lights on   Flyback Transformer (#1-439-339-12)
25   KV-25XBR   P2B   Dead   Dead, Blown Fuse   F651 (3.15A)
25   KV-25XBR   P2B   Dead   No pic or sound, RGB and sleep lights on   Resolder L1505
25   KV-25XBR   P2B   Power   Turns on, but no video or audio   Flyback transformer (#1-439-339-12)
27   KV-2649R        Video   Picture intermittent or weak colors    IC201 (#875300140, on A Board)
27   KV-27EXR15    ANU-2   Power   Randomly Shuts Down    C517 (.1uF/250V)
27   KV-27EXR25    ANU-2   Video   Pincussion problem, intermittent    Bad solder at Q601 and Q536
27   KV-27FS13   BA-5   Dead   Dead, LED flashes 4 times   D501
27   KV-27S10    AA-1    Video    No video, audio OK    R701 (680ohm, on CRT board)
27   KV-27S22    AA-2   Picture    Picture is shifted 3inches to right    D356 (near IC351 on the A board)
27   KV-27S45    BA-4   Power   Shuts down, due to bad Vertical IC    R561 (.47ohm), IC541 (TDA8172)
27   KV-27TS35    LN-1    Audio    audio distorted   MM201 (#SBX1638-11)
27   KV-27TS35    LN-1    Tuner    tuner drifts in and out    replace tuner with rebuilt tuner
27   KV-27V42    BA-4D   Audio Buzz    Buzz in Audio    Add cap (.47uF/50V) between pins 4 and 5 of IC401
27   KV-27V42    BA-4D   Picture    Trapezoid pin distortion    D522 (#8-719-991-33, on A board)
27   KV-27V42    BA-4D   Sound    Sound takes a while to come on    C641 (2200uF/25V, on A Board)
oh eto pa pala..baka may ka-model jan,check nyo nalang dito pag medyo bangungot..
baka andito..jackpot. ;) ;) ;) ;) ;)
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #7 on: May 04, 2011, 05:44:56 PM »
tanx sa sharing master bka mkahanap ako dito ng kaparehas na model yung hindi  ko na repair .+1 ka sakin.
Offline x13r_kit_0
« Reply #8 on: May 04, 2011, 05:48:39 PM »
thanks so points..,
mga nahalungkat lang yan sa baul..,copy paste ko lang baka makatulong..
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #9 on: May 05, 2011, 10:37:27 AM »
magpalamig ka muna ito ang halo2 mo 25+1=26
Offline x13r_kit_0
« Reply #10 on: May 06, 2011, 09:48:14 AM »
another tips..download nalang.. ;) ;) ;)
