Author Topic: Sharing ENC28J60 Led Blinker Project  (Read 2451 times)
Offline 1diyMARKET
  • Pogi/Ganda Points: 4
    • 1 am 1diyTEAM
Re: Sharing ENC28J60 Led Blinker Project
« Reply #20 on: May 08, 2011, 05:24:48 PM »
for a start. what can you do with SO28 PIC18C252, DIP28 PIC18C252, and DIP40 PIC18C452 PICmicros? i am willing to write programs for it. if you can offer something nice that could benefit the elab community, i will pass these chips to you.
This is nice,   for the start.
Guys,  here, free chipset of microchip from our fellow PICuser -  kapag may EB o pa contest baka gusto niyo isama ito.  Hurry up!
Outside elab,  there are school / students / hobbyist who are called less fortunate that due to budget  or financial restriction cannot avail such material,  they might need it.
Offline PlCUSER
  • Pogi/Ganda Points: 153
« Reply #21 on: May 08, 2011, 05:36:51 PM »
Offline drx2k
    • Drx2k Network
« Reply #22 on: May 11, 2011, 10:13:50 PM »
i'll try this soon :)
Offline PlCUSER
« Reply #23 on: May 11, 2011, 11:30:51 PM »
go go go! support microchip products! ;D
Offline drx2k
    • Drx2k Network
« Reply #24 on: May 12, 2011, 06:41:18 PM »
ask ko lng po bakit di ako makaconnect sa ethernet module at PIC kpg naka connect sa router, pero kapag sa PC ok nmn, nagrerespond nmn ung module,
may kinalaman po ba ung utp cable na gamit ko, ang gamit ko kasi ay straight through cable kpg PIC >> PC
« Reply #25 on: May 12, 2011, 09:34:03 PM »
please share your setup more clearly ;) (including the IPs of every devices concerned)
Offline PlCUSER
« Reply #26 on: May 12, 2011, 09:48:22 PM »
manual set ka ba ng ip mo when you connect to pc? if yes, wat ip setting mo?
wat ip setting mo when you connect naman sa router?
Offline drx2k
    • Drx2k Network
« Reply #27 on: May 12, 2011, 10:19:30 PM »
eto po ung IP set up ng mga devices
ENC28J60 Module + PIC18F4620 (Manual Configuration
IP = 192.168.2.107
Subnet = 255.255.255.0
Gateway = 192.168.2.1
Linksys WRH54G Wireless Router (DCHP Enabled)
IP = 192.168.2.1
Gateway = 192.168.1.1
DNS = 192.168.1.1
PC (Manual Configuration
IP = 192.168.2.106
DNS = 192.168.2.1
DNS = 192.168.1.1
kapag sa router ko kinonek ung ethernet module, di umiilaw ung activity LED pero kpg sa PC umiilaw nmn
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #28 on: May 12, 2011, 10:59:43 PM »
dapat ata pag sa PC ka kumonek, naka cross cable, pag sa router straight.
parang pc to pc, kailangan cross,  then pag pc to router or pc to a switch, straight.
« Reply #29 on: May 13, 2011, 06:36:45 AM »
subscribing
Offline drx2k
    • Drx2k Network
« Reply #30 on: May 13, 2011, 10:58:12 AM »
ok na, naconnect ko na sa router..
Offline PlCUSER
« Reply #31 on: May 13, 2011, 09:57:39 PM »
great! point for you for figuring it out.
Offline drx2k
    • Drx2k Network
« Reply #32 on: May 14, 2011, 11:41:27 AM »
eto na...na-try ko na rin
http://tinypic.com/r/2pzweg2/7
Offline PlCUSER
« Reply #33 on: May 14, 2011, 11:47:28 AM »
ayos! bootloader nag try ka na?
Offline drx2k
    • Drx2k Network
« Reply #34 on: May 14, 2011, 11:54:01 AM »
di pa po..
Offline PlCUSER
« Reply #35 on: May 14, 2011, 12:14:12 PM »
eto gamit kong udp bootloader:
http://www.mikroe.com/forum/viewtopic.php?t=9093
ung hex for 18F2620 jan, pwd mo na iload sa 18F4620, without recompiling. ayos gamitin yan. you can reload firmware over the network.
Offline drx2k
    • Drx2k Network
« Reply #36 on: May 14, 2011, 12:41:20 PM »
gaano po kalaki ang ginagamit nito sa memory ng PIC?
Offline PlCUSER
« Reply #37 on: May 14, 2011, 01:06:50 PM »
nasa 8percent ata for 68Kb na pic
« Reply #38 on: May 26, 2011, 06:04:02 AM »
pwede ba ito sa 18f2550?
« Reply #39 on: May 26, 2011, 07:13:52 AM »
opo. no problem with the ENC28J60
