Author Topic: panasonic tc-2121  (Read 1036 times)
Offline judaspriestcody
panasonic tc-2121
« on: March 26, 2011, 12:10:48 PM »
help vertical may retrace sa ibabw..wer naka connect eletrolytic capacitor na nasa ilalim ng bord sa may vertical ic..help pls
panasonic tc-2121
  • Pogi/Ganda Points: 231
Re: panasonic tc-2121
« Reply #1 on: March 26, 2011, 12:19:02 PM »
palitan mo ecap sa Vertical.
post mo value ng Vertical IC at Ecap value.
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #2 on: March 26, 2011, 12:52:07 PM »
agree. replace ecap sa vertical.. lahat na..
tapos kapehan na.. ;D
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #3 on: March 26, 2011, 01:59:06 PM »
di kaya malito ang mga master dito kulang sa info ha...
« Reply #4 on: March 26, 2011, 02:13:52 PM »
napalitan ko na po lahat electrolitc sa vertical ..may problem po ngayon asan nka connect yung capacitor na nasa ilalim ng bord ,kung alin sa pin ng vertical ic ko i hinang..tampered na ksi ang bord.. :)tenk u masters
« Reply #5 on: March 26, 2011, 02:20:18 PM »
sis post mo number ng Vertical IC mo pati yung value ng Ecap na nasa ilalim ng board para matulungan ka ng mga master.
« Reply #6 on: March 26, 2011, 02:32:54 PM »
la 7835 value ng ng cap .22 uf  pls help
Offline taqui
  • ang ganda ko
« Reply #7 on: March 26, 2011, 03:20:49 PM »
pa ot
TOINKS.. out muna ako dito... :(
  • Pogi/Ganda Points: 915
« Reply #8 on: March 26, 2011, 03:21:38 PM »
sis  anung chassis  ito ?
can you post the major parts  kong hndi  alam ?
Power Reg ?
jungle ?
system con ?
« Reply #9 on: March 26, 2011, 03:39:37 PM »
regulator stk-73907-t,jungle an5160nk,sytem mn152810q16,model no.tc2121n
« Reply #10 on: March 26, 2011, 03:52:43 PM »
sinasabi ko na nga  ba..
Chassis GL8HA
ito  sis kong napalitan  mu  na  yan ng lahat ng ecaps sa vert sect. near in vert. drive.. mukhang may nakakaligtaan  ka pag dalawang ecaps na palitan...
palitan  mu  yung dalawang magkatabi na 100uf/25v or 50v  malapit sa flybak. (upper side) common sakit yan ng ganyang chassis.
vertical linearity trouble
pakape  ka na  sis ;D
« Reply #11 on: March 26, 2011, 03:59:30 PM »
Yan Ts..si Master Ultra na yan ..gawin mo muna suggestion nya.. tapos mag pakape ka nadaw.
« Reply #12 on: March 26, 2011, 04:15:00 PM »
ok try ko
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #13 on: March 26, 2011, 04:37:11 PM »
pin 11 to ground.. :)
« Reply #14 on: March 26, 2011, 04:47:52 PM »
tnx  dito sis di ko pala  sinagot  yung  tanong ng TS
nagjump  pala  aku sa  conclusion  ko  ;D
@TS  pwede  mu  bang  mapicturan ang main board ng chassis  na yan..
at post  mu  dito...
i pipin-out  lang  natin  kong saan ang 100uf/25v ecaps. na tinutukoy  ko..
nang may reference ang iba...
marami  kasing nadadali  nyan..
common sakit  din  kasi  yan  ng pana...
wala  kasi  aku sa SVC shop ngayon para manghalungkat  ng mga board ;D
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #15 on: March 26, 2011, 07:34:03 PM »
la7835=vrtcl ic
.22uf/50v connection =ground ,= positive ng ecaps sa anode ng D451
220uf/25v=c559,,330uf/35v,,near in fbt yan ang symptoms kdalasan, vertical linearity trouble, plitan m n2
c455=100uf/50v,c451=220uf/25v,,savertical section plitan ndin
hope nka tulong
« Reply #16 on: March 27, 2011, 12:06:24 AM »
ok tenks salamat po.post ko bukas ano resulta...GOD BLESS
« Reply #17 on: March 27, 2011, 12:47:15 AM »
tenk u po gumana na...may nakita rin ako fusible resistor na pinalitan ng 10 ohms ..supply pa punta ng vertical.tenk you talaga mga masters.  olryt na!!!!
Offline RhUNhA
« Reply #18 on: March 27, 2011, 06:52:01 AM »
kung gnun magbigay kn ng kape sa mga nag bigay sau ng tulong pra hindi mag sawa ang mga k member,,recharge all!!!just press it
ui congrats nga pla ;D ;D ;D ;D
Offline Vaounsi
« Reply #19 on: March 27, 2011, 02:37:05 PM »
ano sira resistor lng ba? :)
