Hi Efren,welcome to the forums, please post your tube projects for other members to see and enjoy.....
hi efrenwelcome aboard, enjoy mo stay mo ditomadami ding mahilig sa tube ditoisa na ako, but i will leave the sonic qualitiesto the listener, depende kasi iyan sa taomay kaniya-kanyang taste iyan.para sa akin, I like both tube and solid state.I guess depende siguro sa pag kaka design orpag kakagawa ng unit. Sir tony has a lot of tube projectsand really built well. As you can see, he really take time to built it I wish I have a lot of time in my handto build one of this tube amps.sana ma post mo din sir ang mga projects mo ditoI would definitley ask for you and sir tony's assistancein the future thanks again and welcome po sa inyo
Makigulo rin ako dito. Tnx sir efren, share na po tungkol dito.
Thanks a lot sir Danny, I met sir Tony personally as I have been to his place just recently and I can vouch that you can learn a lot from the man, he unselfishly shared a lot of knowledge about tubes & everything about electronics under the sun, oh by the way sir, hindi ako sarado sa solid state, one of my amp is designed by an Italian, Flavio Delipianne, a 5w/ch transistorized in class A mode driven by a DIY'ed 6BL8 tube line driver, as you can see mahilig po ako sa low wattage amplification, especially single ended designs, provided you MUST have a highly sensitive driver to truly enjoy the sonic qualities of these amps. @ sir Tony,thank you po sa added info, one of the box (unopened) have the pamphlet but it gives me a hard time figuring out which is which, kasi Cyrilic yun nakasulat puro Russian .
Waaah lalo akong naiinggit. Bakit kasi ngayon pa ako nawalan ng budget. Sana meron na rin me tube amp. Sir Tony just wait I will try to get the items from you till may.
